How To Install Led Trunk Light - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus First Generation > MK1 Interior Mods & Upgrades
Old 07-07-2013, 05:16 PM   #1
jayboe123
jayboe123's Avatar
Fan#: 106032
What I Drive: 2007 Liquid Grey ZX4
Points 2,744, Level 31
Points: 2,744, Level: 31 Points: 2,744, Level: 31 Points: 2,744, Level: 31
Level Up 96% Completed
FF Reputation: 1 jayboe123 Good Standing Member
If you are like me and think that replacing the factory bulb just is not light enough. and you have leds on the interior this makes everything look great for show and function.
I saw there was no how to for this install and figured it would help anyone trying to do this.
* this uses the factory trunk light so when you open the trunk the light comes on and closing turns it off
Duration: 45 minutes
Tools:
Wire strippers
Electrical Tape
Zip ties
flexible LED strip color your choice (key word flexible!!)
factory replacement bulb is optional
jayboe123 is online now
Old 07-07-2013, 05:18 PM   #2
jayboe123
jayboe123's Avatar
Fan#: 106032
first off get the factory bulb out of the white case and remove the black wire holders in the trunk.
these are the replacement bulbs I used price about 4 dollars autozone
Old 07-07-2013, 05:20 PM   #3
jayboe123
jayboe123's Avatar
Fan#: 106032
These are the flexible led strips i only used one since one was bright enough
Old 07-07-2013, 05:21 PM   #4
jayboe123
jayboe123's Avatar
Fan#: 106032
strip back the electrical tape to reveal orange wire and black wire not sure of the stripes on each color varies per years
Old 07-07-2013, 05:23 PM   #5
jayboe123
jayboe123's Avatar
Fan#: 106032
strip back the wiring and dont cut the wires or let them touch because they have 12 volts running through them the trunk is open..
Old 07-07-2013, 05:26 PM   #6
jayboe123
jayboe123's Avatar
Fan#: 106032
I used the orange wire as positive and black as negative after testing them always test the wires for correctness..
Then i Military spliced into each wire by separating the wire of each and running the wires for the leds through each one respectively, negative to negative positive to positive!!
Then twist the wires around the factory wiring so they are secure
Old 07-07-2013, 05:28 PM   #7
jayboe123
jayboe123's Avatar
Fan#: 106032
* once connected the lights will turn on this is ok the trunk is open
- when doing this the lights eventually turn off like factory if they do just close the trunk and open it again theyll turn back on
Old 07-07-2013, 05:29 PM   #8
jayboe123
jayboe123's Avatar
Fan#: 106032
tape up the wires and ziptie them for strength like so
Old 07-07-2013, 05:30 PM   #9
jayboe123
jayboe123's Avatar
Fan#: 106032
also put in the replacement bulb if you like or have one
Old 07-07-2013, 05:31 PM   #10
jayboe123
jayboe123's Avatar
Fan#: 106032
I ran the wiring through the left side behind the carpet
