Does the auto gauge cluster have a shift light? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-02-2013, 09:52 AM   #1
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,689, Level 86
Points: 18,689, Level: 86 Points: 18,689, Level: 86 Points: 18,689, Level: 86
Level Up 68% Completed
Forum Activity 18%
Buy-Sell-Trade Rating: (4)
I ask because I can't get it to work.
There's a bulb in there that is good. I've adjust the tune several times trying different turn on points and trans types to no avail. I know that it worked with both my manual trans clusters so I'm at a loss here. Everything inside looks the same, pins and all.
Got me.
iminhell is offline
Old 07-02-2013, 02:01 PM   #2
a_2000_se
a_2000_se's Avatar
Fan#: 62964
What I Drive: 2000 SE SOHC SPI, Compression @ 164
Points 4,699, Level 43
Points: 4,699, Level: 43 Points: 4,699, Level: 43 Points: 4,699, Level: 43
Level Up 75% Completed
Forum Activity 5%
FF Reputation: 15 a_2000_se Great Standing Member
It has never 'illuminated' on the 2000 automatic as a function of shifting but as you probably have seen it does illuminate during the bulb self test.
Member of the Dropped Valve Seat Club.
Replaced #4 Piston, Rings, Rod+Bearings, AERA Re-Manufactured Cylinder Head and a light Hone. Then CLEANED the hell out of everything.
60k+ miles.
a_2000_se is offline
Old 07-02-2013, 05:45 PM   #3
amc49
Fan#: 96610
Points 3,279, Level 35
Points: 3,279, Level: 35 Points: 3,279, Level: 35 Points: 3,279, Level: 35
Level Up 53% Completed
Forum Activity 13%
To my knowledge the shift light has only been programmed into the PCM for manual trans only, never ATX, and like forever. That was way back in Tempo days, I looked into it back then. Maybe cluster is otherwise different. Probably in a chip somewhere. Earlier clusters had the light position but didn't work.
amc49 is offline
Old 07-02-2013, 08:11 PM   #4
Magus2727
Magus2727's Avatar
Fan#: 62897
Points 8,413, Level 61
Points: 8,413, Level: 61 Points: 8,413, Level: 61 Points: 8,413, Level: 61
Level Up 88% Completed
Level up: 88% Level up: 88% Level up: 88%
Forum Activity 27%
Activity: 27% Activity: 27% Activity: 27%
likely due to not wanting to have a different wire harness or dash or such for different transmission configurations. most vehicles use a single wire harness and then plug in the different bits. with something like the shift light it is a operations thing to just have all the bulbs installed vs identifying if it should or should no be there.
2001 ZX3 2.0L Zetec-
Hatch Nation #42
Magus2727 is offline
Old 07-02-2013, 08:40 PM   #5
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Forum Activity 18%
Car is MTX, cluster is ATX.
I've got PRP and can change anything. It no workie.
Unrelated ? The 'Brake" lamp has been illuminated since I bought the car. Thought it was just corrosion at the Brake Level Sensor. Swapped a known good sensor, nada; pulled the connector apart, cleaned and tightened it, nada. Checked the parking brake switch, works as it should, simple open/closed circuit.
Didn't really click but maybe it's related to the shift light not working. I'll have to verify the pinouts.
iminhell is offline
Old 07-03-2013, 04:44 PM   #6
amc49
Fan#: 96610
Forum Activity 13%
Could be............
amc49 is offline
Old 07-03-2013, 05:05 PM   #7
freemind
Vince your Moderator
freemind's Avatar
Fan#: 67513
Points 6,606, Level 53
Points: 6,606, Level: 53 Points: 6,606, Level: 53 Points: 6,606, Level: 53
Level Up 28% Completed
Forum Activity 49%
Buy-Sell-Trade Rating: (23)
You can get it reprogrammed at Ford for $110.00
Hatch Nation #140
Caeci caecos ducentes
freemind is offline
Old 07-04-2013, 01:56 AM   #8
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Forum Activity 18%
^Far as I was told, no you can't. Any cluster '05+ you can. But the older ones aren't able to.
I checked because the cluster I'm using says 122,xxx and the actual mileage on the car is just over 54,xxx.
Though it could be I just didn't find a dealer willing yet, have called 5 of the big ones in the state.
iminhell is offline
Old 07-04-2013, 02:24 AM   #9
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 138,625, Level 100
Points: 138,625, Level: 100 Points: 138,625, Level: 100 Points: 138,625, Level: 100
Level Up 0% Completed
Forum Activity 50%
Activity: 50% Activity: 50% Activity: 50%
Buy-Sell-Trade Rating: (11)
That's weird cause we had a local member have a SVT cluster programmed for his mileage and it was an SPI lol. I think it's all how you ask them. Don't tell them your swapping cluster cause you want one with a tach. I think he told them his other cluster was bad and broken and that was good enough for them to do it. Now can that happen again, I have no idea, they could have changed their policy on it since then.
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is offline
Old 07-04-2013, 04:48 AM   #10
amc49
Fan#: 96610
Forum Activity 13%
They may not want to simply because of the mileage issue, or tampering with it, illegal in some places.
amc49 is offline
