dead idle when running hot - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-03-2013, 01:39 AM   #1
gun7369
Fan#: 113688
What I Drive: 2003 white zx3
FF Reputation: 1 gun7369 Good Standing Member
My 2003 Focus ZX3 is dying at idle when things get hot. Thermostat and Water Pump and everything else is tip top. No overheating issues, but why does the car die at idle? What could cause this? Is it the PCV valve? The car runs like a champ but when it is 90+ F and you drive around town it dies at idle at stoplights,etc.
gun7369 is offline
Old 07-03-2013, 03:13 PM   #2
freemind
Vince your Moderator
freemind's Avatar
Fan#: 67513
Points 6,581, Level 53
Points: 6,581, Level: 53 Points: 6,581, Level: 53 Points: 6,581, Level: 53
Level Up 16% Completed
Level up: 16% Level up: 16% Level up: 16%
Forum Activity 51%
Activity: 51% Activity: 51% Activity: 51%
Buy-Sell-Trade Rating: (23)
You will get a better response here.
Hatch Nation #140
Caeci caecos ducentes
freemind is online now
Old 07-04-2013, 12:48 AM   #3
my_beautious_ZX3
Fan#: 32386
What I Drive: 2002 charcoal XZ3
Points 1,342, Level 20
Points: 1,342, Level: 20 Points: 1,342, Level: 20 Points: 1,342, Level: 20
Level Up 43% Completed
FF Reputation: 5 my_beautious_ZX3 Good Standing Member
warm stall is a common failure mode on old Focii, and the common culprit is a collapsed PCV hose or a dirty/faulty IAC valve. Type those terms into the forum search box and you'll find more info than you care to see.
"I'm jealous of girls because they get to wear dresses." (Todd Flanders)
my_beautious_ZX3 is offline
Old 07-04-2013, 06:22 AM   #4
amc49
Fan#: 96610
Points 3,258, Level 35
Points: 3,258, Level: 35 Points: 3,258, Level: 35 Points: 3,258, Level: 35
Level Up 39% Completed
Forum Activity 3%
TPS can do it also, just found that recently on mine.
amc49 is offline
Old 07-04-2013, 09:30 AM   #5
harrison.mike.j
harrison.mike.j's Avatar
Fan#: 113544
What I Drive: 2002 Red Focus SE Wagon
Points 344, Level 6
Points: 344, Level: 6 Points: 344, Level: 6 Points: 344, Level: 6
Level Up 88% Completed
Level up: 88% Level up: 88% Level up: 88%
Forum Activity 2%
FF Reputation: 1 harrison.mike.j Good Standing Member
I would go after the IAC first. I just worked through this on my Zetec as well. Remove the IAC, fill the inside of the valve area with tune-up cleaner, let soak for 5 min, dump it and blow out with compressed air, reinstall. This is a common part of a good tune-up on any non electronic throttle controlled vehicle.
harrison.mike.j is offline
Old 07-04-2013, 10:52 AM   #6
CotyM
CotyM's Avatar
Fan#: 85558
What I Drive: blue, y2k, 5spd ZX3, zetec inside
Points 939, Level 16
Points: 939, Level: 16 Points: 939, Level: 16 Points: 939, Level: 16
Forum Activity 3%
FF Reputation: 3 CotyM Good Standing Member
+1
Check engines codes, a TPS error will have a code for bad TPS... Otherwise I would bet IAC... Autozone will check your codes for free.
2000 Ford Focus US Spec Zetec 5 speed "Blue Dragon"
2000 Renault Clio 1.4 DOHC 5speed "Snap Dragon"
Hatch Nation #32
CotyM is online now
Old 07-04-2013, 10:54 AM   #7
amc49
Fan#: 96610
Forum Activity 3%
Many late IACs have a rubber diaphragm in them, you want no solvents in there..........on the older ones with no rubber, yeah, you could clean those.
amc49 is offline
