Issues with 2001 Focus ZTS - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-24-2013, 02:13 PM   #1
gmancd
Fan#: 117118
What I Drive: 2001 Gold ZTS
FF Reputation: 1 gmancd Good Standing Member
I have a 2001 ford focus zts, zetec engine. About eight months ago, I had a problem with jumping and hesitation when going uphill, and after replacing the spark plugs and wires, I replaced the coil and the problem went away. About three months ago, it started the jumping and hesitation again(maybe its missing), but it does it at random times, not just going uphill. I also began to get the check engine light. The people at auto zone put the code reader on it and it gives a 0171, lean mix bank one. Since I am getting this with the hesitation/missing, they dont think it is the oxygen sensor. I have also replaced the pcv valve and the fuel filter and tried higher octane gas, no change. Any ideas on what this might be?
gmancd is offline
Old 07-24-2013, 02:40 PM   #2
gmancd
Fan#: 117118
maybe plugs?
After looking thru many more posts, I noticed that Bosch plugs may cause a problem. The plugs i installed were Bosch +2's, so i guess i will get some motorcraft plugs and see if that takes care of it. Too bad i didnt see this before i posted.
gmancd is offline
Old 07-24-2013, 02:41 PM   #3
freemind
Vince your Moderator
freemind's Avatar
Fan#: 67513
Points 6,790, Level 54
Points: 6,790, Level: 54 Points: 6,790, Level: 54 Points: 6,790, Level: 54
Level Up 20% Completed
Forum Activity 53%
Activity: 53% Activity: 53% Activity: 53%
Buy-Sell-Trade Rating: (23)
When was the last time that you changed the fuel filter?
Hatch Nation #140
Caeci caecos ducentes
freemind is offline
Old 07-24-2013, 03:54 PM   #4
bile0026
bile0026's Avatar
Fan#: 97349
What I Drive: 2009 Amber Gold Metalic Focus
Points 401, Level 8
Points: 401, Level: 8 Points: 401, Level: 8 Points: 401, Level: 8
Level Up 2% Completed
FF Reputation: 7 bile0026 Good Standing Member
I was going to suggest taking a look at the plugs. For some reason Ford's engines don't like "new style" plugs that have more than a single diode/prong. Also make sure to get platinum and not iridium. Autolites generally work well if you can't find motorcraft plugs.
2009 Ford Focus Sedan SE--Amber Gold Metallic--FS Cool-flo intake, 17" Black Kazera Rims with Potenza S-04PP, Custom 2.5" Exhaust.
bile0026 is offline
Old 07-24-2013, 07:29 PM   #5
amc49
Fan#: 96610
Points 3,381, Level 36
Points: 3,381, Level: 36 Points: 3,381, Level: 36 Points: 3,381, Level: 36
Level Up 21% Completed
Forum Activity 55%
Use DOUBLE platinum plugs since zetecs use waste spark coils.
And look at the pcv HOSE where it goes around back of motor to plug into the intake manifold, they commonly suck shut or suck a hole to make your lean code mentioned.
amc49 is offline
