Vehicle will not stay running unless I give it gas.. - Page 6 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-31-2013, 07:31 PM   #51
amc49
Fan#: 96610
Points 3,274, Level 35
Points: 3,274, Level: 35 Points: 3,274, Level: 35 Points: 3,274, Level: 35
Level Up 50% Completed
Forum Activity 11%
You could if they use same switch mounting.
The point about cutting connector is this. If the junkyard TB was changed for the later 2003 one then you MUST cut the connector, as the later one is different and requires the later 2003 ATX TPS switch which IS available. If you cut for convenience of removing a 2001 part at the junkyard, well, that is not the same thing at all. Or, you still have the old stuff and no ATX TPS available for that one. In short your junkyard trip did nothing at all except drive you crazier.
Ford originally changed the TB because they got a rash of fails with ATX TPS that read too low and caused trouble, note your code. You're there. Why I set the MTX TPS at .9 volts, it gets away from the low volt issue to help. As soon as TPS goes over one volt, the PCM starts signalling to ramp up injectors for increasing load, why if the idle volts are at one volt plus you get all kinds of issues. PCM thinks you are not at idle anymore and screws things up.
You must be b-tchy about setting that voltage at idle, since PCM demands it. Now, if you could get ATX TPS, then it is preset to already do that, but it's not available any more. Thank Ford for that one, and should be enough frustration for you by now to look at another brand next new car time. Simply no excuse for what they did there except greed. The switch could've easily been recalibrated to make ATX switches by the millions. But no, they force you to rebuy a part that has nothing wrong with it to get the one you need. I don't like doing business with companies that do that stuff. To begin with, totally stupid from the getgo to design the TBs with different TPS indexes to begin with, there was no need to use different TBs based on trans type. They should've used same TB and TPS on both transmissions. Or more stupid there.
amc49 is offline
Old 07-31-2013, 07:53 PM   #52
Dmusick
Fan#: 116735
What I Drive: 2001 Ford Focus
FF Reputation: 1 Dmusick Good Standing Member
Ok so this morning at 7am, I went out and removed the junkyard throttle body, the brand new motorcraft TPS for ATX, removed cables. Reinstalled my original TB and got a new TPS for MTX. I did exactly what you did. Modified my TPS, except using a washer I used a heavy duty back strap with 3 holes in it, it was like it was made for back of TPS. Clocked it to .90v at close and it gradually goes up as the throttle opens at all the way open it was around 4.67 or so. I tightened it down.. Put everything back together. Reset battery.. Let car idle for 10mins, then drove around... CAR RUNS PERFECTLY NOW!!! Shifts and downshifts on point, revs and idles like it rolled off show room floor, with 126,00miles on it. :-) AMC49 I cannot thank you and everyone else enough. Thank you thank you for all of y'all's help. DEFANTLY LIKE THEY SAY "A HAPPY WIFE IS A HAPPY LIFE" and all my frustration is gone. For now!! Fingers crossed and hoping for the best. Thank you all again
Dmusick is offline
Old 07-31-2013, 07:57 PM   #53
Dmusick
Fan#: 116735
I also need to add.... All this stress and headache coulda been avoided, if I woulda just did what you said to do in the beginning! Defiantly kicked my own A** on this one. I feel so stupid for not reading better and understanding what you mentioned. THANK YOU AGAIN AMC49
Dmusick is offline
Old 08-01-2013, 06:39 PM   #54
amc49
Fan#: 96610
Forum Activity 11%
Worth every penny as long as you lock it in head for future use. Even if you think you are right always be open at least to other ideas.
I as well do not know nearly everything and often I lurk in/on other sites to pick up ideas. I'm not real original but I can copy and improve on the copy while doing so. Got the TB idea while looking at an aftermarket TB pic one day and realized the difference in the clock positions for different TPS that Ford uses.
Heavy duty backstrap? Hey, you do what you gotta do, if it works. Describe it further, someone else may be able to use it easier than making the specialty washer I made. Idea not hard to understand, I need to get off my butt and learn how to post pics of mine so easier to understand how to do. If you know how don't hesitate to.
amc49 is offline
Old 08-01-2013, 06:42 PM   #55
Dmusick
Fan#: 116735
A hard lesson I need to figure out. My wife calls me "hard headed" I'm beginning to believe her. I will defiantly put pics up, soon as I figure out how too?
Dmusick is offline
Old 08-01-2013, 09:27 PM   #56
amc49
Fan#: 96610
Forum Activity 11%
Believe me, my head is as hard as yours, and many times damaged from banging it into that brick wall.
amc49 is offline
