Where can I buy a ITB? - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-02-2013, 03:17 PM   #11
GhostTribute
GhostTribute's Avatar
Fan#: 107929
What I Drive: 2001 Mazda Tribute (2.0L Zetec)
Points 377, Level 7
Points: 377, Level: 7 Points: 377, Level: 7 Points: 377, Level: 7
Level Up 54% Completed
Level up: 54% Level up: 54% Level up: 54%
Forum Activity 9%
FF Reputation: 1 GhostTribute Good Standing Member
It's a GSW5.
I hear yea about the OEM ECUs. I'm coming over form the Honda world and there is nothing like chipping and tuning an OEM OBD1 ECU. It's easy and reliable, add and remove components and circuits. It's great! The Ford hardware is all new to me.
GhostTribute is offline
Old 08-02-2013, 10:08 PM   #12
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,915, Level 87
Points: 18,915, Level: 87 Points: 18,915, Level: 87 Points: 18,915, Level: 87
Level Up 13% Completed
Forum Activity 10%
Buy-Sell-Trade Rating: (4)
Only reason kids do OBD1 is because Hondata is too complicated for them.
I've played a bit with K Pro (all motor and turbo). The Ford ECU has much more in the way of tunability and options.
You just have to think outside the box with it. For instance, just because something is for EGR (DPFE) doesn't mean that's all it can do. It's simply a tunable switch with and input. You can do whatever you want with it.
Far as things like sequential spark, there you'll have to swap to a V-8 ECU to get the added drivers. It's the project next up on my list.
iminhell is offline
Old 08-03-2013, 12:16 AM   #13
GhostTribute
Fan#: 107929
Points 377, Level 7
Forum Activity 9%
The Hondata S300 is for OBD1 ECUs and it has a lot more tuning options than the Hondata K Pro does. I've used both.... The K pro is very limited compared to the available OBD1 tuning options.
That is the same way that the OBD1 Honda ECUs work. The signals are just input or output and can be used any way you want... if you know the hex addresses in the ROM they can be tuned even further.
May have to look into this option.... however my MS3 is sitting here and I don't really want to spend more money on tuning hardware and software.
Old 08-03-2013, 08:11 AM   #14
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,548, Level 100
Points: 52,548, Level: 100 Points: 52,548, Level: 100 Points: 52,548, Level: 100
Level Up 0% Completed
Forum Activity 57%
Activity: 57% Activity: 57% Activity: 57%
Buy-Sell-Trade Rating: (28)
an your ms3 use and control the knock sensor ? nope , kinda of an important thing to have that the Ford ECU and you can control the ns3 cannot
How will you turn off the adaptive learning in the stock ECU so it doesnt try to over do what you have changed with the ms3 ?
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 08-03-2013, 09:24 AM   #15
GhostTribute
Fan#: 107929
Points 377, Level 7
Forum Activity 9%
Yes I have the knock board on my MS3. So monitoring the stock knock sensor will not be an issue. As far as adaptive learning goes, not sure what you mean. The Stock ECU will no longer be installed in my vehicle. so the adaptive learning will not be a worry.
The MS3 is a complete stand alone engine management system. it works without the use of the OEM ECU.
Old 08-03-2013, 03:33 PM   #16
beatmaniac1
beatmaniac1's Avatar
Fan#: 90996
What I Drive: 2003 red svtf
Points 416, Level 8
Points: 416, Level: 8 Points: 416, Level: 8 Points: 416, Level: 8
Level Up 32% Completed
FF Reputation: 2 beatmaniac1 Good Standing Member
Tom is there a way that the stock ecu program could be tricked out to run with a MAP input instead of a MAF ? Or to convert the signal into a comparable MAF signal ?
beatmaniac1 is offline
Old 08-03-2013, 03:46 PM   #17
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 57%
I have not tried that so I am not sure
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 08-03-2013, 03:59 PM   #18
beatmaniac1
Fan#: 90996
Points 416, Level 8
Maybe some kind of piggy-back device could be programmed to convert a MAP voltage into a proportionnal signal for the ecu... Just throwin ideas loll
Old 08-03-2013, 04:19 PM   #19
GhostTribute
Fan#: 107929
Points 377, Level 7
Forum Activity 9%
In order to remove the mass air flow sensor completely you would also have to find a replacement signal for the intake air temperature signal.
Or you could keep the MAF just for the IAT signal.
The ECU's use completely different processes to convert the flow of air entering an engine. There is no changing a MAP reading to be proportional to a MAF signal. They don't work on the same principles.
That is why they are two separate engine management processes, Speed density (MAP) and Mass Air (MAF)
Old 08-03-2013, 04:24 PM   #20
Hardline
Fan#: 117092
What I Drive: 2000 ZX2 Turbo
Points 384, Level 7
Points: 384, Level: 7 Points: 384, Level: 7 Points: 384, Level: 7
Level Up 68% Completed
FF Reputation: 1 Hardline Good Standing Member
Seems to be a lot of megasquirt hating going on here....
1turbofocus, I have yet to find something my factory ecu did that my ms3 does not do... Aside of OBD-II Connectivity, which I have no want or need for.
Hardline is offline
