Rev Hang - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-15-2013, 05:14 PM   #1
Durany44
Durany44's Avatar
Fan#: 105620
What I Drive: 2014 Mustang GT Premium. Ster Grey
FF Reputation: 1 Durany44 Good Standing Member
Rev Hang
Hello, has anyone else noticed really bad rev hang on their focus? I have a 2009 se coupe and was wondering if there's anyway to eliminate the rev hang, I am tiered of waiting for the revs to go down when I am shifting without the clutch..
Durany44 is offline
Old 07-15-2013, 05:21 PM   #2
#1fordfan
Fan#: 83143
What I Drive: 2005 white se zx4
Points 2,687, Level 31
Points: 2,687, Level: 31 Points: 2,687, Level: 31 Points: 2,687, Level: 31
Level Up 58% Completed
FF Reputation: 4 #1fordfan Good Standing Member
my 2005 5 speed does it too,I was told it's normal and the only way to get rid of it is with a tune.
#1fordfan is offline
Old 07-15-2013, 05:23 PM   #3
Durany44
Durany44's Avatar
Fan#: 105620
I have Toms tunes, so I should just request he eliminates the rev hang?
Durany44 is offline
Old 07-15-2013, 06:46 PM   #4
09vistabluecoupe
09vistabluecoupe's Avatar
Fan#: 67900
What I Drive: 2009 Vista Blue SE coupe
FF Reputation: 2 09vistabluecoupe Good Standing Member
I've figured out a way around it. Double clutch. Say you shift into neutral and you have that annoying as shit rev hanging, simply depress the clutch again and the revs will drop. At least it does in my '09.
SE Coupe 5spd with Sync and Drivers Group.
- FSWerks CAI
- Autolite AR103s
Midwest crew #52
09vistabluecoupe is offline
Old 07-16-2013, 05:27 PM   #5
Durany44
Durany44's Avatar
Fan#: 105620
Well hopefuly a tune will do the trick
Durany44 is offline
Old 07-16-2013, 06:08 PM   #6
09vistabluecoupe
Fan#: 67900
Did you try what I suggested ?
- FSWerks CAI
- Autolite AR103s
Midwest crew #52
Old 07-18-2013, 08:46 PM   #7
Cannont10
Fan#: 80588
What I Drive: 2008 silver se
Points 486, Level 9
Points: 486, Level: 9 Points: 486, Level: 9 Points: 486, Level: 9
Level Up 72% Completed
FF Reputation: 1 Cannont10 Good Standing Member
A tune is only going to help it slightly, the problem is the heavy ass oem flywheel. A light weight aluminum flywheel will make a big difference!
Cannont10 is offline
Old 07-18-2013, 08:51 PM   #8
Durany44
Durany44's Avatar
Fan#: 105620
Vista I tried and it did not work possibly because the custom tune, and cannon, are you sure? How much would it cost to gets light weight flyweel
Durany44 is offline
Old 07-18-2013, 09:11 PM   #9
Cannont10
Fan#: 80588
Points 486, Level 9
Yeah i had the same problem in my 08 got the 93oct tune from fswerks and told them i had bad rev hang they changed some timing in the tune and it slighly fixed it. The stock flywheel is about 22-23lbs the light weight flywheel weighs about 12.5lbs less mass equals less energy required to slow it. It will run you about 375+ shipping and depending on if you install it yourself about 250-300 extra for labor.
Old 07-19-2013, 12:19 AM   #10
BowerR64
BowerR64's Avatar
Fan#: 78699
What I Drive: 2007 ZX3 SE
Points 12,236, Level 72
Points: 12,236, Level: 72 Points: 12,236, Level: 72 Points: 12,236, Level: 72
Level Up 47% Completed
Forum Activity 3%
FF Reputation: 12 BowerR64 Great Standing Member
Couldnt you lower the idle and get it to drop?
When i set my neu-idle rpm and drive-idle rpm to high mine will hang but if i set it really low like 650 it drops like a rock and feels as if its about to stall.
It never stalls because the idle control valve or what ever that thing is opens and keeps it running but i can get it to drop fast by just adjusting the idle settings.
It's not important to win, it's important to make the other guy lose.
BowerR64 is offline
