Mk3 Custom Gauges: HOW TO - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-15-2013, 06:35 PM   #1
jdubhack
I WILL correct you.
jdubhack's Avatar
Fan#: 103056
What I Drive: 2014 SGM Fusion Ti
Points 9,389, Level 65
Points: 9,389, Level: 65 Points: 9,389, Level: 65 Points: 9,389, Level: 65
Level Up 13% Completed
FF Reputation: 37 jdubhack Great Standing Member
Buy-Sell-Trade Rating: (12)
OK. As far as I can tell no-one on the planet that owns an Mk3 Focus has custom gauges installed...except this guy.
I contacted Black Cat Custom after another FF member posted that he had discovered that they were offering custom gauges for the Mk3. I jumped at the opportunity to get some and invited a friend along for the ride.
I custom designed, using their template, a unique gauge face that would compliment our cars and the colors we utilized to personalize and mod those cars.
I'm extremely happy with the communication, professionalism, and the fact that Black Cat Customs put up with me changing something with the design at least 1325 times. No less than that.
After nailing down what we wanted our gauges were made and shipped to us in about 2 weeks.
HOW TO:
The first thing you'll want to do is remove the shroud that is above the steering column. It snaps out pretty easily.
Once that is out you'll remove two torx screws, indicated by the arrows.
You'll hear some scrapping and, quite frankly, it'll sound like your breaking something as you pull out the instrument cluster. You're not.
There is a metal tab that scraps along a plastic ribbed piece, shown in the pictures below. So keep pulling.
The only thing holding the instrument cluster in is the wiring harness. Reach behind and find the latch indicated by the arrow. Pull it to the right and then down. Now pull the harness out.
You'll notice that the there are a bunch of tabs to separate the instrument cluster. Carefully work them from left to right, or if you're daring, right to left.
It'll eventually come apart into 4 pieces as shown.
You'll want to mark the cluster, as shown, in order to preserve your needle position.
Meow - pick a needle and get to work. Carefully grasp the needle and, turning counter-clockwise, pull up. Keep turning and applying upward pressure to remove the needle.
You'll notice two small white tabs holding the gauge face in. Press in on those and remove the face. Insert new one. Simply press the needle down, using the BASE of it, until it is flush.
YOU WILL need to tweak the needles. I kept the plastic "case" off the cluster and plugged the gauges back in and adjusted the needles until they were were they were supposed to be. Fret not young one (or old ) you'll get it.
Once you've got them back to where they need to be. Disconnect the cluster, re-attach the housing, and re-install.
Push it back in, insert the two torx screws, and then snap the shroud back in place. Enjoy.
As always, if you've found this thread helpful, rep a brotha!
PM me for contact details about Black Cat Customs as I'm not sure if posting their information violates any rules.
<>< Gal. 6:14
April 2013 HOTM
2013 Ford Fun Weekend: Show Class Winner
jdubhack is offline
Old 07-15-2013, 06:41 PM   #2
SkyPilot
Jetsetter
SkyPilot's Avatar
Fan#: 22350
Points 13,910, Level 76
Points: 13,910, Level: 76 Points: 13,910, Level: 76 Points: 13,910, Level: 76
Level Up 65% Completed
Forum Activity 8%
FF Reputation: 45 SkyPilot Great Standing Member
Buy-Sell-Trade Rating: (18)
It sounds awesome! Now if your pictures worked...
SkyPilot is offline
Old 07-15-2013, 06:43 PM   #3
jdubhack
I WILL correct you.
jdubhack's Avatar
Fan#: 103056
I'm uploading them separately via Tapatalk. Standby.
<>< Gal. 6:14
April 2013 HOTM
jdubhack is offline
Old 07-15-2013, 06:45 PM   #4
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
What I Drive: 2014 FiST/FoST
Points 26,062, Level 96
Points: 26,062, Level: 96 Points: 26,062, Level: 96 Points: 26,062, Level: 96
Level Up 72% Completed
Forum Activity 58%
Activity: 58% Activity: 58% Activity: 58%
Sweet! Now I can install these-
I like your arrows.
FocusFest 2013: Best of Show
September '13 ROTM
2014 FiST-
dyn085 is online now
Old 07-15-2013, 06:47 PM   #5
SilverPony2001
SilverPony2001's Avatar
Fan#: 27073
What I Drive: 2013 SGM Sedan SE
Points 6,750, Level 53
Points: 6,750, Level: 53 Points: 6,750, Level: 53 Points: 6,750, Level: 53
Level Up 50% Completed
Forum Activity 3%
FF Reputation: 9 SilverPony2001 Good Standing Member
Not sure if this is applicable for the Focus, but when I installed my white faced gauges back in the day on my mustang, I used a dinner fork to pop the needle out. I also took a picture of the needle positions before the install. This allowed me to put the coolant and oil pressure at the correct spot. I then used the "secret diagnostic menu" to display engine speed and RPM to verify my needles where in the correct location.
I would not recommend putting the needles back on while driving, this is very dangerous. But I did it that way anyway with a help of a co pilot.
SilverPony2001 is online now
Old 07-15-2013, 06:50 PM   #6
jdubhack
I WILL correct you.
jdubhack's Avatar
Fan#: 103056
Finally. Pics uploaded.
I should mention that I'm a pretty bold guy, hence the bold gauge faces. Al at Black Cat Customs can do a multitude of colors, like you see above with Duane's.
Both are my design, except Duane is a color Nazi and all "kill all the color things" and went conservative. Both look good, but it goes to show you what can be done.
<>< Gal. 6:14
April 2013 HOTM
jdubhack is offline
Old 07-15-2013, 06:55 PM   #7
jinstall
Deutsche Arsche
jinstall's Avatar
Fan#: 9730
What I Drive: 01 ZX3RACECAR/04 ST170/13 FST2
Points 2,820, Level 32
Points: 2,820, Level: 32 Points: 2,820, Level: 32 Points: 2,820, Level: 32
Level Up 47% Completed
Forum Activity 2%
FF Reputation: 4 jinstall Good Standing Member
Not my thing but cool none the less.
2001 Focus ZX3-Ours IMPOUNDED BY CUSTOMS!!
2010 Renault Clio 1.2 16V in Germany-Hers FOR SALE
2004 SVTF EAP/ST170-Mine
2013 Focus ST2 TS NAV SUNROOF-Hers
jinstall is offline
Old 07-15-2013, 06:59 PM   #8
Bliky
Bliky's Avatar
Fan#: 95135
What I Drive: 2012 Sterling Gray Focus Titanium
Points 3,377, Level 36
Points: 3,377, Level: 36 Points: 3,377, Level: 36 Points: 3,377, Level: 36
Level Up 18% Completed
FF Reputation: 4 Bliky Good Standing Member
Neat. They look cool at night all lit up. I wish there was a way to change the lite blue lights and needles to something else like a darker blue... when/if I ever get some aftermarket gauges they won't match. No idea what color scheme I would get with these either as I doubt a Sterling Grey like color is an option.
'12 Sterling Grey Titanium Hatch - Moonroof / Winter Package / DCT / 17' Alloy Wheels
MK3 Manual Transmission Swap: http://bit.ly/1ondtuV
Bliky is offline
Old 07-15-2013, 07:00 PM   #9
jdubhack
I WILL correct you.
jdubhack's Avatar
Fan#: 103056
These are his colors
This is his site.
<>< Gal. 6:14
April 2013 HOTM
jdubhack is offline
Old 07-15-2013, 07:03 PM   #10
jdubhack
I WILL correct you.
jdubhack's Avatar
Fan#: 103056
For anyone going to FF I'll have my car available to view them along with some business cards that were provided with all the info.
<>< Gal. 6:14
April 2013 HOTM
jdubhack is offline
