17x9 on 2013 SE? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-24-2013, 11:09 AM   #1
bnoon
Fan#: 116854
What I Drive: 2013 Focus SE hatch
FF Reputation: 1 bnoon Good Standing Member
17x9 on 2013 SE?
I've not been able to pull my stock 16's off to measure up clearances and have been wondering if anyone is running or even mocked up 17x9 wheels on a MKIII yet. I want to get Enkei RPF1's redrilled to 5x108 since those are the wheels I had on my Mazdaspeed 3 and loved them. Only 15.9 pounds in 17x9 45 offset. For tires, 235/45/17's will be perfect.
2013 SE Hatch - 5 spd, Spectre filter, no lid, Unleashed E85 tune
1976 GMC C15 Sierra Classic - 454, AC, 2WD, LWB, 1.75" headers, .501/.510 232 cam
bnoon is offline
Old 07-24-2013, 06:22 PM   #2
theshrewz
Fan#: 103228
What I Drive: 2012 Silver Se Focus
Points 2,185, Level 28
Points: 2,185, Level: 28 Points: 2,185, Level: 28 Points: 2,185, Level: 28
Level Up 24% Completed
FF Reputation: 2 theshrewz Good Standing Member
well they run 235's on the stock 18's that come on the Ti and ST
theshrewz is offline
Old 07-24-2013, 06:26 PM   #3
Twenty
Sonic's Mk3 Crew #17
Twenty's Avatar
Fan#: 90312
What I Drive: 2012 YB SE sedan w/ ST exterior
Points 22,044, Level 92
Points: 22,044, Level: 92 Points: 22,044, Level: 92 Points: 22,044, Level: 92
Level Up 70% Completed
Forum Activity 10%
FF Reputation: 10 Twenty Great Standing Member
9's can fit, and as far as inside clearance you should be fine, though steering limiters may be needed (as found on the Ti with handling package, for example). From factory Foci can have up to 8" wide, +55 wheels so 9" +45 should clear the inner workings.
officialTHREETWENTY
2012 YB Focus SE Sedan [featured in Performance Ford, Sept '14]
1992 BW Grand Prix SE Sedan [restomod project]
SR#74/SMk3C#17/YBOC#03
Bill M.
Twenty is offline
Old 07-24-2013, 07:06 PM   #4
Julian@TireRack.com
Fan#: 102247
What I Drive: N/A
FF Reputation: 2 Julian@TireRack.com Good Standing Member
If you base it on this the 9" ET45 would stick out 20mm more towards the fenders but you should clear all the inner workings. The 235/45 would be a good fit on a 9" wheel, but I would agree with the above, you may get some rubbing lock to lock and may need to do some fender modification or camber adjustments to make it work perfect.
888-428-8355 ext. 4798
Julian@TireRack.com
Remember to reference Julian/Focus Fanatics in the "previous contacts" field to make sure the forum get's credit!
Julian@TireRack.com is offline
Old 07-26-2013, 11:46 AM   #5
bnoon
Fan#: 116854
All good to know. I knew the 235 tires would work at a minimum since that's what the ST's run from the factory. With the 9 inch wheel and 45 offset it's 3mm less inner clearance and sticks out 23mm farther than the 8 inch wide 55 offset ST wheel. 245-255 on an extreme fitment maybe with some fender massaging and the perfect offset. Thanks guys.
bnoon is offline
Old 07-29-2013, 11:58 PM   #6
BOMBtech001
BOMBtech001's Avatar
Fan#: 116373
What I Drive: 2012 Black Focus Sport
Points 2,818, Level 32
Points: 2,818, Level: 32 Points: 2,818, Level: 32 Points: 2,818, Level: 32
Level Up 46% Completed
Forum Activity 2%
FF Reputation: 2 BOMBtech001 Good Standing Member
I have the 2012 SE Sport with the handling package and DCT... I have stock 17's and Eibach Sportline Springs that have lowered it nearly 2" it practically sits on the tires. I have 20 mm spacers on rear, 15mm front...for a wider stance. I would like to get some 18" rims, but I want the offset just right I like the wider stance, and if i can get it without spacers even better.
BOMBtech001 is offline
Old 07-30-2013, 11:30 AM   #7
Juicedz
Juicedz's Avatar
Fan#: 108814
What I Drive: 2013 Ford Focus Hatchback SE, 5sp
Points 2,337, Level 29
Points: 2,337, Level: 29 Points: 2,337, Level: 29 Points: 2,337, Level: 29
Level Up 25% Completed
Level up: 25% Level up: 25% Level up: 25%
Forum Activity 6%
FF Reputation: 3 Juicedz Good Standing Member
17x9 at only 15.9 pounds?! Now that sounds sexy.
'13 Oxford White Hatch 5-speed
injected 93 tune, steeda intake, e-focus rmm
Hatch Nation#24 172whp 157wtq
Juicedz is offline
Old 07-30-2013, 01:52 PM   #8
bnoon
Fan#: 116854
Yeah and not bad on price either. Goodwin Racing has the wheels for something like 239 each. I have been quoted 50 per wheel to redrill them too. As I said, had them on my ms3 and loved them.
bnoon is offline
Old 07-30-2013, 11:35 PM   #9
Juicedz
Juicedz's Avatar
Fan#: 108814
Forum Activity 6%
The lightest I've found so far are the 17x8 Team Dynamic Motorsport wheels. I believe they come in at around 17.9 pounds (est.). Only plus side is that they're direct bolt on and run $180 per wheel.
Juicedz is offline
Old 07-31-2013, 05:46 AM   #10
thenorm
thenorm's Avatar
Fan#: 14947
What I Drive: '04 liquid grey ZX3, built for FSP
Points 5,532, Level 47
Points: 5,532, Level: 47 Points: 5,532, Level: 47 Points: 5,532, Level: 47
Level Up 91% Completed
Forum Activity 10%
FF Reputation: 35 thenorm Great Standing Member
i was sure you can get the TDs in 17x9.
to the OP. since it is an aggressive fitment, err on the high side of offset, because you can always use spacers to clear the inners and you maintain the highest possible fender clearance.
if I had a MKIII I would be putting on 17x9 too.
May 2014 ROTM
for auto-x: '04 Liquid Grey ZX3
for street: '02 Infrared SVT
thenorm is offline
