rear drum brakes - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-14-2013, 04:21 PM   #11
CJ148941
Fan#: 115820
What I Drive: 2011 Black SE, 2.0L 5 spd
FF Reputation: 1 CJ148941 Good Standing Member
Didn't think of the lugs it might be a 5 lug due to bigger wheels, but since the studs are made into the drum when you remove the drum you remove the studs. New rotors should come with new studs also.
CJ148941 is offline
Old 07-14-2013, 07:43 PM   #12
mpalmer91
Fan#: 74582
What I Drive: 2003 Twilight Blue Sedan - 2.3L
Points 293, Level 5
Points: 293, Level: 5 Points: 293, Level: 5 Points: 293, Level: 5
Level Up 86% Completed
FF Reputation: 2 mpalmer91 Good Standing Member
Buy-Sell-Trade Rating: (7)
Fawzie13R, I believe your drum setup is very similar to mine. On the rear of your drums there are 4 bolts you have to remove to completely take the drum off. There are also two spot welds that must be drilled out. There should be one weld between the top two bolts and one weld between the bottom two bolts.
I would suggest doing a bit more reading before investing in parts. I remember reading somewhere on these forums that those 4 bolts on the 08 and up might be slightly larger than 07 and earlier. Based on that, I am not completely sure an earlier year disc setup is a direct bolt on, without drilling and rethreading those holes.
Hope this helps, good luck.
MTX-75 swapped, Exedy OEM clutch kit, 05 front brakes, VF Engineering mounts, tint, fog lights, cosworth cai, custom 2.5" exhaust, focussport upper stress bar, ground control/koni yellow coilovers, more to come
mpalmer91 is offline
