Well...Damn. First post and I need help - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-06-2013, 06:33 PM   #1
SlickWilly
SlickWilly's Avatar
Fan#: 116476
What I Drive: 2009 Ford Focus SES Sangria Red
Points 5,290, Level 46
Points: 5,290, Level: 46 Points: 5,290, Level: 46 Points: 5,290, Level: 46
Level Up 70% Completed
Forum Activity 15%
Activity: 15% Activity: 15% Activity: 15%
FF Reputation: 6 SlickWilly Good Standing Member
Well I'll do my intro later. Anyways here we go. Stock SES 2009 Focus with the Audiophile/Sync system/Amp/Sub. Well I installed an after market amp today, and well it doesn't produce sound. I tapped into the sub out put to wire in the RCA converter. My amp turns on fine, green light but no sound comes through UNLESS we ground it using a test light. Plugged in RCA's into a different amp in a different car with no issues. If I run a negitive wire from one on my sub out puts and run it to my amp output I'd get sound. Well, still getting nothing and the stock amp is hot as hell.
Amp is a Alpine M400 V12 Power, Sub is a Kicker L7 Solo X 10"
SlickWilly is online now
Old 07-07-2013, 03:29 AM   #2
ViperThreat
Dat boxer rumble
ViperThreat's Avatar
Fan#: 66026
What I Drive: '06 WRX Wagon 285whp/292wtq
Points 7,819, Level 59
Points: 7,819, Level: 59 Points: 7,819, Level: 59 Points: 7,819, Level: 59
Level Up 35% Completed
Level up: 35% Level up: 35% Level up: 35%
Forum Activity 13%
FF Reputation: 9 ViperThreat Good Standing Member
quick check:
•is your amp wired to a dedicated ground and power line? what gauge are they?
•amp signal wire installed?
• are your subs hooked up correctly?
One of the above is most likely the cause.
Moderator For: Socal Fanatics | SVT Focus | Mk1 Focus | Audio & Electronics | General Chat
"Ford Focus ST - the official car of message-board circle-jerks"
-Regular Car Reviews
ViperThreat is offline
Old 07-08-2013, 10:36 AM   #3
SlickWilly
SlickWilly's Avatar
Fan#: 116476
Forum Activity 15%
Pass quick checks...
4 gauge wire all around
Dedicated...
Sub is wired in 2 OHM parallel
Still only works if the speaker channel is grounded.
Switched to a Solo Baric
Old 07-08-2013, 03:11 PM   #4
freemind
Vince your Moderator
freemind's Avatar
Fan#: 67513
Points 6,774, Level 54
Points: 6,774, Level: 54 Points: 6,774, Level: 54 Points: 6,774, Level: 54
Level Up 12% Completed
Forum Activity 49%
Buy-Sell-Trade Rating: (23)
What are you grounded to?
It really sounds like the Alpine has gone Bye bye on you.
Hatch Nation #140
Caeci caecos ducentes
freemind is offline
Old 07-09-2013, 01:02 AM   #5
SlickWilly
SlickWilly's Avatar
Fan#: 116476
Forum Activity 15%
Underneath the trunk mat. Sanded Down brass end
Old 07-09-2013, 01:58 AM   #6
ViperThreat
Dat boxer rumble
Fan#: 66026
Forum Activity 13%
Going to agree with freemind on this one. did you get a volt meter and check the output on the amp?
Most amps have a light to indicate that they are operational. If that light is on and no fuses are popping, then your sub should work. If its not, then you have a bad amp my friend.
Old 07-09-2013, 07:37 PM   #7
freemind
freemind's Avatar
Fan#: 67513
Forum Activity 49%
Brass end? Pics please. You MUST ground to the chassis, seat belt bolt, etc. A solid ground(also called earths)are PARAMOUNT.
Do you own an electrical meter(DMM)?
Hatch Nation #140
freemind is offline
