OEM Ti lights hazing/clouding. Who else has noted problems? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
View Poll Results: How are your headlights?
No 3M/original bulbs/no problems 22 50.00%
No 3M/original bulbs/problems 8 18.18%
No 3M/new bulbs/no problems 6 13.64%
No 3M/new bulbs/problems 5 11.36%
3M/original bulbs/no problems 1 2.27%
3M/original bulbs/problems 1 2.27%
3M/new bulbs/no problems 0 0%
3M/new bulbs/problems 1 2.27%
Voters: 44. You may not vote on this poll
Old 07-13-2013, 03:11 PM   #1
Twenty
Sonic's Mk3 Crew #17
Twenty's Avatar
Fan#: 90312
What I Drive: 2012 YB SE sedan w/ ST exterior
Points 22,454, Level 93
Points: 22,454, Level: 93 Points: 22,454, Level: 93 Points: 22,454, Level: 93
Level Up 11% Completed
Forum Activity 11%
FF Reputation: 10 Twenty Great Standing Member
Recently (the past couple of months) I have noted an issue with the headlights on my Focus. The lenses seem to be clouding/hazing near the parking lights and it's getting rather noticeable. Please note this does not refer to moisture. This is the lens being affected.
My managers and I were wondering if it was the 3M on top getting damaged, or the lights themselves. Yesterday the 3M was peeled off and it was confirmed it is indeed the lights. I'm looking into warranty replacements (the headlights are under a year old) but I'm trying to find the cause of the problem first.
The parking lights sit fairly close to the lens so we figure heat from them is doing the damage. However, I'm not sure if it's due to the lights, 3M, or both. While the lights have been on the car for not even 10 months, they have had 3M almost since day one and have had stealth parking lights; normal bulbs coated in a translucent silver coating to hide the amber. I want to find out what specific item (or perhaps both) is causing the issue.
If you are noting problems with clouding or similar, have replaced bulbs, and/or have wrapped your lights in 3M, please respond to the poll so we can hopefully determine what caused this!
officialTHREETWENTY
2012 YB Focus SE Sedan [featured in Performance Ford, Sept '14]
1992 BW Grand Prix SE Sedan [restomod project]
SR#74/SMk3C#17/YBOC#03
Bill M.
Twenty is offline
Old 07-13-2013, 05:42 PM   #2
Vince
Vince's Avatar
Fan#: 115058
What I Drive: 2012, Black Tit X
FF Reputation: 1 Vince Good Standing Member
Are yoy saying there is cloud ing on tue ibside of the lenses?
If I understand right, I would say the seal of the headlight is broken, and damp is getting in.
I don't understand what the '3M' you talk about is, as I only believe it to be a brand/make of poducts.
Regards,
Vince
Vince is offline
Old 07-13-2013, 06:16 PM   #3
Twenty
Twenty's Avatar
Fan#: 90312
Forum Activity 11%
The clouding is definitely not moisture; the lens is losing its clarity and getting a hazy look. Both lights are affected in the area by the parking lights and nowhere else.
By 3M I am referring to the 3M clear bra, often used to protect paint. My headlights were wrapped with it as well to avoid rock damage in winter.
officialTHREETWENTY
Bill M.
Twenty is offline
Old 07-13-2013, 06:45 PM   #4
Vince
Vince's Avatar
Fan#: 115058
I see what you mean, have you spoken to the people that applied the 3M? Or is it the manager you speak of.
Ive had a food search and cant find anything, only thing I can of it Heat from your headlights melting the film. But being designed to be on headlights, 3M would of definitely thought of that. Its sn odd one forsure.
Regards,
Vince
Vince is offline
Old 07-13-2013, 06:48 PM   #5
Twenty
Twenty's Avatar
Fan#: 90312
Forum Activity 11%
Regards,
Vince
The 3M was applied by my coworkers and I last year. It wasn't the film being damaged though. I've added the photos to the original post now to show the problem; they show the headlights without the 3M since it was peeled off yesterday.
officialTHREETWENTY
Bill M.
Twenty is offline
Old 07-13-2013, 07:15 PM   #6
Vince
Vince's Avatar
Fan#: 115058
Does look odd, im not sure on the cause, but you should be able to polish them up fairy easy.
Regards,
Vince
Vince is offline
Old 07-13-2013, 09:49 PM   #7
GoldenHour
GoldenHour's Avatar
Fan#: 103427
What I Drive: 2014 Tuxedo Black ST
Points 1,148, Level 18
Points: 1,148, Level: 18 Points: 1,148, Level: 18 Points: 1,148, Level: 18
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
Forum Activity 2%
FF Reputation: 3 GoldenHour Good Standing Member
so in trying to protect from rock damage you incurred heat damage?
GoldenHour is offline
Old 07-13-2013, 09:54 PM   #8
1slofofo
Adam
1slofofo's Avatar
Fan#: 92422
What I Drive: Mk3
Points 4,596, Level 43
Points: 4,596, Level: 43 Points: 4,596, Level: 43 Points: 4,596, Level: 43
Level Up 23% Completed
FF Reputation: 6 1slofofo Good Standing Member
I don't have the Ti, I have stock bulbs, and the chrome stock ones, and they do look slightly cloudy, I'll have to see exactly what part it was, but it wasn't moisture. It looked like it was the lens.
Avant Garde M310 18x8.5 Satin Silver. Engine Cover w/ Sonic Blue Accents. Sonic Blue Door Grabs. KW V1 Coilovers. OEM Titanium Headlights. OEM Replica Spoiler. K&N Air Filter.
1slofofo is offline
Old 07-13-2013, 10:39 PM   #9
Twenty
Twenty's Avatar
Fan#: 90312
Forum Activity 11%
Regards,
Vince
Unfortunately it's on the inside of the lens, so polishing it out of the question.
Essentially, yes. It could be from the lights being too hot somehow, the 3M holding the heat in, or both. I have noticed that even original, unwrapped lights can get warm.
In the same place? That's odd. This could be a factory issue then and not related entirely to other factors.
officialTHREETWENTY
Bill M.
Twenty is offline
Old 07-13-2013, 11:43 PM   #10
cobie56
Fan#: 84403
I have seen clouding of many headlight lenses over the years, ESP with cars left in the sun a lot. I keep mine well waxed and have never had an issue with this for any car I have owned. Just good luck? Who knows? I will, however continue to wax them
cobie56 is offline
