05 blower fan and resister question - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-07-2013, 09:15 PM   #1
ricknelson88
Fan#: 116507
What I Drive: tan 05 focus
FF Reputation: 1 ricknelson88 Good Standing Member
I'm having an issue with my blower working on all speeds for roughly 30 seconds and then it slowly peters out. If you wait a little bit it will start again and then do the same. I have replaced the blower and the resister.
ricknelson88 is offline
Old 07-08-2013, 05:08 AM   #2
MEJY1988
Fan#: 101883
What I Drive: 2006 Burgandy ZX5
Points 163, Level 3
Points: 163, Level: 3 Points: 163, Level: 3 Points: 163, Level: 3
Level Up 26% Completed
FF Reputation: 3 MEJY1988 Good Standing Member
Did you check the wiring plug where it plugs into the resistor pack? They have been known to burn-up with the resistor pack. I would also check the one that plugs into the blower motor and switch.
I was a Shade Tree Mechanic, but had to cut down the Shade Tree to make room for the garage. Does this make me a Mechanic now?
MEJY1988 is offline
Old 07-09-2013, 08:39 AM   #3
ricknelson88
Fan#: 116507
Yes I looked at it and it seems to look good. Tonight I think ill run a ground to the blower case. But I am sure up for any suggestions. Thanks.
Old 07-09-2013, 06:07 PM   #4
MEJY1988
Fan#: 101883
Points 163, Level 3
IIRC the fan is feed hot thru a fuse/relay and picks up the negative/ground is feed thru the switch and resistor pack.
MEJY1988 is offline
Old 07-12-2013, 10:45 PM   #5
RICK1TIMER
Fan#: 26087
FF Reputation: 1 RICK1TIMER Good Standing Member
I'm having the EXACT same problem. So far I just changed the resister so i guess i'll look elsewhere before changing the blower motor. If it was the fuse it would not work intermittently? there is a red plastic in the resister connector with NO discoloration??? I did smell a burning smell while trying to keep the fan going by continuing to turn fan on and off. I just don't get why it works for a minute or two and then slows to not blowing??? HELP
RICK1TIMER is offline
Old 07-13-2013, 09:56 AM   #6
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,314, Level 75
Points: 13,314, Level: 75 Points: 13,314, Level: 75 Points: 13,314, Level: 75
Level Up 16% Completed
Level up: 16% Level up: 16% Level up: 16%
Forum Activity 99%
First step for YOUR issue from the description would be to remove the blower motor, clean out any debris, check that it spins freely, then power it up with jumper leads from a battery & see how it runs by itself.
Without testing, it's all guessing, and that can cost $ without solving anything.
Luck!
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
Old 07-14-2013, 03:24 PM   #7
RICK1TIMER
Fan#: 26087
OK fixed mine... ended up being the blower motor. Here are the final steps i took.
1. Unplugged the connecter from the blower motor.
2. Turned ignition to run and and tested the current at connecter in all five fan speeds. 4=12.3, 3-1 were all less than the previous (as it should be coming through the resister.)
Because the fan was working in all fan positions and then stopping, I was concerned it was some thing other then the motor. So...
3. Plugged the motor back up and tested the blower as it went through its it's symptomatic run then fail after a minute or two. There was no change in current as the motor died.
4. Removed the blower motor and connected directly to the batter with some test leads. (Removing all other components in the circuit.) The motor failed after running for a few minutes just as it had while in the circuit. BAD MOTOR.
Bought a new one problem solved! The motor running and then cutting off had me second guessing myself and I didn't want to buy parts I didn't need.
Thanks All... the site had some great input.
