Fuel Filter and MPG question. - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Second Generation > DURATEC Performance (2008-2011)
DURATEC Performance (2008-2011) The place to chat about any Duratec 20 engine performance, tuning and exhaust related upgrades.
Old 07-03-2013, 12:20 PM   #1
bryanbag
Fan#: 98196
What I Drive: 2010 Silver SE
Points 109, Level 2
Points: 109, Level: 2 Points: 109, Level: 2 Points: 109, Level: 2
Level Up 18% Completed
FF Reputation: 1 bryanbag Good Standing Member
I have a 2010 Focus SE. 2.0L with 63,000 miles.
I brought my car into the dealer to have the oil change, tire rotation and Multipoint inspection done.
I requested the for the fuel filter to be changed out and to check out why fuel mileage drop off from 35 to 28 MPG.
I received the call from the dealer saying my car is ready, OK COOL.
They told me I have a non-serviceable fuel filter, this seamed a little weird since everywhere I look fuel filter are available and say to change every 30,000 to 50,000 miles.
What the deal here, did these car come with a (so called) lifetime fuel filter?
Mileage, they claimed they hooked the car up to there computer and the and ran what ever test to do and it came back as getting 33.2 MPG.
I know a dirty MAF, O2 sensor on it's way out can affect mileage. The MAF will be getting cleaned this weekend and possibly the O2 sensors changed out also.
Now I only drive the car Mon to Fri to work which is 140 miles round trip. The car doesn't get dogged on. That's what my Lightning is for. I set the cruise on 72 and off I go.
I know with the hot weather were having here in South Louisiana can have an effect on MPG but 7MPG is a bit much.
Any added info would be great.
Thanks
Bryan
2010 Focus SE, Bone stock. If any mods were to be done, they would be only to get better MPG.
2000 Lightning, Build #1183, Built on 3/16/2000.
234,000+ miles on original Block, Heads, and Trans an still running strong.
bryanbag is offline
Old 07-05-2013, 11:13 AM   #2
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 12,186, Level 72
Points: 12,186, Level: 72 Points: 12,186, Level: 72 Points: 12,186, Level: 72
Level Up 34% Completed
Forum Activity 99%
FF Reputation: 65 felixthecat Excellent Standing Member
Yeah your fuel filter is in the tank w/ the pump. How 'bout a Steeda sri for more mpg. What kind of mpg do you get going 60mph? You have more wind restance at 70+ then you do at 60.
felixthecat is online now
Old 07-05-2013, 06:47 PM   #3
09vistabluecoupe
09vistabluecoupe's Avatar
Fan#: 67900
What I Drive: 2009 Vista Blue SE coupe
FF Reputation: 2 09vistabluecoupe Good Standing Member
http://www.wikihow.com/Increase-Fuel-Mileage-on-a-Car
Are you going off the computer ? Excessive use of the a/c can put a hamper on mileage, I'm at 83k and with some hypermiling my trip computer is currently sitting at 38mpg (probably going to actually be about 33mpg to the tank). I'm about to go fill up right now, I'll let you know how that goes.
SE Coupe 5spd with Sync and Drivers Group.
- FSWerks CAI
- Autolite AR103s
Midwest crew #52
09vistabluecoupe is offline
Old 07-05-2013, 11:50 PM   #4
felixthecat
w/ my magic bag
Fan#: 80663
Forum Activity 99%
Wow, 38mpg is pretty good. The most I can get is 35 at 70 down the freeway. Is hypermiling shutting the motor off down hills & coasting or what?
Old 07-06-2013, 12:13 PM   #5
09vistabluecoupe
Fan#: 67900
Pretty much all newer engines will shut the fuel injectors off while coasting downhill if you're in gear. But yeah some hypermiling tips are.
Coast back down to a stop, don't slow down as much for turns, keep your tires aired up, don't drive above 45mph with the windows down, use the a/c as little as possible, don't speed (drag increases exponentially with speed), skip shift(get up to speed limit using 1st & 2nd then shift to 4th, or maybe 1-3 then skip to 5th depending on how fast you have to go).
I've got an all time best of 39.4mpg, or almost 500 miles, to a tank before.
- FSWerks CAI
- Autolite AR103s
Midwest crew #52
Old 07-06-2013, 03:16 PM   #6
#1fordfan
Fan#: 83143
What I Drive: 2005 white se zx4
Points 2,597, Level 30
Points: 2,597, Level: 30 Points: 2,597, Level: 30 Points: 2,597, Level: 30
Level Up 98% Completed
FF Reputation: 4 #1fordfan Good Standing Member
well,maybe in may the above 45 mph with windows up would work,but around here you would be sweating if you drove with the windows up after may. I have always wondered at what speed does the drag from the windows down use as much gas as using the A/c? I hardly ever use A/C unless kids are in the car or it is VERY hot(95+).
#1fordfan is offline
Old 07-08-2013, 05:24 PM   #7
crice8
crice8's Avatar
Fan#: 84830
What I Drive: 2010 Sterling Gray Focus SE Sedan
Points 8,390, Level 61
Points: 8,390, Level: 61 Points: 8,390, Level: 61 Points: 8,390, Level: 61
Level Up 80% Completed
FF Reputation: 9 crice8 Good Standing Member
Buy-Sell-Trade Rating: (13)
I may have overlooked it but are you auto or manual? about 43 mph right after the torque convertor lets up will get you awesome mileage around town. Then do the same on the highway. Get it just to where it shifts to the next gear but at the lowest mph. This will keep your RPM in optimal MPG range(= Lighter wheels made the biggest difference for me. Plus all my other mods. If it adds power then it makes it run more efficient(mostly) cai,header,exhaust,tune,etc. will increase MPG's if you drive properly and don't floor it with the new found power.
Galatians 6:14
crice8 is offline
Old 07-08-2013, 05:26 PM   #8
crice8
crice8's Avatar
Fan#: 84830
Best lately is 45mpg at 72mph down the highway for a 54miles stretch of hills and such.
Galatians 6:14
crice8 is offline
Old 07-08-2013, 05:28 PM   #9
crice8
crice8's Avatar
Fan#: 84830
Fuel also makes a big difference. I'm not saying run 93 octane because that is only beneficial if you are tuned for it. But I get noticably better mpgs and power when I use SHELL gas (which is almost always), but if I get gas at wally world or other gas stations where it is a little cheaper I get 4-8mpg less and noticbly less power.
Galatians 6:14
crice8 is offline
Old 07-08-2013, 05:41 PM   #10
#1fordfan
Fan#: 83143
sorry,mine is a manual 5 speed. I ran 93 octane a few tanks last year just as a test,no difference in mpg's. I don't notice a big difference in fuel brands around here,but I do mostly try to use shell. I am averaging 31-32 mpg's which is good,but more is always better!! :)
