How old is your AEM wideband? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-13-2013, 06:31 AM   #1
BowerR64
BowerR64's Avatar
Fan#: 78699
What I Drive: 2007 ZX3 SE
Points 12,323, Level 72
Points: 12,323, Level: 72 Points: 12,323, Level: 72 Points: 12,323, Level: 72
Level Up 69% Completed
Forum Activity 5%
FF Reputation: 12 BowerR64 Great Standing Member
I think mine is starting to fail, when i first got it mine use to run pretty consistantly at 14.7-15 now at times it will drop down to 10 and just hang there. It seems very sporadic like its starting to fail or go bad.
Maybe the O2 sensor has a limit on how long it will last? maybe it needs cleaned? or MAF sensor cleaned?
It's not important to win, it's important to make the other guy lose.
BowerR64 is offline
Old 07-13-2013, 07:14 AM   #2
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 140,700, Level 100
Points: 140,700, Level: 100 Points: 140,700, Level: 100 Points: 140,700, Level: 100
Level Up 0% Completed
Forum Activity 50%
Activity: 50% Activity: 50% Activity: 50%
FF Reputation: 50 sleepyboy Excellent Standing Member
Buy-Sell-Trade Rating: (11)
Don't clean it you'll damage it. Are you sure you not just running really rich? If you think it's going out then you can always get a replacement one. When it does that do you notice the car running different? What are you doing when it happens?
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is online now
Old 07-13-2013, 07:19 AM   #3
Mike_Mac
Mike_Mac's Avatar
Fan#: 61110
What I Drive: 04 Red/Black ZX5, 14 SE hatch
Points 2,400, Level 29
Points: 2,400, Level: 29 Points: 2,400, Level: 29 Points: 2,400, Level: 29
Level Up 67% Completed
Forum Activity 2%
FF Reputation: 12 Mike_Mac Great Standing Member
Buy-Sell-Trade Rating: (8)
i have had mine for around 5 years no issues. if anythings going bad its the sensor itself which i think is ~$80 maybe less.
you could trying cleaning for MAF with electrical contact or MAF cleaner. but like sleepyboy said don't clean the O2 you will kill it.
Mike_Mac is offline
Old 07-13-2013, 03:01 PM   #4
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,915, Level 87
Points: 18,915, Level: 87 Points: 18,915, Level: 87 Points: 18,915, Level: 87
Level Up 13% Completed
Forum Activity 10%
Buy-Sell-Trade Rating: (4)
http://www.aemelectronics.com/Images...%2030-4100.pdf
iminhell is offline
Old 07-13-2013, 05:25 PM   #5
ZXthrizzle05
TURBO ZX3
ZXthrizzle05's Avatar
Fan#: 24434
What I Drive: 2012 Mazdaspeed 3, TURBO ZX3
Points 51,036, Level 100
Points: 51,036, Level: 100 Points: 51,036, Level: 100 Points: 51,036, Level: 100
Forum Activity 2%
FF Reputation: 6 ZXthrizzle05 Good Standing Member
yep good for a while.
FF MODERATOR
RISE AGAIN EGGYOLK302 WHP 274 WTQ ZETEC CREW #271
RIFF CREW
ZXthrizzle05 is offline
Old 07-13-2013, 08:48 PM   #6
BowerR64
BowerR64's Avatar
Fan#: 78699
Forum Activity 5%
Originally Posted by iminhell View Post
What page am i looking at?
I have not done anything out of the normal. It worked fine for the first year or so lately its been acting up and i havnt touched it.
The reason im asking is because i havnt touched any part of the wideband since i installed it. I have however changed the intake manifold.
BowerR64 is offline
Old 07-14-2013, 01:07 PM   #7
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Forum Activity 10%
Read the whole thing, ain't that much there.
Things you should notice,
- Output is heat dependent
- Output is susceptible to moisture and fuel contamination
- Output is susceptible to harness corrosion
- Average life is said to be 70,000km (it's actually hours but)
Best bet is to compare it to your STFT's and see if it looks like it's correct or wrong.
iminhell is offline
Old 07-14-2013, 06:23 PM   #8
BowerR64
BowerR64's Avatar
Fan#: 78699
Forum Activity 5%
Ill have to check it out the nex time im under my car.
Its been on my car since i installed it and i just drive around with it on and working even though i havnt needed it since the last tune Tom did about 2 years ago. I think ive only put about 15,000 miles on it since
Last summer was when i noticed the first signs of it flaking out, we had a REALLY hot summer.
I didnt think mine would run any hotter or have any more issues with placement then any one else though.
Can you tell from this if its not reading correctly? Pink is throttle position, brown is car speed.
What i do is start logging, then a few seconds after i start the car, let idle for about a minute drive then pull over and again let idle for a minute.
Im not even sure what that is telling me.
BowerR64 is offline
Old 07-14-2013, 09:04 PM   #9
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Forum Activity 10%
I'll assume the blue'ish are WBO2 and STFT; which being the case, I see no issue with the sensor.
I do think Ignition Timing should be looked at though.
Ya'know, if you haven't had Tom look over a log for 2 years ...
iminhell is offline
Old 07-14-2013, 09:27 PM   #10
BowerR64
BowerR64's Avatar
Fan#: 78699
Forum Activity 5%
How often should you have it looked at? I havnt even thought about that.
I have the item highlighted under each chart what each one is darkened. It shows min-max and average.
If i have a sensor or a selinoid go bad or plugged in wrong will it show on a log? I still have a engine code P2004 but im not sure where to start. Plugs, the diaphram bell thing that move the actual arm or a vacuum line. Everything looks right but i havnt had a few of them plugged in or hooked up in a while so i forgot wich plugs went to what. I thought they all had their own plug type so you couldnt plug the wrong thing into the wrong sensor but maybe not.
BowerR64 is offline
