auto trans Pan drain valve for flushing - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-26-2013, 09:55 AM   #1
herman
Fan#: 53783
What I Drive: 2007 Red SES
Points 1,107, Level 18
Points: 1,107, Level: 18 Points: 1,107, Level: 18 Points: 1,107, Level: 18
Level Up 7% Completed
FF Reputation: 1 herman Good Standing Member
Im thinking about installing a B&M drain plug kit in my trans pan. My thinking is to use this for flushing out the old fluid.
Does anyone have any experience in doing this ?
herman is offline
Old 07-26-2013, 01:09 PM   #2
elsolo
elsolo's Avatar
Fan#: 96835
Points 2,576, Level 30
Points: 2,576, Level: 30 Points: 2,576, Level: 30 Points: 2,576, Level: 30
Level Up 84% Completed
Forum Activity 8%
Those plugs often leak.
I find it pretty easy to remove the cooler return line from the ATX.
elsolo is offline
Old 07-26-2013, 03:52 PM   #3
emsvitil
Fan#: 50210
What I Drive: 2000 SE Wagon
Points 3,052, Level 34
Points: 3,052, Level: 34 Points: 3,052, Level: 34 Points: 3,052, Level: 34
Level Up 2% Completed
Forum Activity 3%
FF Reputation: 9 emsvitil Good Standing Member
When you drop the pan, you can change the filter and remove all the metallic sludge that accumulates around the pan magnet........
Ed
emsvitil is offline
Old 07-26-2013, 05:26 PM   #4
elsolo
elsolo's Avatar
Fan#: 96835
Forum Activity 8%
Yes, but getting the fluid out before dropping the pan is always less messy.
elsolo is offline
Old 07-26-2013, 05:57 PM   #5
amc49
Fan#: 96610
Points 3,258, Level 35
Points: 3,258, Level: 35 Points: 3,258, Level: 35 Points: 3,258, Level: 35
Level Up 39% Completed
Forum Activity 3%
The B&M plug kinda sucks. Too thick, you leave whatever oil is lower than the thickness of the inside nut. The nylon washer cannot be tightened as much as needed either. You want really tight there because you have to loosen the plug while holding the outer nut or the outer nut spins free and then loose, the only resolution then is to pull pan again. You can even slightly loosen it using the double wrench method since the nylon gives with time. The plug is also low enough it can snag things to wreak havoc with pan depending on where you locate it.
I make up my own by shortening inside nut height and aluminum washer for no give and super tight and an allen plug used after tapping the 1/8" NPT slightly deeper. Then no plug sticking out, entire assembly tight as sh-t and the oil pretty much all drains out. Fixture located about in middle to take advantage of the stock installed trans angle, the trans will rub back surface before fixture contact, it also clears inside filter and any thing else. Two cars fitted up and not a drop leaked.
amc49 is offline
