GR347WH173N0R7H's Focus Sport (30k mi to 0 mi) - Page 7 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-19-2013, 09:11 PM   #61
sanford12
sanford12's Avatar
Fan#: 116365
What I Drive: 2012 Focus Titanium
FF Reputation: 1 sanford12 Good Standing Member
Changing the shredded tires for the stock ones makes one think multiple hole shots or some autocross or even drifting. All the parts you removed were to increase output. You can't tell me you didn't use it in a way unintended for street use on more than one occasion. I know I would have as well as anyone else here. But just because you did abuse it doesn't mean it didn't have a defective part you may have just found it sooner.
FoMoCo cars I've owned
1970 429 Cyclone, 1978 LTD II 302, 1980 Fiesta 2nd best Ford I've owned
1986 Tempo LX, 1990 Areostar,1996 Areostar Best vehicle I've ever owned
2005 Ford 500, 2006 Freestyle, 2012 Focus Titanium pearl white
sanford12 is offline
Old 07-19-2013, 09:27 PM   #62
Tjrommel
Tjrommel's Avatar
Fan#: 114674
What I Drive: 2013 Oxford white Sedan 5M
Points 1,588, Level 22
Points: 1,588, Level: 22 Points: 1,588, Level: 22 Points: 1,588, Level: 22
Level Up 88% Completed
Level up: 88% Level up: 88% Level up: 88%
FF Reputation: 1 Tjrommel Good Standing Member
@op, you run 87 octane? My theory is you were driving on 93 and filled up on 87 out of nowhere and comp delayed on timing retardation causing detonation issues blowing a valve off its seats?
Tjrommel is offline
Old 07-19-2013, 09:50 PM   #63
mp223
Fan#: 104161
What I Drive: 2012 Focus SEL
Points 160, Level 3
Points: 160, Level: 3 Points: 160, Level: 3 Points: 160, Level: 3
Level Up 20% Completed
FF Reputation: 0 mp223 Newbie
Originally Posted by GR34TWHI73N0RTH View Post
Read the thread i posted a few pages ago how it happened. You come one here assuming and going on the offensive but you clearly haven't read the whole thing...
Nah, you said what happened, you blew your main bearing. If you were my grandmother who just drives to church every Sunday I'd believe you when you said "it just happened." 50% worn clutch on 30k miles, lol, right buddy.
But it's obvious as hell you're hard on your car (shredded tires, really?) so abuse is what I'm gonna call it. So what did you do? Run it low on oil? Rev the piss outta it on a cold startup a bunch? I bet your tach has seen red-line more than a handful of times...
mp223 is online now
Old 07-19-2013, 10:11 PM   #64
Deftmetal
Moderator
Deftmetal's Avatar
Fan#: 105884
What I Drive: 2014 Mazda 3
Points 6,045, Level 50
Points: 6,045, Level: 50 Points: 6,045, Level: 50 Points: 6,045, Level: 50
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
Forum Activity 4%
FF Reputation: 9 Deftmetal Good Standing Member
I do none of these things except the low oil thing because that's what ford requires me to do and I've had 2 bad engines. Is it not possible to wear out tires in less than 30 000 miles? Personally I've had tires that have been trashed inside of 6000 miles of highway only driving. Given how terrible ford has handled my situation I'm glad that the OP was able to minimize the hassle.
Rally Revolution #14
Josh
Originally Posted by dyn085 View Post
Don't hate on an amputee chick that's still playing with lego's.
Deftmetal is offline
Old 07-22-2013, 01:19 AM   #65
GR34TWHI73N0RTH
GR34TWHI73N0RTH's Avatar
Fan#: 96598
What I Drive: 2012 Black SE Sport 5 Spd
Points 2,141, Level 27
Points: 2,141, Level: 27 Points: 2,141, Level: 27 Points: 2,141, Level: 27
Level Up 94% Completed
FF Reputation: 1 GR34TWHI73N0RTH Good Standing Member
mp223:
I wrote the whole story how it happened on like page 4 again read the whole thread please , i explained everything and your just skipping over and reading what you want to. Again, there were no over rev codes (never red lined, and our car has a rev limiter anyways i was told it should cut out at 7k), shredded tires from salted mountain roads with cables (they tend to kill your tire life + crappy so cal roads = bad tires). Also my oil is changed every 3k with full synthetic (way under recommended with way higher quality oil then recommended) Your clearly not reading now go find another thread; Your not benefiting the conversation. You came in insulting my car (my crappy white wheels remember? guess what buddy until you pay my car bill S.T.F.U) now go away, you have 33 post go find somewhere else to boost your post count.
Sanford12:
Yes i do drive spirited so i probably exacerbated preexisting problem, that is what my hypothesis is at least. The main bearing breaking only is slightly suspicious, if it was due to abuse i would think i would have broken a piston too or at least something else then just a bearing(and then the others when the first failed).
GR34TWHI73N0RTH is offline
Old 07-22-2013, 02:18 AM   #66
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 13,031, Level 74
Points: 13,031, Level: 74 Points: 13,031, Level: 74 Points: 13,031, Level: 74
Level Up 46% Completed
Forum Activity 99%
mp223:
Sanford12:
Ok so the main bearing spun w/ so revs, the rod bearings usallay go first. Look at what takes out 23's= low on oil. Yeah, I don't like the bearing setup on the D-tech/mzr motors w/ no rod or main tangs. I also don't like the press fit for the cams & crank. I guess there setup for production. Just to say, I'd run Mobil1 oil in it.
felixthecat is online now
Old 08-03-2013, 12:14 AM   #67
CunFFS13
CunFFS13's Avatar
Fan#: 117411
What I Drive: 2013 Sterling Gray Ford Focus S MT
Points 2,360, Level 29
Points: 2,360, Level: 29 Points: 2,360, Level: 29 Points: 2,360, Level: 29
Level Up 40% Completed
Forum Activity 15%
Activity: 15% Activity: 15% Activity: 15%
FF Reputation: 6 CunFFS13 Good Standing Member
Glad to read Ford took care of you for free
CunFFS13 is offline
