not sure which fluid to buy for 4F27E, Mercon V or LV? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-24-2013, 03:06 AM   #1
gabi911
Fan#: 117102
What I Drive: 2004 White Focus MKI
FF Reputation: 1 gabi911 Good Standing Member
hi.
according to the ECAT software my car has a 4F27E Transmission.
i wanted to buy some oil to replace and i can decide which oil i need
Mercon V or Mercon LV?
its a 2004 Focus
i tried to google and some PDF's says V and other says LV
people saying LV go to 2007 focus and later
which one is the correct?
best regards
gabi911 is offline
Old 07-24-2013, 05:48 AM   #2
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,762, Level 98
Points: 27,762, Level: 98 Points: 27,762, Level: 98 Points: 27,762, Level: 98
Level Up 42% Completed
Forum Activity 4%
Mercon V is what my owner's manual recommends. Have you looked in your owner's manual under fluid specifications?
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 07-24-2013, 06:02 AM   #3
02 wagon
Fan#: 99149
What I Drive: 2002 red wagon
Points 39, Level 1
Points: 39, Level: 1 Points: 39, Level: 1 Points: 39, Level: 1
Level Up 78% Completed
FF Reputation: 1 02 wagon Good Standing Member
307-01 Automatic Transaxle/Transmission 2004 Focus
SPECIFICATIONS Procedure revision date: 05/09/2007
Specifications Printable View
General Specifications
Item Specification
MERCONŽ V Automatic Transmission Fluid XT-5-QM MERCONŽ V
Motorcraft Metal Surface Cleaner ZC-21 WSE-M5B392-A
Thread Sealant with PTFE TA-24 WSK-M2G350-A2
Ultra Silicone Sealant TA-29 —
Capacities
Refill Capacities — Liters Quarts
Transaxle dry fill capacity 6.7 7
02 wagon is offline
Old 07-24-2013, 06:06 AM   #4
gabi911
Fan#: 117102
http://www.docstoc.com/docs/document...doc_id=9216698
in this documents its says MERCON V
https://www.fcsdchemicalsandlubrican...ickref/atf.pdf
in this one it says MERCON LV
is it possible that until 2007 there was not LV oil so they recmanded V
and soon as LV was made they recomanded him as replacement for th V?
gabi911 is offline
Old 07-24-2013, 06:37 AM   #5
whynotthinkwhynot
Captain TMI
Fan#: 18416
Forum Activity 4%
Use MerconV. You should always consult the owner's manual that came with your car in the glove compartment. That will give you the specified fluid for your vehicle. Mercon LV is not compatible with your transmission. If you didn't buy your vehicle with an owner's manual, then search online and eventually you'll find an owner's manual you can download. This is important to have because it will help you figure out how to change light bulbs and other simple things that you might have questions about throughout the life of the vehicle.
Maybe this will help: http://www.ford-trucks.com/forums/76...mercon-lv.html
Be eclectic.
Old 07-24-2013, 07:51 PM   #6
amc49
Fan#: 96610
Points 3,270, Level 35
Points: 3,270, Level: 35 Points: 3,270, Level: 35 Points: 3,270, Level: 35
Level Up 47% Completed
Forum Activity 9%
The master chart showing LV only for 4F27E is wrong just like the earlier master lube chart they used years ago showing V went in all cars using regular Mercon. That chart back then tore up plenty of Ford cars getting serviced right at dealerships using official Ford charts. The fiasco forced the remix of all Mercon V at the time but plenty of damage was done. Ford hurriedly yanked all those charts after the lawsuits piled up and issued a bulletin covering the issue and the fluid remix later. Looks like some dumb-ss making up current charts has not learned a thing. Even now other oil manufacturers are reluctant to drop 'Mercon only' fluid to go to a Mercon-Mercon V mix. They still sell both whereas Ford does not, only the one. Could be because the 'Mercon only' also works on Dexron cars and they don't want to confuse the issue and affect sales.
Use what the owner manual says and pretty sure V not LV.
amc49 is offline
Old 07-24-2013, 09:08 PM   #7
whynotthinkwhynot
Captain TMI
Fan#: 18416
Forum Activity 4%
LV stands for low viscosity. If your transmission is not made for it, damage will result. Ford switched to this fluid on some vehicles in 09. It is important that you use MerconV not LV.
Be eclectic.
Old 07-26-2013, 05:37 PM   #8
amc49
Fan#: 96610
Forum Activity 9%
and LV has NOT replaced V, not yet anyway.
amc49 is offline
