2000 ZX3 - Sudden Loss of Brake Pedal - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-22-2013, 09:40 AM   #1
SVT0716
Fan#: 83035
What I Drive: 2004, Highlight Silver, SVT EAP
FF Reputation: 1 SVT0716 Good Standing Member
Hi All,
I sold my SVT last year and bought a Mustang. Mustang ended up with 400whp and I picked up a ZX3 as a daily last week.
I've been driving it the past few days, and this morning when I got into the car I noticed that it suddenly had no brake feel.
The brakes still work, but the pedal shoots to the floor. Hopped out of the car and checked the fluid, didn't see any in the reservoir at all.
I filled up the reservoir and tried again (i know i need to bleed them, but i was late for work).
Anyone else have this issue, I checked under the car and couldn't find any leaks.
When i get home tonight I'm going to try and bleed them, but my concern is that bleeding them implies air got into a sealed system somehow.
I don't know anything about this car so any info would be appreciated.
Cheers,
SVT0716 is offline
Old 07-22-2013, 12:08 PM   #2
PDQEagle
Fan#: 9356
What I Drive: 03 Focus ZX3
FF Reputation: 11 PDQEagle Great Standing Member
You've been driving it the last few days???? what does that mean-is it new to you. If so, that's a problem with the car when you bot it
PDQEagle is offline
Old 07-22-2013, 12:12 PM   #3
SVT0716
Fan#: 83035
Sorry for being unclear. I purchased the car last week, and drove it for 4 days. experiencing no problems with the brakes.
The issue started this morning, when i started the car. Last night I had brakes, this morning I don't.
Fluid is not leaking anywhere I can see.
SVT0716 is offline
Old 07-22-2013, 12:43 PM   #4
CJ148941
Fan#: 115820
What I Drive: 2011 Black SE, 2.0L 5 spd
FF Reputation: 1 CJ148941 Good Standing Member
Im not to familiar with this model, but have you checked the pads and/or shoe thickness? You may have bought a car with thin pads/shoes causing fluid to be low, who ever you bought it from may have never added fluid from a previous leak, fluid change, ect.
A few questions thou, is this a manual trans with shared reservoir for the brake system? And did your red brake warning like come on, like if you had parking brake set?
CJ148941 is offline
Old 07-22-2013, 12:45 PM   #5
SVT0716
Fan#: 83035
Thanks for the response. Auto, so no sharing fluid for the clutch.
No warning lights, I will check the pads as soon as im home today.
SVT0716 is offline
Old 07-22-2013, 01:12 PM   #6
CJ148941
Fan#: 115820
I suggest checking your reservoir to see if it has a connector on it for a low fluid sensor, if it does your sensor may be messing up, or stuck due to old fluid that was never changed. It wont cause your problem but I would do some digging to find out why it didn't come one to keep your self safe.
CJ148941 is offline
Old 07-22-2013, 01:16 PM   #7
SVT0716
Fan#: 83035
Ironically it does have the sensor, but it appears not to work, as the fluid was so low but no lights came on lol
SVT0716 is offline
Old 07-22-2013, 02:31 PM   #8
CJ148941
Fan#: 115820
The float in the reservoir may be stuck in the high position due to old fluid gunk, you might me able to push it down with a small metal rod or your finger. Try pushing it down while someone is in your car to see if light comes on. I think you have to replace the whole reservoir the fix the float if this doesn't work. I would make sure that the float is the problem before replacing it.
CJ148941 is offline
Old 07-22-2013, 02:53 PM   #9
freemind
Vince your Moderator
freemind's Avatar
Fan#: 67513
Points 6,589, Level 53
Points: 6,589, Level: 53 Points: 6,589, Level: 53 Points: 6,589, Level: 53
Level Up 20% Completed
Forum Activity 49%
Buy-Sell-Trade Rating: (23)
Fill up the fluid. Pump the brakes. make sure that the cap is put on correctly. Then hold them down. Does the petal slowly go down?
At first thought, Master Cylinder or, wheel cylinder leak.
Hatch Nation #140
Caeci caecos ducentes
freemind is online now
Old 07-23-2013, 01:53 PM   #10
amc49
Fan#: 96610
Points 3,267, Level 35
Points: 3,267, Level: 35 Points: 3,267, Level: 35 Points: 3,267, Level: 35
Level Up 45% Completed
Level up: 45% Level up: 45% Level up: 45%
Forum Activity 7%
Won't be worn brake parts alone. All masters are calculated to hold enough fluid to cover the entire range of use until brake pads/shoes are dead, the level will be lower but not running out at all. If run out to expose air then leak somewhere.............
amc49 is offline
