Anzo Headlights review and comments - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus First Generation > MK1 Interior Mods & Upgrades
Old 07-25-2013, 10:27 PM   #1
sgibbs2013
sgibbs2013's Avatar
Fan#: 109206
What I Drive: 2001 Ford Focus ZX3 Black
FF Reputation: 1 sgibbs2013 Good Standing Member
Hello again group.
I am searching for a projector headlight set and I heard that the ebay projectors are shytty. I saw some Anzo projector headlights for the mid $250s. Does anybody have experience with this brand headlights?
Black 2001 Ford Focus ZX3.
Mod list: Blacked out headlights w/ Bixenon 6000k HID Kit, JVC CD Player w/ Bluetooth, hard wired radar detector. 35/15% tint, JVC CS-V6837 6x8" speakers (4), Dual 400 watt Amp, MTX 4500 10" sub in custom box
sgibbs2013 is offline
Old 07-25-2013, 10:58 PM   #2
Red01Focus
Fan#: 40437
What I Drive: 2001 Infa Red SE
Points 11,103, Level 69
Points: 11,103, Level: 69 Points: 11,103, Level: 69 Points: 11,103, Level: 69
Level Up 64% Completed
FF Reputation: 10 Red01Focus Great Standing Member
Buy-Sell-Trade Rating: (56)
buy the ebay's and retrofit better projectors in,anzo's are usually the same thing just marked up
SEDAN REVOLUTION #13
Red01Focus is offline
Old 07-26-2013, 12:39 AM   #3
Sniper Focus
Sniper Focus's Avatar
Fan#: 84221
What I Drive: '03 SVT EAP "Eurotrish"
Points 2,122, Level 27
Points: 2,122, Level: 27 Points: 2,122, Level: 27 Points: 2,122, Level: 27
Level Up 82% Completed
Forum Activity 15%
Activity: 15% Activity: 15% Activity: 15%
FF Reputation: 22 Sniper Focus Great Standing Member
Buy-Sell-Trade Rating: (13)
Yeah, eBay has the same lights that any other site sells, the good brands and the bad.
I heard Anzos are some of the "better" lights out there.
Sniper Focus is online now
Old 07-26-2013, 04:04 AM   #4
calebstubstad
Chef Boyardee
calebstubstad's Avatar
Fan#: 103240
What I Drive: 2000 Atlantic Blue LX
Points 2,716, Level 31
Points: 2,716, Level: 31 Points: 2,716, Level: 31 Points: 2,716, Level: 31
Level Up 78% Completed
FF Reputation: 4 calebstubstad Good Standing Member
take you stock headlights, and retrofit in a set of mini h1 projector's for around the same price!
http://www.theretrofitsource.com/pro...roducts_id=227
this kit will literally pop right in to your headlight. it's super easy. remove headlight from car, take out bulbs. open headlights in oven (many how to's around here for painting, same concept). take projector and put base through hole left by bulb. put adapter, washer, and locking ring on and tighten. put shroud on projector. (repeat for other headlight). put h1 bulb in headlight. take HID kit, wire to car (plug and play, literally connect ballast to original harness and bulb). reconnect headlights to car. enjoy this forever!
you can even wire in the high beam wire (super easy) to the solenoid to keep high beam function, too!
Rally Revolution #43
[HOONIGAN]
Originally Posted by matmatician View Post
Not the bear the zoo deserves, but the bear the zoo needs.
calebstubstad is offline
Old 07-26-2013, 08:23 AM   #5
sgibbs2013
sgibbs2013's Avatar
Fan#: 109206
That looks good. Sweet. Im going check out that link
Old 07-26-2013, 08:29 AM   #6
sgibbs2013
sgibbs2013's Avatar
Fan#: 109206
Could you provide more details about wiring the solenoid for the high beam? I never done this before but I plan to order the kit.
Old 07-26-2013, 01:15 PM   #7
calebstubstad
Chef Boyardee
Fan#: 103240
You'll need to cut the pigtail that plugs into the back of the stock headlight. I forgot the focus was like this. Its very easy though. The pigtail has 3 wires. Low high and negative. The positive (low beam) and negative will go to the ballast. The high beam wire will go to the solenoid wire. The solenoid controls the cutoff shield (metal piece that also gives the super sharp cutoff line and creates the "color flicker" you see on like audis and bmws with the blue and purple at the very top). When you put the high beams on the solenoid activates an electromagnet that makes the shield go down.
On the TRS website it has a ton of info on everything projectors and hids. Real good info to scan through!
Also, youtube has vids of other people doing this retrofit. Not the focus, but similar. The focus is easiest cause of the h4 bulb adapter plate provided, so it's aimed correct right away where as other retrofits would be harder, but that's more for a different day lol
[HOONIGAN]
Old 07-26-2013, 01:19 PM   #8
calebstubstad
Chef Boyardee
Fan#: 103240
Heres a how to actually of that red car up there
http://forums.focaljet.com/mk-i-exte...storation.html
[HOONIGAN]
Old 07-27-2013, 12:20 AM   #9
sgibbs2013
sgibbs2013's Avatar
Fan#: 109206
Thanks,
I ordered the projector retro kit tonite. I will probably hit u up again if I need tech support.
Old 07-27-2013, 03:28 AM   #10
calebstubstad
Chef Boyardee
Fan#: 103240
awesome! yeah, i never did pull the trigger since I was just about to when a pair of machs came up locally for 50 bucks. you really can't pass that deal up. but i'm glad to help whenever!
[HOONIGAN]
