What size injectors is everyone running - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-06-2013, 07:34 PM   #1
BoostedFord
BoostedFord's Avatar
Fan#: 95085
What I Drive: 2002 Silver ZX3
Points 2,719, Level 31
Points: 2,719, Level: 31 Points: 2,719, Level: 31 Points: 2,719, Level: 31
Level Up 80% Completed
FF Reputation: 2 BoostedFord Good Standing Member
Just seeing what everyones running on there turbo focis im running 42lb green tops but thinking of bumping it up
Focus Revolution
Boosted Zx3 @ 20psi spinnin 327whp
"cant find em grind em"
BoostedFord is offline
Old 07-06-2013, 08:20 PM   #2
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,506, Level 100
Points: 52,506, Level: 100 Points: 52,506, Level: 100 Points: 52,506, Level: 100
Level Up 0% Completed
Forum Activity 61%
Activity: 61% Activity: 61% Activity: 61%
Buy-Sell-Trade Rating: (28)
Whats your power goals ?
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 07-06-2013, 08:24 PM   #3
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,868, Level 87
Points: 18,868, Level: 87 Points: 18,868, Level: 87 Points: 18,868, Level: 87
Level Up 4% Completed
Forum Activity 13%
Buy-Sell-Trade Rating: (4)
I'm running greens and N/A.
BTW, control of the injector is what you should also be looking at. So long as you're able to control it well, there is no injector too big (within reason).
iminhell is offline
Old 07-06-2013, 08:30 PM   #4
BoostedFord
Fan#: 95085
Well im thinking about the sizing for my new motor imma build from top to bottom and be around 400 maybe a lil more
Focus Revolution
Old 07-06-2013, 09:37 PM   #5
ZXthrizzle05
TURBO ZX3
ZXthrizzle05's Avatar
Fan#: 24434
What I Drive: 2012 Mazdaspeed 3, TURBO ZX3
Points 51,036, Level 100
Points: 51,036, Level: 100 Points: 51,036, Level: 100 Points: 51,036, Level: 100
Forum Activity 2%
FF Reputation: 6 ZXthrizzle05 Good Standing Member
Buy-Sell-Trade Rating: (11)
if your building a motor its obvious you don't want low power goals. so might as well use 60# from decca siemens
FF MODERATOR
RISE AGAIN EGGYOLK302 WHP 274 WTQ ZETEC CREW #271
RIFF CREW
ZXthrizzle05 is offline
Old 07-06-2013, 09:44 PM   #6
BoostedFord
Fan#: 95085
Ya ill look into those i was tgink 80lb but if those are good
Focus Revolution
Old 07-06-2013, 11:08 PM   #7
Mother Focus
Mother Focus's Avatar
Fan#: 73292
What I Drive: 2001 Money Pit
Points 4,667, Level 43
Points: 4,667, Level: 43 Points: 4,667, Level: 43 Points: 4,667, Level: 43
Level Up 59% Completed
FF Reputation: 13 Mother Focus Great Standing Member
Buy-Sell-Trade Rating: (9)
60's are enough for pump gas @ 20psi but if you are going for race gas get the 80's.
PTE 6262CEA
Pump Gas 385whp 319wtq
Race Gas 551whp 439wtq
Tuned by Fernando@RacingPartsSolution.com
Mother Focus is offline
Old 07-08-2013, 12:18 AM   #8
paulg127
Fan#: 55998
What I Drive: 2003 Black SVT
Points 3,273, Level 35
Points: 3,273, Level: 35 Points: 3,273, Level: 35 Points: 3,273, Level: 35
Level Up 49% Completed
FF Reputation: 3 paulg127 Good Standing Member
You can calculate fuel requirements for a turbo or NA motor pretty simply using the following equations:
NA = ~.5lb/HP --> 200hp*.5 = 100lb/hr / 4 injs = 25lb/Hr (Stock are 29lb)
Turbo ~.65lb/hp --> 200hp*.65 = 130lb/hr / 4 injs = 32.5lb/Hr
Turbo ~.65lb/hp --> 400hp*.65 = 260lb/hr / 4 injs = 65lb/Hr
Turbo ~.60lb/hp --> 400hp*.60 = 240lb/hr / 4 injs = 60lb/hr
The basis of the calculation is brake specific horsepower (dyno calculated) that is typically .5 lb/Hp for a NA motor. The lower the number, the more efficient the engine is at converting fuel energy to horsepower.
For a turbo motor the BSFC goes up due to the richer requirements to protect the engine from detonation and exhaust cooling. Typically 10.5 to 11:1 AF is about .60 to .65 bsfc, which requires a larger injector to supply the required AF ratio.
Bigger injectors typically don't idle as well, but that can be due to cone angle. Narrow cone angles get most fuel into the cyl without wetting the wall, but at idle a wider cone typically helps idle...
I don't think I would go to 80lb injectors for 400hp, but 60lb's is pretty much at the limit to ensure you can get the AF you need to protect the motor.
Increasing the fuel pressure can help get more flow out of the injector. Typically the injector flow sheets can show you how much you need.
paulg127 is offline
Old 07-08-2013, 12:40 AM   #9
ZXthrizzle05
TURBO ZX3
Fan#: 24434
Forum Activity 2%
well said
FF MODERATOR
RIFF CREW
Old 07-09-2013, 02:13 PM   #10
turbosvtfocus04
turbosvtfocus04's Avatar
Fan#: 100806
What I Drive: 2004 black svt
Points 233, Level 4
Points: 233, Level: 4 Points: 233, Level: 4 Points: 233, Level: 4
Level Up 66% Completed
FF Reputation: 1 turbosvtfocus04 Good Standing Member
^ wrong. For the part that bigger injectors typically have idling issues. If you have a good quality injector and a good tuner you won't have any issues. My setup on stock motor I have 1200cc(114lbs) injectors, I won't have any idling issues.
turbosvtfocus04 is offline
