stuttering after timing belt change!?!? - Page 3 - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Tech Discussions > General Technical Chat
Old 07-16-2013, 03:45 PM   #21
kyle9563
Fan#: 102046
What I Drive: 2000 Silver ZTS
FF Reputation: 1 kyle9563 Good Standing Member
I did replace the fuel filter this morning and the car does seem to idle smoother and I might get new wires anyway because they aren't to expensive.
kyle9563 is offline
Old 07-16-2013, 03:56 PM   #22
ztecpower
ztecpower's Avatar
Fan#: 20083
What I Drive: 2002 Infra-red Ford Focus ZTS-S2
FF Reputation: 5 ztecpower Good Standing Member
When you say "using the correct tools" do you mean the Cam allignment tool and the Pin that you install? You could be off if you only used the cam allignment tool, When ever I did Zetec timing belts I always set TDC with a wooden dowel in cyl#1 and centered it on the "Dead spot" (Where you slightly rotate the crank back and forth and no piston movement is observed) I never had any problems and I've done 4 myself.
If all else fails you can check it by removing all of your spark plugs and turning the crank to TDC, check that the cam allignment tool fits in to the slots on the end of the camshafts. If it doesn't reset your timing, it almost sounds like your 180 out... You usually get intake backfires and a bad misfire but it depends on how far you are out.
Troy. :)
You know... That guy.
SR# eleventybillion
ztecpower is offline
Old 07-16-2013, 04:03 PM   #23
kyle9563
Fan#: 102046
Right tools as in the can allignment bar and metal pin. We even put a screw driver in the first cylinder to see tdc as well just to be safe and the cams lined up so the timing shouldn't be an issue.
kyle9563 is offline
Old 07-16-2013, 04:29 PM   #24
amc49
Fan#: 96610
FF Reputation: 23 amc49 Great Standing Member
It is impossible to be true 180 out on these, the crank and cam sensors re-identify TDC and which TDC position on every crank up of motor. PCM zeroes in on the cam sensor knorb or bump and recalculates for it. Meaning, cams dead straight down are same as dead straight up. Of course, you can screw up by partial amounts in any one of the other degrees between the two.
amc49 is online now
Old 07-17-2013, 12:26 PM   #25
kyle9563
Fan#: 102046
So it's not the plug wires because I put a brand new set on and it's exactly the same. Could it maybe be the coil?
kyle9563 is offline
Old 07-17-2013, 02:03 PM   #26
Insaniac
Insaniac's Avatar
Fan#: 34327
What I Drive: 2003 ZX5 SVT
FF Reputation: 5 Insaniac Good Standing Member
Have you checked for vacuum leaks? If you were raising and lowering the engine to get access to things (serpentine idler pulley usually) its possible a vacuum line got disconnected, pinched, or broken in the process.
2003 ZX5 SVT #1345
CD Silver; Red Interior; Audiophile; Moonroof; HID's
Insaniac is offline
Old 07-17-2013, 02:05 PM   #27
kyle9563
Fan#: 102046
I looked around as best as I could and couldn't see any disconnected hoses but a lot of them are hard to see as they are behind the engine
kyle9563 is offline
Old 07-25-2013, 10:27 PM   #28
kyle9563
Fan#: 102046
So I finally replaced the ignition coil and that's not it either? I'm just completely stumped. I guess I'll have to take it in and see what's what.
kyle9563 is offline
Old 07-25-2013, 11:13 PM   #29
jetrinka
jetrinka's Avatar
Fan#: 45622
What I Drive: 88 5-speed XR4TI
FF Reputation: 180 jetrinka Excellent Standing Member jetrinka Excellent Standing Member
Buy-Sell-Trade Rating: (6)
Who says a power balance test doesn't work? Pulling each plug wire out individually while the car is running is a totally viable way of telling if a cylinder is contributing. If you pull a wire off and the engine runs way rougher than before, you can bet that wire is working and the ignition is contributing like it should. If it doesn't change the way the engine runs when you pull if off, chase that cylinder/plug/wire cause thats your problem.
I can't believe no one has suggested ensuring your timing marks are on. When you put the new belt on did you rotate the engine over (two revolutions of the crank) by hand and make sure that all the marks line up again afterwards? This is the very first step that should have been taken before condemning all sorts of other ignition parts without proper cause.
jetrinka is offline
Old 07-26-2013, 12:12 AM   #30
kyle9563
Fan#: 102046
Ya, when we put the belt back on we made sure to rotate the engine atleast 2 times and everything still lined up just fine.
kyle9563 is offline
