How to disconnect Zetec coil pack for testing? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-25-2013, 03:15 PM   #1
OCTurbine
Fan#: 116933
What I Drive: 2001 white Focus SE, Zetec 2.0l
FF Reputation: 1 OCTurbine Good Standing Member
Howdy, y'all,
Firstly, searching this forum isn't working. I attempted a thread search for the string "coil pack" and the webserver returned a "loading" message, but nothing was displayed.
I'm trying to fix an intermittent stalling-at-warm-idle problem. I've replaced the IACV, the PCV valve, and the PCV tube vacuum hose. I checked the rest of the vacuum system and found no leaks. A local shop also tested for a vacuum leak using a smoke tester. None found.
I'm gonna check the coil pack, even though there's no strong evidence of ignition failure. The plugs and wires are new and I carefully retorqued the plugs to 10 ft-#. There was a wiring problem that caused an ignition fuse failure couple months ago, so I'm suspicious of the coilpack control wiring.
But how do I remove the coilpack connector? My Haynes manual doesn't say.
Oh, never mind. Found a useful video at YouTube, but I'll post anyway just in case anybody has another tip:
http://www.youtube.com/watch?v=BxvcAwNzanc
Coilpack testing:
http://easyautodiagnostics.com/ford_...cus_coil_1.php
Thanks much.
OCTurbine is offline
Old 07-25-2013, 03:34 PM   #2
freemind
Vince your Moderator
freemind's Avatar
Fan#: 67513
Points 6,769, Level 54
Points: 6,769, Level: 54 Points: 6,769, Level: 54 Points: 6,769, Level: 54
Level Up 10% Completed
Forum Activity 49%
Buy-Sell-Trade Rating: (23)
Have you tested the TPS?
Hatch Nation #140
Caeci caecos ducentes
freemind is offline
Old 07-25-2013, 04:38 PM   #3
bringler26
FUBARCUS
bringler26's Avatar
Fan#: 59705
What I Drive: 03 ZX3 & 07 Impreza 2.5i
Points 9,434, Level 65
Points: 9,434, Level: 65 Points: 9,434, Level: 65 Points: 9,434, Level: 65
Level Up 28% Completed
Forum Activity 7%
Here are my results from searching "coil pack"
http://www.focusfanatics.com/forum/showthread.php?t=281582
2007 Subaru Impreza 2.5i - current DD
I always moderate naked!
bringler26 is offline
Old 07-25-2013, 05:43 PM   #4
amc49
Fan#: 96610
Points 3,356, Level 36
Points: 3,356, Level: 36 Points: 3,356, Level: 36 Points: 3,356, Level: 36
Level Up 4% Completed
Forum Activity 39%
Activity: 39% Activity: 39% Activity: 39%
Could easily be the TPS. BTDT.
amc49 is online now
Old 07-26-2013, 03:24 PM   #5
OCTurbine
Fan#: 116933
I'll check the TPS
I'll check the TPS as described in this thread:
http://www.focusfanatics.com/forum/a...?t-263152.html
I have an OBD-II scanner, so I'll check the Absolute Throttle Position, which should be 0% at engine idle, and 100% at wide-open throttle (WOT).
I'm increasingly suspicious of the EGR system so I'll also check the Commanded EGR parameter (0% when EGR is off and 100% when on), and the EGR Error parameter. The owner of the Focus took it to a tech for repair of a short that caused the ignition fuse to blow. She seems to think that the warm-stalling-at-idle problem began about that point.
Thanks much.
