anyone else data logging regularly? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Third Generation > MK3 Interior Mods & Upgrades
MK3 Interior Mods & Upgrades The place to chat about performance gauges, shifter knobs, custom interior paint, car seats or any interior upgrades for the 2012 Focus.
Old 07-02-2013, 09:25 PM   #1
2kwik4u
Fan#: 102523
What I Drive: '12-Sonic Blue-5dr/5spd/203A/Roof
Points 1,642, Level 23
Points: 1,642, Level: 23 Points: 1,642, Level: 23 Points: 1,642, Level: 23
Level Up 43% Completed
FF Reputation: 1 2kwik4u Good Standing Member
Since I had the loss of power issue a few weeks back I've been data logging my trips into and home from work. Interesting data if nothing else good comes of it.
Question is what to do with the "door" that covers the OBD2 port. I'm currently just letting it hang down but occasionally bonk it with my foot when getting in/out of the car.
Any thoughts on how to handle that from the resident interior guru's?
2kwik4u is offline
Old 07-03-2013, 12:14 AM   #2
ShoOff
ShoOff's Avatar
Fan#: 109590
What I Drive: 2013 Performance Blue SE Hatchback
Points 1,858, Level 25
Points: 1,858, Level: 25 Points: 1,858, Level: 25 Points: 1,858, Level: 25
Level Up 58% Completed
FF Reputation: 16 ShoOff Great Standing Member
What r u using for data logging?
Steeda CAI, Steeda STS, Magnaflo Cat Back Exhaust, Injected Tuner, Cobb Rear Motor Mount, TTR Upper Motor Mount, Injected 180 T Stat
ShoOff is offline
Old 07-03-2013, 05:31 AM   #3
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Points 1,277, Level 19
Level Up 77% Completed
Yes, there is a data logging thread in the Ti-VCT performance section. As for the OBD door, all you need is an OBD right - angle extension cord. It will give you the room to close the door and still be plugged in.
Hatch Nation #90
TboneZX3 is offline
Old 07-03-2013, 09:39 AM   #4
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
This is the extension I bought:
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
The low profile right-angle will give you enough room to keep the door closed. In addition, you will need to unclip the OBDII port from its hole in the dash to allow it to "retract" further into the dash. I just keep the extension coiled up behind the port, and plug the sensor in when I need it--hidden back above the "dead pedal". Of course, you can run the extension to wherever you feel is convenient.
This thread contains some Torque logs and discussion: http://www.focusfanatics.com/forum/showthread.php?t=319243
Hatch Nation #90
TboneZX3 is offline
Old 07-03-2013, 05:01 PM   #5
bigliketexas
Fan#: 109094
What I Drive: 13' SE|HB
FF Reputation: 1 bigliketexas Good Standing Member
If you look at the ODBII port you should see a white clip on each side. Press them in and push back. This should unhinge the port and allow you to leave your dongle attached always.
bigliketexas is offline
Old 07-03-2013, 05:14 PM   #6
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Not the larger ones like mine. I had to unclip the port and use the extension above, as I described. Many OBD adapters are stilll too long and fat to fit without the extension cord.
Hatch Nation #90
TboneZX3 is offline
