rear sway bar, choice ??? - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-10-2013, 04:09 PM   #11
Juicedz
Juicedz's Avatar
Fan#: 108814
What I Drive: 2013 Ford Focus Hatchback SE, 5sp
Points 2,372, Level 29
Points: 2,372, Level: 29 Points: 2,372, Level: 29 Points: 2,372, Level: 29
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
FF Reputation: 3 Juicedz Good Standing Member
How much is the whiteline running? I would suggest that due to the solid bar design versus a hollow body. Solid is the way to go although I'm not sure what sort've forces this car actually places on the sway bar. It may be so negligible that it doesn't really matter which bar you go with. The only down side to the solid bar is it's going to add a little more weight.
'13 Oxford White Hatch 5-speed
injected 93 tune, steeda intake, e-focus rmm
Hatch Nation#24 172whp 157wtq
Juicedz is offline
Old 07-10-2013, 04:29 PM   #12
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Points 1,277, Level 19
Level Up 77% Completed
Torsional strength to weight ratio of a tube is much higher than a solid bar. The handling with the tubular Steeda is neutral, and doesn't need to be any stiffer than it is, IMO, or excessive oversteer will be the result. It is already two times the stiffness of the stock bar. To provide the same handling effect with a solid bar, the bar will need to be much heavier than Steeda's tube.
Hatch Nation #90
TboneZX3 is offline
Old 07-10-2013, 04:30 PM   #13
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
duplicate...
Hatch Nation #90
TboneZX3 is offline
Old 07-10-2013, 06:11 PM   #14
Juicedz
Juicedz's Avatar
Fan#: 108814
Here's a good thread on it over at pro-touring. com http://www.pro-touring.com/showthrea...Solid-Sway-Bar
It gets a little carried away at the end...lol. Typical of forums though. I guess I'm just leery of this happening
Juicedz is offline
Old 07-10-2013, 07:15 PM   #15
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
I haven't read the thread yet, but it's obvious to me that the swaybar pictured above was cracked LONG before that picture was taken. Also, the attachment points look extremely cheezy (thin and stamped ends, vs. thick, welded ones) compared to the Steeda bar. If a manufacturer cuts corners in one aspect, he will probably cut them in others... (material, finish, corrosion resistance, heat-treating, etc.)
Also, that's a swaybar on an AWD, and therefore has to control more weight transfer than the rear bar on a Focus. I'll take a well-made, tubular rear swaybar on the rear of the Focus any day over a solid one.
Hatch Nation #90
TboneZX3 is offline
Old 07-10-2013, 07:26 PM   #16
rick47
rick47's Avatar
Fan#: 85994
What I Drive: 2012, silver, SEL
Points 221, Level 4
Points: 221, Level: 4 Points: 221, Level: 4 Points: 221, Level: 4
Level Up 43% Completed
FF Reputation: 1 rick47 Good Standing Member
Thanks for info !!!
rick47 is offline
Old 07-10-2013, 07:44 PM   #17
Deftmetal
Moderator
Deftmetal's Avatar
Fan#: 105884
What I Drive: 2014 Mazda 3
Points 6,045, Level 50
Points: 6,045, Level: 50 Points: 6,045, Level: 50 Points: 6,045, Level: 50
Forum Activity 4%
FF Reputation: 9 Deftmetal Good Standing Member
I have the 24mm whiteline. I had it on the "soft" setting and it was great. With the whiteline you either need new end links or you need to drill out the holes in the bar.
Rally Revolution #14
Josh
Originally Posted by dyn085 View Post
Don't hate on an amputee chick that's still playing with lego's.
Deftmetal is offline
Old 07-10-2013, 08:09 PM   #18
Seminoles
Seminoles's Avatar
Fan#: 98405
What I Drive: 2012 SGM SE Sedan
Points 969, Level 16
Level Up 69% Completed
Forum Activity 2%
FF Reputation: 1 Seminoles Good Standing Member
All the pictures of hollow bars I saw on here and the link look like something off my kids swing set unless my glass are really dirty....
Seminoles is offline
Old 07-10-2013, 08:36 PM   #19
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
I agree with that, regarding the link above. What a POS.
However...
Take a look at the pics at this link. (clean your glasses first)
http://www.steedafocus.com/parts/201...-rear-swaybar/
Look at that solid link tab and the weld around it and tell me it looks like a swing set part. Surely you will agree that there is no comparison to the pics above. Also, Steeda uses stock end links, so I don't believe there's a question of durability there.
Hatch Nation #90
TboneZX3 is offline
Old 07-10-2013, 09:46 PM   #20
Seminoles
Seminoles's Avatar
Fan#: 98405
Forum Activity 2%
Yes no comparison and chrome moly steel too you can see in the crack it on the broken ones they weren't.
