Sway bar link woes - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-05-2013, 07:59 PM   #1
dodgeguy
dodgeguy's Avatar
Fan#: 85952
What I Drive: 2014 White Focus ST2
Points 578, Level 11
Points: 578, Level: 11 Points: 578, Level: 11 Points: 578, Level: 11
Level Up 56% Completed
FF Reputation: 1 dodgeguy Good Standing Member
Sway bar link woes
So, last year in September, I was excited to finally get rid of the clunk in my front suspension. It turns out that the culprit was the sway bar links. So I replaced both with the site favorite, Moog brand. Wow what a difference. The car handled better. It was quiet. I was happy.
Until last month. I started getting a clunk again from the passenger side. I didn't even look at the sway bar link, since I knew it wasn't that old. Well, it took a while, but I found the noise... the sway bar link. No problem. I had my receipt, and had it warrantied out. Put the new one in, and life was good again. About 2 weeks later I start getting a clunk from the drivers side. I check the link and of course its bad. My brother (a Dodge mechanic) said I should have replaced them both at the same time. Ok. But I didn't. My bad. Tried to warranty the second one, but lost my receipt. I shell out another $35, install the part, and life with the Focus is good again. That was last weekend. On Wednesday, the drivers side is clunking again. Are you Freakin kidding me? I'm too pissed to look at the moment, but willing to bet its the 1 week old drivers side sway bar link.
I will be looking this weekend to see what the problem is.
To be continued...
K&N Air filter, uh - thats it, NO CAI, NO FSWerks, NO Exhaust, NO Coilovers, NO Tune, Nothing
dodgeguy is offline
Old 07-05-2013, 09:17 PM   #2
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,678, Level 86
Points: 18,678, Level: 86 Points: 18,678, Level: 86 Points: 18,678, Level: 86
Level Up 66% Completed
Forum Activity 18%
Buy-Sell-Trade Rating: (4)
Sounds like there's something causing them to go bad.
Could be any number of things, bad alignment, worn bushings, broken spring/s, worn swaybar bushings or loose swaybar.
iminhell is offline
Old 07-08-2013, 05:02 AM   #3
dodgeguy
dodgeguy's Avatar
Fan#: 85952
Upon a quick inspection, it does not appear that the new sway bar link is making the noise. Not positive, but this noise is hard to trace by myself. Going to meet up with my brother later to get some help
dodgeguy is offline
Old 07-08-2013, 08:51 AM   #4
rambleon84
So mote be it
rambleon84's Avatar
Fan#: 51521
Points 7,752, Level 59
Points: 7,752, Level: 59 Points: 7,752, Level: 59 Points: 7,752, Level: 59
Level Up 1% Completed
Level up: 1% Level up: 1% Level up: 1%
Forum Activity 19%
FF Reputation: 23 rambleon84 Great Standing Member
Buy-Sell-Trade Rating: (15)
What brand endlinks are you using? Moog's are well made and only cost $22 from amazon (link.) Just make sure you grease them every once in a while. You shouldnt be going through enlinks that fast unless something else is wrong though. Along with what iminhell mentioned, also check that your sway bar is centered.
I've also havent read about anyone destroying a set of Massive endlinks yet. If you have changed your ride height ever, those will let you dial in perfect fitment.
rambleon84 is online now
Old 07-09-2013, 10:46 PM   #5
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,809, Level 73
Points: 12,809, Level: 73 Points: 12,809, Level: 73 Points: 12,809, Level: 73
Level Up 90% Completed
Forum Activity 99%
Moved to the new "brakes, suspension & chassis" area for ya!
BTW - Attachment bolts getting loose happens fairly often when links replaced, had one new one do that to me. Some add lock washers or switch to nylock nuts depending on what hdwe. came with the new ones...
Luck!
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
