Non-Ford Audio Question- '07 Subaru Impreza - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-11-2013, 03:26 PM   #1
bringler26
FUBARCUS
bringler26's Avatar
Fan#: 59705
What I Drive: 03 ZX3 & 07 Impreza 2.5i
Points 9,434, Level 65
Points: 9,434, Level: 65 Points: 9,434, Level: 65 Points: 9,434, Level: 65
Level Up 28% Completed
Forum Activity 7%
Does anyone have experience with 06-07 Subaru Imprezas? I'm considering doing some upgrades on my factory speakers and was trying to figure out a plan of attack/what to expect in the process.
2007 Subaru Impreza 2.5i - current DD
I always moderate naked!
bringler26 is offline
Old 07-11-2013, 04:43 PM   #2
freemind
Vince your Moderator
freemind's Avatar
Fan#: 67513
Points 6,774, Level 54
Points: 6,774, Level: 54 Points: 6,774, Level: 54 Points: 6,774, Level: 54
Level Up 12% Completed
Forum Activity 49%
Buy-Sell-Trade Rating: (23)
It shouldn't be much different than most cars.
Goals?
Hatch Nation #140
Caeci caecos ducentes
freemind is offline
Old 07-11-2013, 09:14 PM   #3
oritpro
oritpro's Avatar
Fan#: 96148
What I Drive: 2012 Subaru Impreza Sport Limited
Points 749, Level 14
Points: 749, Level: 14 Points: 749, Level: 14 Points: 749, Level: 14
Level Up 49% Completed
FF Reputation: 2 oritpro Good Standing Member
I plan on upgrading the over-sized clock radio speakers in my Subie at the end of the month. Crutchfield is a good resource and can recommend which speakers will fit, just go to their web site and add your vehicle. It shouldn't be much different on a Subaru than any other car.
oritpro is offline
Old 07-12-2013, 09:22 AM   #4
bringler26
FUBARCUS
bringler26's Avatar
Fan#: 59705
Forum Activity 7%
I was reading about it and even cructhfield gives a warning "some modification may be required" when choosing speakers.
Old 07-12-2013, 09:50 AM   #5
Kipp
FocusFest Event Team
Kipp's Avatar
Fan#: 31300
What I Drive: 2013 F150 4x4 5.0, 2014 HD 883 Iron
Points 4,517, Level 42
Points: 4,517, Level: 42 Points: 4,517, Level: 42 Points: 4,517, Level: 42
Level Up 84% Completed
FF Reputation: 9 Kipp Good Standing Member
it's been a while since i worked in a shop so my memory is a little weak now. but there are several import cars (honda, toyota. . .) that may need some trimming, rivets drilled, or plates made in order to put in aftermarket speakers (especially if they have large magnets). nothing that can't be handled if you have the time, patience and resources to take care of it. make sure you take your time taking off the door panels so you don't break anything. i'm sure you're aware subarus are built around the drivetrain, so the interior isn't the most refined vehicle and can be a little brittle on some. good luck with it and have fun!
2013 F150 4x4 SCrew XLT 5.0L
Midwest Crew #22
Official FocusFest Event Planner
Kipp is offline
Old 07-12-2013, 10:02 AM   #6
bringler26
FUBARCUS
bringler26's Avatar
Fan#: 59705
Forum Activity 7%
Thanks! From what I can tell the rear doors if trimmed properly will accept a 5-1/4" speaker with less work than trying to install replacement whimpy 4" speakers that it comes with. I'm going to have to use a hole saw to make the new tweeter fit in factory location(like the clean look) and trim the door panel plastic to fit the woofer in the front. I've done speakers before but it was removed old install new no mods needed. Hopefully this won't be to crazy hard.
Old 07-12-2013, 10:10 AM   #7
Kipp
Kipp's Avatar
Fan#: 31300
shouldn't be too bad. just make sure you test fit everything and remember to measure twice and cut once.
Midwest Crew #22
Kipp is offline
Old 07-12-2013, 10:50 AM   #8
bringler26
FUBARCUS
bringler26's Avatar
Fan#: 59705
Forum Activity 7%
I'll keep this updated. Next after this might be building a small sub enclosure to tuck into the trunk. I don't know if I want to spend that much. I may consider adding some extra deadening material to the doors if I have the panels off anyway. Do it once not three times, more likely to break the plastic bits.
Old 07-13-2013, 10:31 PM   #9
bringler26
FUBARCUS
bringler26's Avatar
Fan#: 59705
Forum Activity 7%
Found a site that sells spacers/brackets that should smooth things out!
