2001 Focus Not Start - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-09-2013, 04:47 PM   #1
MikeD83
Fan#: 116572
What I Drive: 2001 Ford Focus Black
FF Reputation: 1 MikeD83 Good Standing Member
Went to leave work the other day turned the key and nothing happened. Turned it again and the car started. Got home and then had to leave again went out and it wouldn't start again. Tried jumping the battery first nothing happened. There is an audible click from the engine compartment(loud) but the started wasn't turning. Replace the ignition relay still nothing. Went to the starter next removed it and brought it to advance auto to have it tested the said it was bad. Replaced the starter still the same thing, loud audible click from engine compartment. Unsure where to go next I am wondering if the alternator is shot? Any advice would be appreciated.
MikeD83 is offline
Old 07-09-2013, 05:11 PM   #2
Gav-O-SVT
I Like Red
Gav-O-SVT's Avatar
Fan#: 113561
What I Drive: '02 Infra-Red SVT
Points 3,502, Level 37
Points: 3,502, Level: 37 Points: 3,502, Level: 37 Points: 3,502, Level: 37
Level Up 2% Completed
Forum Activity 99%
FF Reputation: 6 Gav-O-SVT Good Standing Member
Take your alternator out and have it tested, that could very well be your problem. If it is good then you might have a short somewhere. My best bet is that your alternator is starting to crap out on you, mine just went out last week and cost me almost $200... The alt was not charging my batt and the car was starting to sputter, like if you were about to run out of gas but luckly I was close to home and made it back but when i tried to roll up my window, nothing happened. My batt was drained and the alt was making just enough juice to bairly keep the car running. I turned it off and tried to start it back up and nothing happened, completely dead. So yeah, get your alternator tested, depending on the age of your batt, you might want to replace that too. Good luck!
Gav-O-SVT is offline
Old 07-09-2013, 05:16 PM   #3
Gav-O-SVT
I Like Red
Gav-O-SVT's Avatar
Fan#: 113561
Forum Activity 99%
I have a question for you, did your battery light ever come on just before this happened, I noticed that my batt light came on and thats when my car started to act up, indicates a problem with the charging system. You might have not noticed it but if it did then like I said, your alternator is prob shot. When you take it to get it tested, have your battery checked as well just to be safe. Best of luck to ya.
Old 07-09-2013, 05:25 PM   #4
MikeD83
Fan#: 116572
Thanks guys ill get the alternator checked next then. Didn't notice a battery light but just checked it is on when the key is turned over after the rest of the dash light go out. The battery is fairly new. Funny though that the starter tested bad as well.
MikeD83 is offline
Old 07-09-2013, 06:10 PM   #5
crazy_urn
Capt. Urn
crazy_urn's Avatar
Fan#: 1986
What I Drive: 77 F-250, 10 HHR, 08 Outlook
FF Reputation: 5 crazy_urn Good Standing Member
The starter may have been good enough to start the car, but not to pass the test... Quite possible with 12 year old parts....
If you find the alt is bad, make sure you have the battery tested after it is replaced. as Gav-O pointed out, dying alternators can be hell on batteries, even new ones.
By the way, what engine do you have in your focus?
I don't know about the zetec, but on the SPI the alt. is a real easy swap. hardest part is getting the accessory belt on at the end. Might be a good idea to check your belt tensioner while you have the belt off.
Defending the reputation of the red-headed step-child of the focus world for far too long.
crazy_urn is offline
Old 07-09-2013, 06:33 PM   #6
MikeD83
Fan#: 116572
I have the zetec engine, alternator is pretty easy to get to. I'll get it taken off tomorrow, hope its the alternator I really don't feel like dealing with a short somewhere.
MikeD83 is offline
Old 07-09-2013, 07:27 PM   #7
UnbridledCarnage
Rhinoliner!!!
UnbridledCarnage's Avatar
Fan#: 66551
What I Drive: 03 Rhinoliner'd ZX3 AdvanceTrac
Points 16,266, Level 81
Points: 16,266, Level: 81 Points: 16,266, Level: 81 Points: 16,266, Level: 81
Level Up 84% Completed
FF Reputation: 9 UnbridledCarnage Good Standing Member
moving ya to tech chat for more help
If your local to the 502, 270, 812, 606, 859 area, check out FocusXtreme, the Ohio Valley chapter of FF. Monthly meets and kickass people! Join and POST UP!!!
UnbridledCarnage is offline
Old 07-16-2013, 12:35 AM   #8
MikeD83
Fan#: 116572
2001 Ford Focus 16v Zetec No Start Continued...
Posted last week sometime and got some good advice on where to start. Replaced the ignition relay, starter, and alternator. Car still will not turn over. The key turns, and all I get is one click from the engine compartment. Looking for some more advice on what could be causing this. Thanks.
MikeD83 is offline
Old 07-16-2013, 01:30 PM   #9
amc49
Fan#: 96610
Points 3,368, Level 36
Points: 3,368, Level: 36 Points: 3,368, Level: 36 Points: 3,368, Level: 36
Level Up 12% Completed
Forum Activity 49%
Power supply to starter, or, cable condition. Probably what it was all along...........need to check main engine ground too.
I see nothing still of battery load tested. I replaced plenty of crap batteries that failed in less than a year, often with people who insisted on buying the too cheap (less CCA) battery. You play, you pay................Battery needs load test at correct CCA. Could easily cause that. In heat like now our battery replacements went up like 400%.
amc49 is offline
Old 07-19-2013, 10:36 AM   #10
MikeD83
Fan#: 116572
Just had the battery load tested like you suggested amc49 CCA is at 666 and running at 12.7 volts. Started checking the wiring to starter and I will check the ground as well.
MikeD83 is offline
