Poor handling in the rain - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-09-2013, 08:14 PM   #1
coyotehunter
Fan#: 87972
What I Drive: 2003 blue zx3
FF Reputation: 1 coyotehunter Good Standing Member
My 03 zx3 has to be the worst car I've ever had to drive in the rain. I put new front tires on and it only helped slightly. I'm also in the process of replacing shocks/struts, ball joints, tie rod ends and all the bushings with poly and then get a 4 wheel alignment done. Would there be anything else I need to look at to get it over 55 without feeling like I'm just a passenger in the car? If after this is all done and it still is crap in the rain it's going the way of the dodo bird. I don't want to but I can't have it only as a dry weather car when it's my dd.
coyotehunter is offline
Old 07-09-2013, 08:19 PM   #2
SD.Norm
SD.Norm's Avatar
Fan#: 68980
What I Drive: 2013 Tangerine Scream Focus ST
Points 1,537, Level 22
Points: 1,537, Level: 22 Points: 1,537, Level: 22 Points: 1,537, Level: 22
Level Up 37% Completed
Level up: 37% Level up: 37% Level up: 37%
FF Reputation: 1 SD.Norm Good Standing Member
What tires are they are most likely the cause
Sent from my Nexus 4 using FF Mobile
"We are now shifting from 5th gear into top gear!"
Build Number #1135
SD.Norm is offline
Old 07-09-2013, 08:21 PM   #3
NeoDecker
NeoDecker's Avatar
Fan#: 103476
What I Drive: 2012 Ingot Silver Focus S Sedan
Points 23, Level 1
Points: 23, Level: 1 Points: 23, Level: 1 Points: 23, Level: 1
Level Up 45% Completed
Level up: 45% Level up: 45% Level up: 45%
FF Reputation: 1 NeoDecker Good Standing Member
As I'm not exactly sure what the car is doing. Just off the top of my head I'd say Tires.
2012 Ford Focus S Sedan
1997 Ford Ranger XLT
Sedan Revolution# 254
NeoDecker is offline
Old 07-09-2013, 08:28 PM   #4
TheGlassMaker
REVOLT.BUILD.RISE
TheGlassMaker's Avatar
Fan#: 69510
Points 36,770, Level 100
Points: 36,770, Level: 100 Points: 36,770, Level: 100 Points: 36,770, Level: 100
Level Up 0% Completed
My focus has bad toe issues in the rear, its kinda common for focus to have rear toe issues. It causes the rear of the car to feel "loose" and fishtail in the snow and rain. A proper alignment should fix the issue.
TheGlassMaker is offline
Old 07-09-2013, 08:28 PM   #5
coyotehunter
Fan#: 87972
I had multi brands when I got it. Put the best on the back and 2 mastercraft on the front. When I drive on the highway the car will lose traction up front and I can see the tach rev up. When its real bad(?) it wonders in the rain hence the feeling like I'm just a passenger. And I'm not flying down the highway either. Speed limit only in the rain and sometimes slower.
Old 07-09-2013, 08:32 PM   #6
coyotehunter
Fan#: 87972
I know I have other issues in the rear suspension and I'm hoping it will all go away after I blow the boy's college money on the car. I'm just making sure I have everything covered as I cannot do all of this again. Thanks everyone with the suggestions so far. It is appreciated muchly.
