blown motor:( - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-03-2013, 11:23 PM   #1
jwgstang2112
Fan#: 116399
What I Drive: 2004, sonic blue, svt zx5
FF Reputation: 1 jwgstang2112 Good Standing Member
blown motor:(
hello i recently purchased an 04 focus svt with a blown motor and no details on how it happened... but i ran compression checks and no.3 cyl was like at 60 psi while the others were 130-140 psi and i took it apart today the piston in between the rings broke and the rings as well... it burned oil alot so i dont think the oil pump went out.. i was wondering why it went out at 136k miles what can be done to prevent it from happening again, and everything is bone stock.
any help is appriciated
jwgstang2112 is offline
Old 07-03-2013, 11:33 PM   #2
jdmzx5
Fan#: 116056
What I Drive: 2004 Silver Focus ZX5 Svt Eap
FF Reputation: 1 jdmzx5 Good Standing Member
Any evidence of a turbo installation? It was probably driven hard and rings usually break at high rpm. Give more info about the rest of the car and drivetrain, modifications etc. You will get more info. How about some pics too
jdmzx5 is offline
Old 07-03-2013, 11:40 PM   #3
jwgstang2112
Fan#: 116399
idk what i sould look for as far as a turbo instalation and pics are on the way
Old 07-03-2013, 11:42 PM   #4
jwgstang2112
Fan#: 116399
its 100% bone stock it has a 6 speed manual trans and 2.0 its a zx5
Old 07-04-2013, 12:11 AM   #5
jwgstang2112
Fan#: 116399
http://jwgstang2112.tumblr.com/image/54569051720
picture of the piston
Old 07-04-2013, 12:39 AM   #6
jdmzx5
Fan#: 116056
Picture of the cylinder, main bearings, rod bearings and cam caps, also lets see the valve margins and valve seats. Then I can give you probable cause.
jdmzx5 is offline
Old 07-04-2013, 01:05 AM   #7
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 140,700, Level 100
Points: 140,700, Level: 100 Points: 140,700, Level: 100 Points: 140,700, Level: 100
Level Up 0% Completed
Forum Activity 50%
Activity: 50% Activity: 50% Activity: 50%
FF Reputation: 50 sleepyboy Excellent Standing Member
Buy-Sell-Trade Rating: (11)
Some SVT have had the ring lands on the pistons let go. This has happened on boosted and n/a SVT's alike. Why it happens I dunno maybe detonation from bad gas or a bad tune I forget really since this happens every so often. I guess it's like the SPI valve drop problem only no where near as severe. There are SVT's with over 200k mi running around with no problems. Just rebuild it back to stock and you should be fine. You also may want to invest in getting a tune since the factory tune for the SVT sucks. You won't gain very much power but the driveability is greatly improved.
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is online now
Old 07-04-2013, 01:33 AM   #8
jwgstang2112
Fan#: 116399
http://jwgstang2112.tumblr.com/image/54574225546
http://jwgstang2112.tumblr.com/image/54574401076
http://jwgstang2112.tumblr.com/image/54574618748
http://jwgstang2112.tumblr.com/image/54574758166
http://jwgstang2112.tumblr.com/image/54574857781
Old 07-04-2013, 01:35 AM   #9
jwgstang2112
Fan#: 116399
what kind of tune lice sct tuner or...?
Old 07-04-2013, 02:58 AM   #10
SuperStockAMX
Fan#: 89501
What I Drive: 2003 Comp Orange EAP SVT
Points 735, Level 14
Points: 735, Level: 14 Points: 735, Level: 14 Points: 735, Level: 14
Level Up 35% Completed
Level up: 35% Level up: 35% Level up: 35%
FF Reputation: 1 SuperStockAMX Good Standing Member
I'm going through the same process right now. My SVTF leaned out (N/A, 67mm TB, Hi-Flow cat, Tom Tune). The cable that actuates the intake manifold runner was rotted and broke from battery acid and the original 135,000+ mile fuel pump is suspect. Whatever the issue, it leaned out on a top end WOT situation. #3 piston torched the entire north end, #2 piston was cracked 180* from each end of the wrist pin along the skirt. Bearings are perfect.
Nobody makes a forged SVT piston so I'm in the process of having Diamond Pistons make a set. Should be done inside of two weeks from today. I went 85mm which is about .006" over standard. The #3 cylinder had light vertical score that cleaned up with a hone. Going with 1mm top barrel face ring and 1mm napier second ring; both available from Total Seal. Using ARP rod bolts and new Clevite rod bearings even though the rod bearings looked dang near perfect.
Also bought ARP head studs instead of the TTY factory head bolts.
Having the factory cams reground by the guy that cuts my custom race cams for my AMC V-8. See www.redlineracingcams.com if your interested. I don't know the retail cost as I'm getting the buddy deal on the cams.
Replacing the IMRCM and cable, new fuel pump, filter, performance valve job while I'm at it. Finally, Tom Tune from my laptop when it's all together.
Can't wait to take it for a drive with the new parts!
I'll pass on the piston ordering info to Central Florida Motorsports so they can make these a catalog item.
I was absolutely against the zetek 130HP piston / rod conversion. Price wise it's a good deal but I feel the flame travel has to be considerably better with the SVT piston over the zetek piston. Plus I'm able to use considerably better rings with the 1mm / 1mm setup. And the Diamond piston is far superior to the SVT piston.
And then maybe the turbo....
SuperStockAMX is online now
