Dashes in odometer and car won't start - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-03-2013, 11:14 AM   #1
zetecfocus
Fan#: 96880
What I Drive: 2000 Silver ZX3
FF Reputation: 1 zetecfocus Good Standing Member
Please help! I've replaced the battery cables and alternator...mechanic who did a "diagnostic check" deemed it was the battery cables. Please help!
zetecfocus is offline
Old 07-03-2013, 11:25 AM   #2
PumkinSvt
PumkinSvt's Avatar
Fan#: 46561
What I Drive: 10 Forte DD,Comp SVTF, 14 Fiesta ST
Points 16,375, Level 82
Points: 16,375, Level: 82 Points: 16,375, Level: 82 Points: 16,375, Level: 82
Level Up 5% Completed
FF Reputation: 28 PumkinSvt Great Standing Member
Buy-Sell-Trade Rating: (33)
Check the negative side on the battery there is a little wire thats on the big cable it might have ripped off.
HKS||Garrett||TopSpeed||Tial||Massive||
PumkinSvt is offline
Old 07-03-2013, 11:29 AM   #3
justalilslow
Fan#: 59266
What I Drive: 05 gutted hatch
Points 958, Level 16
Points: 958, Level: 16 Points: 958, Level: 16 Points: 958, Level: 16
Level Up 58% Completed
FF Reputation: 3 justalilslow Good Standing Member
Could also be the fuse to the ECU. It should be a huge 20amp under the hood.
I drive a stock-ish 05 gutted hatch, occasionally bottle fed.
justalilslow is offline
Old 07-03-2013, 11:40 AM   #4
zetecfocus
Fan#: 96880
Like I said I just put the new cables on, where does this little cable you're referring to terminate? So it Goes from negative terminal to where in other words?? Do you mean the little ground that bolts to the body right next to the battery? I've checked the fuses quickly, but I will have to pull each one and look carefully.
Old 07-03-2013, 11:43 AM   #5
zetecfocus
Fan#: 96880
I've got power to all the accessories, but the odometer reads "dashes" and I get no cranking, turning over, clicking, nothing... Maybe the ECU itself has went out? Because I've tried to put a code reader on it and it won't connect to the car.
Old 07-03-2013, 11:51 AM   #6
elsolo
elsolo's Avatar
Fan#: 96835
Points 2,622, Level 31
Points: 2,622, Level: 31 Points: 2,622, Level: 31 Points: 2,622, Level: 31
Level Up 15% Completed
Forum Activity 2%
Figure out if the ECU is getting power before deciding it's dead.
elsolo is offline
Old 07-03-2013, 11:58 AM   #7
zetecfocus
Fan#: 96880
Where is the power hold relay? Someone else mentioned it being bad?
Old 07-03-2013, 05:49 PM   #8
Gadabout
Gadabout's Avatar
Fan#: 114774
What I Drive: 2006 Vermillion Red ZX4 SE
Points 1,052, Level 17
Points: 1,052, Level: 17 Points: 1,052, Level: 17 Points: 1,052, Level: 17
Level Up 52% Completed
FF Reputation: 4 Gadabout Good Standing Member
Check the #9 Fuse.
edit: http://www.focusfanatics.com/forum/showthread.php?t=317115
“Things work out best for those who make the best of the way things work out.” - J Wooden
Team Duratec #42
Gadabout is offline
Old 07-03-2013, 11:43 PM   #9
elsolo
elsolo's Avatar
Fan#: 96835
Forum Activity 2%
Fuse #10 by the battery box, it powers the data link and also tee's off to feed 12v to the alternator.
If it is blown, it would explain why the guy thought it needed a battery cable and/or an alternator
elsolo is offline
Old 07-04-2013, 01:11 AM   #10
Mile30
Mile30's Avatar
Fan#: 74686
What I Drive: '03 ZX3
Points 8,132, Level 60
Points: 8,132, Level: 60 Points: 8,132, Level: 60 Points: 8,132, Level: 60
Level Up 91% Completed
Forum Activity 9%
FF Reputation: 7 Mile30 Good Standing Member
Buy-Sell-Trade Rating: (10)
Did you check the 30a ignition fuse under the hood? Mine was doing that earlier this year. Use a multimeter on the continuity setting; check ALL the fuses under the hood, if it doesn't beep: you found your culprit! If it keeps popping, you'll need to trace the wires on that particular circuit to get to the bottom of it.
"I'm gonna sing the doom song..."
Mile30 is online now
