Larger oil filter? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-14-2013, 01:29 AM   #1
Stic-o
Stic-o's Avatar
Fan#: 110855
What I Drive: 2010 Focus SES Coupe
FF Reputation: 1 Stic-o Good Standing Member
Larger oil filter?
So in changing the oil today in the focus I noticed the filter had about the same size fitting as a old ford V8 or some V6's. Since I had a one sitting around I tried my FL1A and it screwed right on. It looks like there is a support ribs that may need a bit of grinding just to be safe, but other then that should work fine. It would be great to be able to use that other half quart of oil at oil changes and just buy one filter for at least two of my cars.
Question is, I know I can't be the only one thinking of this, so who has done this, and what are the pluses and minus.
The Commuter ~ '10 Focus SES
The Mall Crawler ~'06 Explorer XLT
The Tow Rig ~ '01 F-250 Crew Lariet 4x4
The Off-Roader ~'99 Explorer XL 4x4
Stic-o is offline
Old 07-14-2013, 02:51 AM   #2
mashore81
Fan#: 105575
What I Drive: 03 Pitch Black Sedan PZEV
FF Reputation: 1 mashore81 Good Standing Member
IIRC the ranger 2.3 filter is larger and a direct fit.
mashore81 is offline
Old 07-14-2013, 07:29 AM   #3
mtnbkr
Fan#: 116275
What I Drive: 2013 Performance Blue Hatchback 5sp
Points 202, Level 4
Points: 202, Level: 4 Points: 202, Level: 4 Points: 202, Level: 4
Level Up 4% Completed
FF Reputation: 1 mtnbkr Good Standing Member
I haven't done this on the Focus, but I've used larger filters on other vehicles. I've never noticed an issue. The extra capacity can't be bad IMO. As long as it's not narrower or wider than the stock filter and isn't so long that it interferes with something else, I'd go for it.
I'm running a filter nearly 2x larger (longer) in my 1997 4Runner, and have been doing so for several years. My OCI are 5k miles and I run Mobil1 synthetic 10w-30. The truck has 207k miles and fires right up every day (or did when it was my DD prior to getting the Focus, now it mostly sits).
Chris
mtnbkr is offline
Old 07-14-2013, 10:00 AM   #4
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 13,802, Level 76
Points: 13,802, Level: 76 Points: 13,802, Level: 76 Points: 13,802, Level: 76
Level Up 38% Completed
Forum Activity 100%
Activity: 100% Activity: 100% Activity: 100%
The oil filter mount hangs down vertical & a long filter hangs down pretty low. Hit a curb or something & that'll take out the filter. I've seen it done before working in a body shop. I use a FL842= shorter then the fl400 & a tad bit longer then the fl910, but wider like the fl1a. It'd be great to have the filter mount horizon, to use a filter like the fl1a.
felixthecat is offline
Old 07-14-2013, 01:33 PM   #5
#1fordfan
Fan#: 83143
What I Drive: 2005 white se zx4
Points 2,701, Level 31
Points: 2,701, Level: 31 Points: 2,701, Level: 31 Points: 2,701, Level: 31
Level Up 68% Completed
FF Reputation: 4 #1fordfan Good Standing Member
this would work if you are serious about a bigger oil filter. http://www.focusfanatics.com/forum/showthread.php?t=238252 I considered it a couple weeks ago when I changed my oil,but didn't have time to wait for it to get here,so just went with the stock size bosch.
#1fordfan is offline
Old 07-14-2013, 01:53 PM   #6
Stic-o
Stic-o's Avatar
Fan#: 110855
2.3 uses a fl1a... or at least my old '96 ranger did. My '99 explorer uses it.
Stic-o is offline
Old 07-14-2013, 06:58 PM   #7
#1fordfan
Fan#: 83143
Not sure weather it is true or not,but when I was researching a bigger filter,someone mentioned the FL1A but said it wouldn't fit because of the webbing on the engine block. also I would think it would hang down WAYYY to far and be in danger of being ripped off if you hit something with it.
Old 07-14-2013, 09:59 PM   #8
felixthecat
w/ my magic bag
Fan#: 80663
Forum Activity 100%
Try a FL842
Old 08-05-2013, 09:40 PM   #9
GreySkorpion
saved from the grave
GreySkorpion's Avatar
Fan#: 94674
Points 6,225, Level 51
Points: 6,225, Level: 51 Points: 6,225, Level: 51 Points: 6,225, Level: 51
FF Reputation: 11 GreySkorpion Great Standing Member
The regular 910s seems to work fine, my oil is always clean after 5K
GreySkorpion is offline
Old 08-06-2013, 01:20 PM   #10
felixthecat
w/ my magic bag
Fan#: 80663
Forum Activity 100%
Yeah, thats the stock size. FL400 are the same but longer & the FL842 is shorter then the 400 & has a bigger diameter.
