Dashes in odometer and car won't start - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-04-2013, 01:20 AM   #11
Mile30
Mile30's Avatar
Fan#: 74686
What I Drive: '03 ZX3
Points 8,150, Level 60
Points: 8,150, Level: 60 Points: 8,150, Level: 60 Points: 8,150, Level: 60
Level Up 40% Completed
Forum Activity 11%
FF Reputation: 7 Mile30 Good Standing Member
Buy-Sell-Trade Rating: (10)
The first two times I had the dashes issue; it was that fuse. It later ended up just "killing" the cluster, while every other electrical system functioned properly.
What I found that was when I first freaked out about this, I REPLACED THE POWER CABLE... unnecessarily as it turned out! I wasn't able to route the cable as it had been when I removed the old one. My friend (an '03 Cobra guy) came by the shop one afternoon and did his "redneck beepy test" and found the bad fuse in 20 seconds. It took longer for him to figure out how to pop the hood.
The inadequate routing I did had placed the power cable to close to the EGR tubes. The main (red) cable had settled against the tube and the casing and original insulation had melted off. A small semi-circular hole had allowed the wire to arc THROUGH A 1mm PINHOLE! That contact was letting the ignition start part of the ignition circuit short-to-power... which blew the 30a Maxi a few times before the blank gauge cluster happened.
"I'm gonna sing the doom song..."
Mile30 is offline
Old 07-04-2013, 01:27 AM   #12
Mile30
Mile30's Avatar
Fan#: 74686
Forum Activity 11%
06-04-2013, 12:00 AM BOOSTED OLDS post #110
The screwdriver is pointing at the gremlin I finally found. I even reran the powe supply wire to the ignition in the column before I went under the hood and found it!
http://www.focusfanatics.com/forum/s...=304719&page=3
I have my post count maxed out, so the page number for you and I may differ.
Mile30 is offline
Old 07-04-2013, 09:56 PM   #13
CFR0628
CFR0628's Avatar
Fan#: 116223
What I Drive: 2003 Silver Ford Focus X3
FF Reputation: 1 CFR0628 Good Standing Member
Its a fuse. I had fun with that problem too.
CFR0628 is offline
Old 07-06-2013, 10:55 AM   #14
zetecfocus
Fan#: 96880
What I Drive: 2000 Silver ZX3
FF Reputation: 1 zetecfocus Good Standing Member
Which fuse?
Was it a fuse located under the hood or under the driver side dash board? Even more exact would be a fuse position number as well? Also, the fuse number or location from both of you will tell me if you both had the same problem. Thanks for the help guys.
zetecfocus is offline
Old 07-10-2013, 08:17 PM   #15
zetecfocus
Fan#: 96880
ALL the fuses look to be intact
So I should check continuity on all fuses and relays then huh? All the fuses visually look good.
Old 07-11-2013, 10:12 AM   #16
Mile30
Mile30's Avatar
Fan#: 74686
Forum Activity 11%
Like I said before:
-multimeter on "continuity" or "beep"
-back probe the underhood fuses, if they beep; keep moving!
-if it's the one I'm thinking of; it's the green 30a maxi fuse for the ignition circuit.
*keep in mind*
If the fuse keeps blowing you need to trace the powers and grounds! That maxi-fuse is just a protection device that's keeping the wiring from getting fried. If that same fuse keeps on being a problem; you've got metal-on-metal contact somewhere along the path. You can keep throwing new parts at it, but it won't stop the problem!
Mine was a chaffed power cable touching an EGR tube for the DPFE... it was intermittent, too. If the wire vibrated close to the metal tube, the little bit of exposed power cable would touch and arc; shorting-to-power and blowing that 30a ignition fuse... yours may be the same or similar, or a completely different spot: but electricity only acts a certain way!
Mile30 is offline
Old 07-15-2013, 01:23 PM   #17
adrst2.3
adrst2.3's Avatar
Fan#: 80621
What I Drive: 07,red,st
Points 3,287, Level 35
Points: 3,287, Level: 35 Points: 3,287, Level: 35 Points: 3,287, Level: 35
Level Up 58% Completed
FF Reputation: 4 adrst2.3 Good Standing Member
Buy-Sell-Trade Rating: (9)
Did you fix your issue?
Hey! I do conversions too!
adrst2.3 is offline
Old 07-25-2013, 12:25 AM   #18
Mile30
Mile30's Avatar
Fan#: 74686
Forum Activity 11%
Right... so?! Make with some details, please!
Mile30 is offline
Old 04-30-2014, 10:48 PM   #19
KnowlandBS
Fan#: 160074
What I Drive: 2000 Ford Focus SE, Blue 2.0L DOHC
FF Reputation: 1 KnowlandBS Good Standing Member
mine keeps blowing fuse #9 a 20amp fuse.
on a 03 Ford Focus SE with an automatic and a 2.0L Zetec DOHC.
replaced the fuse and ran fine for a while, turned it off and then it popped the fuse again.
any idea where that fuse goes to, I mean it won't start turn over or anything and the mileage on the dash goes -----
replaced that fuse and bam fired right up.
if anyone has fixed this issue let me know! thanks!
(I have two ford focus')
a 2000 SE Manual and a 2003 SE Auto.
KnowlandBS is offline
