Serious Problem, Spark Plug piece fell into my Cylinder - Page 3 - Focus Fanatics
Old 07-21-2013, 10:12 PM   #21
tylerdetox
Fan#: 109283
What I Drive: 2001 Ford Focus ZTS
FF Reputation: 1 tylerdetox Good Standing Member
Update:
Knocking is Gone, I took it for a drive; Have Full power still and no CEL.
I consider my self Lucky, but its too early to say.
to anyone who ever has this problem. Try the Vacuum Trick, if not try using a bore scope and getting it with small pliers or tape on a hose... Anything before having to take the Head off, although I would of took the Head off, but I had no Gasket, and all stores were closed but that would of been the Last Resort.
I would never Recommend to just 'try it' and hope for the best...
When I started it for the first time, It was idling ruff, and I thought it was done. Eventually after what felt like Minutes, the Knocking Stopped and it was idling normal. Thank you all for your help!
On the bright side, i also changed my oil and I Fixed my Speedometer by replacing the Speed Sensor in the Transmission.
But thank you everyone!
tylerdetox is offline
Old 07-22-2013, 08:02 AM   #22
tylerdetox
Fan#: 109283
So I have one last question,
What kind of damage would it of done? And what should I look for. Its not burning oil, no smoke.
And although the knock is pretty much gone (still has a faint knock), could it still be in there?
Or should I just not worry about it?
Just want to make sure I'm good.
Thanks!
Old 07-22-2013, 11:31 AM   #23
CJ148941
Fan#: 115820
What I Drive: 2011 Black SE, 2.0L 5 spd
FF Reputation: 1 CJ148941 Good Standing Member
The ceramic will just bounce around if your lucky. But it will still cause damage by scratching cylinder walls, similar to putting a piece of broken glass in your mouth it will cut "scratch" you everywhere. Worse case it will get stuck between a valve causing it to stay open, when your piston comes up it will bend and possibly break the valve. Your knocking may be the valve hitting the piston. Some damage has already been done I would suggest looking into engine and get it out before it completely degrades your engine.
CJ148941 is offline
Old 07-22-2013, 11:39 AM   #24
Paul R
Fan#: 116744
What I Drive: 2013 Focus ST
FF Reputation: 1 Paul R Good Standing Member
Watch to see if you have any oil consumption issues as that would indicate that the rings or cylinder walls were damaged allowing oil blow-by. A key indicator of severe damage would be smoky exhaust.
-Paul
Paul in Sunny Orlando, FL
2013 Focus ST
Tuxedo Black ST3
Paul R is offline
Old 07-22-2013, 12:07 PM   #25
amc49
Fan#: 96610
FF Reputation: 23 amc49 Great Standing Member
Poor poor car. The knock tells you everything. Lack of patience and ability again leaps to the forefront. Could've rolled engine to where valves were all shut and repeatedly fired compressed air jet in cylinder with piston maybe 1/2" down to eventually have piece end up in center where it could be seen and grabbed with claw grabber tool. Or maybe punched lightly with small punch into smaller pieces and then blasted out with air again.
Cylinder wall not your problem there, rather the piston, it's aluminum and far weaker than the iron walls are. The knocking probably the piston decks getting smashed with dents. The piston edge if impacted is now damaged and a chunk of ring land will always have the chance of coming loose. You should look at the SPI piston damage when a valve seat lets go, this won't be as bad but could still easily be as fatal. Pistons in some ways are just as brittle as the plug ceramic.
Every spark plug on earth can break like this, there is no difference in quality at all in the ceramic, the difference is leaning sideways on the socket, or not using proper center foam insert socket.
amc49 is offline
Old 07-22-2013, 12:26 PM   #26
CotyM
CotyM's Avatar
Fan#: 85558
What I Drive: blue, y2k, 5spd ZX3, zetec inside
FF Reputation: 3 CotyM Good Standing Member
...Well it's obviously built ford tough I guess...
Hatch Nation #32
I'm mad! Your mad! We're all mad here!
CotyM is offline
Old 07-22-2013, 12:43 PM   #27
tylerdetox
Fan#: 109283
So how long would I have until I start noticing ? And ill post a video of the knock / tick Later tonight
Old 07-22-2013, 03:56 PM   #28
JPFocus86
JPFocus86's Avatar
Fan#: 115084
What I Drive: 2005 InfraRed ZX4 ST
FF Reputation: 1 JPFocus86 Good Standing Member
You definitely pounded the ceramic pieces into the piston/cylinder head. I'd give it a month. You could always take the head off and look for yourself though to see if the damage was significant
Previous: CD Silver 2000 ZTS 5-speed
Current: InfraRed 2005 ST
SR #279
JPFocus86 is online now
Old 07-22-2013, 04:19 PM   #29
tylerdetox
Fan#: 109283
Alright, so in a month I'll either blow my engine or start seeing signs. Any chance i wont? I will upload a video of my engine , and will take my head off when I get time next week to do so.
Old 07-22-2013, 04:35 PM   #30
stephenellis
Fan#: 114094
What I Drive: 2010 Silver Focus Sport
FF Reputation: 1 stephenellis Good Standing Member
Unlikley, you will at least notice your car drinking oil like hell. Keep an eye on it or you really will sieze your engine, almost literally welding your pistons to the cylinder. Not pretty or cheap!
Sent from my GT-I9300 using FF Mobile
stephenellis is offline
