How to Disable DRL's on 2000 SE - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-06-2013, 09:14 PM   #1
xX BRADchap5 Xx
Fan#: 116481
What I Drive: 2000 White SE
FF Reputation: 1 xX BRADchap5 Xx Good Standing Member
Well I'm not sure if this is the right place to post this but I am wondering if anybody has attempted and been successful with disabling the DRL's on a 2000 SE model of focus. I know a lot of people say that its illegal and you shouldn't do it, but I am going to the drive-in in a few days and need to start the car but can't have those lights on while its running. Also I'm not sure if it will work with using the parking brake, but mine isn't in a working condition at the moment but if it works that way could I take the wire from it and some how put it on a switch? Pull the R12 relay under the hood? or possibly something inside under the dash I could do? I am hoping to try and do something I can add on a toggle switch but anything will do.
xX BRADchap5 Xx is offline
Old 07-06-2013, 09:28 PM   #2
mix1983
Life Is Good
mix1983's Avatar
Fan#: 61101
What I Drive: 2000 Honda Civic EX 5spd
Points 9,183, Level 64
Points: 9,183, Level: 64 Points: 9,183, Level: 64 Points: 9,183, Level: 64
Level Up 45% Completed
Level up: 45% Level up: 45% Level up: 45%
Forum Activity 7%
FF Reputation: 5 mix1983 Good Standing Member
Pull the fuse. I know my Taurus had a fuse just for DRL.
I'm all about sharing the road with other drivers - as long as they use the part that's behind me.
mix1983 is online now
Old 07-06-2013, 09:30 PM   #3
xX BRADchap5 Xx
Fan#: 116481
Is there a trick to pulling the relays? I figured i would give it a try just because, but i ended up pulling the relay case off instead.
Old 07-06-2013, 09:33 PM   #4
mix1983
Life Is Good
mix1983's Avatar
Fan#: 61101
Forum Activity 7%
Found this with a Google search;
There is both a fuse and a relay in the engine compartment power panel that controls the DRL's. Simply remove either, or both.
You should note that if you are in Canada, the Daytime Running Lights are MANDATORY on all vehicles sold in Canada since 1990, and disabling them may cost you a LOT of money in fines, as it is against Federal law, and the Highway Traffic Acts of most Provinces.
Old 07-07-2013, 09:08 AM   #5
TheGlassMaker
REVOLT.BUILD.RISE
TheGlassMaker's Avatar
Fan#: 69510
Points 36,735, Level 100
Points: 36,735, Level: 100 Points: 36,735, Level: 100 Points: 36,735, Level: 100
Level Up 0% Completed
I would just pull the bulb. I would be afraid the fuse would run some thing else too. Or in the case of my mazda. put in blown bulbs, so the sockets don't sit empty.
TheGlassMaker is offline
Old 07-07-2013, 09:33 AM   #6
ShoOff
ShoOff's Avatar
Fan#: 109590
What I Drive: 2013 Performance Blue SE Hatchback
Points 1,858, Level 25
Points: 1,858, Level: 25 Points: 1,858, Level: 25 Points: 1,858, Level: 25
Level Up 58% Completed
FF Reputation: 16 ShoOff Great Standing Member
Steeda CAI, Steeda STS, Magnaflo Cat Back Exhaust, Injected Tuner, Cobb Rear Motor Mount, TTR Upper Motor Mount, Injected 180 T Stat
ShoOff is offline
Old 07-07-2013, 11:08 PM   #7
zetecDon
Where am I?
zetecDon's Avatar
Fan#: 62506
What I Drive: 02 ZX3, 02 MX-5
Points 13,154, Level 74
Points: 13,154, Level: 74 Points: 13,154, Level: 74 Points: 13,154, Level: 74
Level Up 76% Completed
Level up: 76% Level up: 76% Level up: 76%
Forum Activity 37%
Activity: 37% Activity: 37% Activity: 37%
FF Reputation: 29 zetecDon Great Standing Member
Buy-Sell-Trade Rating: (46)
Moved to "MK1 Focus".
zetecDon is online now
