stuttering after timing belt change!?!? - Page 2 - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Tech Discussions > General Technical Chat
Old 07-15-2013, 12:48 PM   #11
amc49
Fan#: 96610
Points 3,093, Level 34
Points: 3,093, Level: 34 Points: 3,093, Level: 34 Points: 3,093, Level: 34
Level Up 29% Completed
Level up: 29% Level up: 29% Level up: 29%
Forum Activity 57%
Activity: 57% Activity: 57% Activity: 57%
FF Reputation: 25 amc49 Great Standing Member
X2,
'Think it out, if car didn't do it before, then you caused it, gotta get your head around that.'
Still applies. Car either did it before or didn't and your path seems pretty clear.
If you view testing wires as too difficult and new part is easier than that, then by all means go there.
You still have not confirmed whether you did the belt for the problem, or the problem now mentioned happened AFTER the belt done. You could be tilting your responses toward totally incorrect. Being vague on internet car repair only hurts you, not us. Now you're wanting to go to fuel lines or injector, with no solid evidence at all. Dangerous unless you are made of money.
amc49 is online now
Old 07-15-2013, 01:38 PM   #12
kyle9563
Fan#: 102046
What I Drive: 2000 Silver ZTS
FF Reputation: 1 kyle9563 Good Standing Member
Sorry for the lack of info but the problem arose after the belt change. I only said it may be in the fuel system because i was just trying to brain storm and see if that sounded like it might be a problem, also i said fuel because a while back I was running with the fuel light on for probably to long and my fuel filter got clogged up and ran somewhat similar to how it is now but not exactly the same. For the vom test what setting should the meter be on? I think its ohms but im not sure and also what numbers should i be looking for?
kyle9563 is offline
Old 07-15-2013, 03:33 PM   #13
amc49
Fan#: 96610
Forum Activity 57%
Ohms, low as possible. No more than 5000 ohms per foot of wire length is a good number to adhere to. You'll have some resistance since it's carbon string conductor but going over that number means the carbon has fallen apart inside cable.
amc49 is online now
Old 07-15-2013, 06:57 PM   #14
kyle9563
Fan#: 102046
Alright thanks for the info. I'll try and test the wires tonight after work and I'll post the results.
kyle9563 is offline
Old 07-15-2013, 10:25 PM   #15
duc450
duc450's Avatar
Fan#: 10651
What I Drive: 2004 Ford Focus SVT CD Silver
FF Reputation: 4 duc450 Good Standing Member
Did you ever test the wires for resistance like everyone has said? If so what numbers did you come up with?
"If you ain't moving fast enough your costing me money and if your costing me money you ain't moving fast enough." -"The Machine"-
duc450 is offline
Old 07-16-2013, 12:19 AM   #16
kyle9563
Fan#: 102046
Well if I read the meter right (it's analogue and kinda old) cylinders 3 and 4 which are on the drivers side we about .25-.3 ohms while cylinders 1 and 2 were around 1.5 ohms. #1 was slightly higher than #2 tho but maybe that's just a difference in wire length. Also today while driving home from work I was turning left doing about 10mph in 2nd gear slowly accelerating and I heard a loud pop and my engine died. I tried to restart the engine and it took a little longer than usual to start and after driving for a few more seconds there was another pop like the first one but had no effect on rpm and I could feel any jolt or bump from it or the first. Could the pops be backfires? Also I don't remember if I've said this already but the whole problem occurs only when I'm accelerating or when I depress the gas pedal in or out of gear (like a rev). But say I'm driving at 45 mph in 5th the problem seams to go away. Also seams to go away when accelerating hard at over 3500 rpm. One ladt thing, im kind of rambling now but I'm trying to get as many details in as I can. So when the car has been sitting for awhile say a few hours the first time going up through the gears is just about uneventful but as soon as I have been driving fir more than about 30 seconds and try and accelerate again the car starts jolting and shutting like the rest if the time.
kyle9563 is offline
Old 07-16-2013, 01:04 AM   #17
kyle9563
Fan#: 102046
Another question. What happens when a car runs to lean or to rich and what could be the cause of something like that?
kyle9563 is offline
Old 07-16-2013, 01:07 PM   #18
amc49
Fan#: 96610
Forum Activity 57%
Pull plugs, if black, fouling misfire to backfire.
You haven't read meter right. Don't toss it, analog VOMs can do things digital can't, like test crank and cam sensors or other types of proximity sensors.
amc49 is online now
Old 07-16-2013, 04:35 PM   #19
kyle9563
Fan#: 102046
We checked the plugs before and they all looked ok, not black and no cracks . How do I test those other proximity sensors, and if they were bad wouldnt they throw a code?
kyle9563 is offline
Old 07-16-2013, 04:43 PM   #20
amc49
Fan#: 96610
Forum Activity 57%
Was just saying tool useful for other things. Crank and cam sensors most likely OK, car will not start without them.
amc49 is online now
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Cadillac ATS-V, Ford Fusion and Acura TLX. You can find all Ford Focus and Focus ST related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
