my rear tires lean more than that tower in piza:) - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-16-2013, 01:57 AM   #1
Vohaul
Fan#: 114465
What I Drive: 2001 dark blue wagon
FF Reputation: 1 Vohaul Good Standing Member
my rear tires..(01 focus wagon) both lean in at the top.enough so you can see it and enough to cause considerable wear on the inside of the tires....yes, i can keep replacing tires, but that doesn't really help long term...
I jacked it up today, and tried to move the tire, thinking bearing etc. nope...tight as anything...also checked springs...nothing broken, as suggested in other posts....so pulled the tire off, and while it is rusty....theres nothing that seems broken or obviously bent....
i snapped a few pictures to see if anyone else can see what could be causing the issue.....couple quick notes...is the upper bar supposed to be curved that much.(it seems pretty similar on the other side and.yes it is rusty.....
anyway....anyone have any ideas.....i really dont want to have to throw used tires at it again just so i can continue my 45 min each way commute...
Thanks
Paul
Vohaul is offline
Old 07-16-2013, 08:25 AM   #2
rambleon84
So mote be it
rambleon84's Avatar
Fan#: 51521
Points 7,742, Level 58
Points: 7,742, Level: 58 Points: 7,742, Level: 58 Points: 7,742, Level: 58
Level Up 96% Completed
Forum Activity 21%
Activity: 21% Activity: 21% Activity: 21%
FF Reputation: 23 rambleon84 Great Standing Member
Buy-Sell-Trade Rating: (15)
Its probably the camber/control arm on your wagon thats at fault. If you can notice the lean, you are probably close to or past -3 and will wear the tires faster. When was the last time you had an alignment? Having your toe out of spec will eat rear wheels as well
See this thread for some more details:
http://www.focusfanatics.com/forum/s....php?p=4792454
rambleon84 is online now
Old 07-16-2013, 12:34 PM   #3
my_beautious_ZX3
Fan#: 32386
What I Drive: 2002 charcoal XZ3
Points 1,342, Level 20
Points: 1,342, Level: 20 Points: 1,342, Level: 20 Points: 1,342, Level: 20
Level Up 43% Completed
FF Reputation: 5 my_beautious_ZX3 Good Standing Member
new LCA's & coil springs fixed my rear camber problems
"I'm jealous of girls because they get to wear dresses." (Todd Flanders)
my_beautious_ZX3 is offline
Old 07-16-2013, 12:40 PM   #4
amc49
Fan#: 96610
Points 3,267, Level 35
Points: 3,267, Level: 35 Points: 3,267, Level: 35 Points: 3,267, Level: 35
Level Up 45% Completed
Level up: 45% Level up: 45% Level up: 45%
Forum Activity 7%
Bushing sag in all the arms do it, you can't expect rubber bushings to avoid that side load forever. ALL rear IRS cars built like that do it, you should look close at Mercedes, VW, and Beemers, Corvettes do it too.
amc49 is offline
Old 07-16-2013, 12:51 PM   #5
Vohaul
Fan#: 114465
ya, so i definetly have the ecessive negative camber problem....
if i got to a wrecker and grab a set of these upper control arms from a 2004 or something...i wonder if that would fix the issue....
(the car is rusty as anything and isnt really worth putting a lot of money into...)
i was kind of afraid to take it to get aligned as im worried theyd find a lot of other crap wrong:)
or do they sell bushing kits...?
Vohaul is offline
Old 07-18-2013, 10:13 PM   #6
Vohaul
Fan#: 114465
so after doing a ton of searching, and reading ...i see that i can get bolts that will help adjust my camber....and that this is a huge focus issue....
My question is this....will it help me to grab a set of newer 2005 or so upper camber arms from a wrecker and replace mine at the same time as the bolts (which i just ordered off ebay)..?
Thanks
Paul
Vohaul is offline
Old 07-19-2013, 11:45 AM   #7
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,775, Level 73
Points: 12,775, Level: 73 Points: 12,775, Level: 73 Points: 12,775, Level: 73
Level Up 82% Completed
Forum Activity 99%
Moved to "Brakes, Suspension & Chassis" for more looks.
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
Old 07-24-2013, 01:42 PM   #8
Vohaul
Fan#: 114465
Thanks
Paul
anyone?
Vohaul is offline
Old 07-24-2013, 08:32 PM   #9
bbcobra
bbcobra's Avatar
Fan#: 88400
What I Drive: 2003 SVT Competition Orange EAP ZX3
Points 430, Level 8
Points: 430, Level: 8 Points: 430, Level: 8 Points: 430, Level: 8
Level Up 60% Completed
FF Reputation: 1 bbcobra Good Standing Member
first get an alignment to see what it actually is. you can have a good amount of negative camber and still get good tire wear if your toe is set as close to 0 as they will set it. Mine has over 1 degree neg. camber and this is easily seen when you look at the car from the rear. but thanks to a good alignment shop, I now have great tire wear. improper toe causes more wear than camber does.
03 SVT Focus, Comp Orange, EAP, Eibach sway bars, H&R Race Springs, Koni Sports, steeda shifter, Massive camber arms, toe links, engine mount bushings, sway bar end links.
other car: 2004 SVT Cobra Coupe, Screaming Yellow, 2.76/2lb lower...
bbcobra is offline
