SVTF rear coil over problems - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-14-2013, 11:29 AM   #1
CharlieO
Fan#: 100963
What I Drive: 2003 Black Svt
FF Reputation: 1 CharlieO Good Standing Member
So i installed my front coil overs no problem but i can get the rear shock out and then none of the bolts to get the spring come out and i cant compress the spring cause my spring compressor wont fit. Can someone leave me a run threw and possibly pictures to make sure im doing it right cause to me all the major bolts are threw some form of a link that is slring compressed and snap back to place after a 1/4 turn.
CharlieO is offline
Old 07-15-2013, 10:15 AM   #2
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,394, Level 75
Points: 13,394, Level: 75 Points: 13,394, Level: 75 Points: 13,394, Level: 75
Level Up 36% Completed
Forum Activity 99%
Once the shock is off, levering down the arm as much as you can & prying out the spring should work (careful!).
Did that to remove stock, compressors fit JUST enough to get SVT springs in.
Center type compressor would be the proper way, but hard to find since it's a spring tool that doesn't work on struts.
Luck!
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is offline
Old 07-16-2013, 09:19 AM   #3
rambleon84
So mote be it
rambleon84's Avatar
Fan#: 51521
Points 7,893, Level 59
Points: 7,893, Level: 59 Points: 7,893, Level: 59 Points: 7,893, Level: 59
Level Up 72% Completed
Forum Activity 31%
Activity: 31% Activity: 31% Activity: 31%
FF Reputation: 24 rambleon84 Great Standing Member
Buy-Sell-Trade Rating: (15)
I rented an internal spring compressor from autozone or advance (just call and ask before heading up there, make sure they know you are asking for an internal variety) but I had to use a large impact socket in order to compress it enough. Although, I dont recommend that to be safe, so be extremely careful and never have it pointed towards you. Otherwise order some new control arms and cut the bolt/sleeve out and replace.
This style
with this added between the washers
You can also try buying one of these style internal compressors, it might work better/safer?
Amazon sells both varieties
rambleon84 is offline
