2001 ZX3 with NO A/C! - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-01-2013, 05:02 PM   #1
CurtZHP
Fan#: 89053
What I Drive: 2001 Silver ZX3
FF Reputation: 1 CurtZHP Good Standing Member
2001 ZX3 DOHC Zetec.
For well over a year now my air conditioning has not worked. When I hit the button, the light comes on, but I don't hear the compressor kick on. It's been my understanding that, the way this system is designed, if there is inadequate pressure in the system, the compressor WON'T come on in order to prevent it from getting burned up. Can anyone confirm this or tell me I'm out to lunch?
I'm assuming that's the case, and the system just needs a good recharge. I've seen the new cans of refrigerant at AutoZone; some even come with their own pressure gauge. I was tempted to try one, but I thought I'd check with the good folks here first.
CurtZHP is offline
Old 07-01-2013, 07:03 PM   #2
CotyM
CotyM's Avatar
Fan#: 85558
What I Drive: blue, y2k, 5spd ZX3, zetec inside
Points 957, Level 16
Points: 957, Level: 16 Points: 957, Level: 16 Points: 957, Level: 16
Level Up 57% Completed
Level up: 57% Level up: 57% Level up: 57%
Forum Activity 2%
FF Reputation: 3 CotyM Good Standing Member
Yeah it's either to high or to low, chances are that the system is to low and probably has a leak, if you try to charge it, make sure to add some refrigerant with UV dye that way you can use a black light to find what part is leaking. Then you can replace that part and have the system evacuated (draws moister from the system) and re-charged...
If you decide to take the stop leak rought, although not recommended, IDQ actually has cans of refrigerant that is supposed to remove moister from the lines. I don't know how; my guess is it uses a formula to turn the moister into stop leak... It's defenently worth trying if you take the stop leak rought...
2000 Ford Focus US Spec Zetec 5 speed "Blue Dragon"
2000 Renault Clio 1.4 DOHC 5speed "Snap Dragon"
Hatch Nation #32
CotyM is offline
Old 07-01-2013, 07:04 PM   #3
MEJY1988
Fan#: 101883
What I Drive: 2006 Burgandy ZX5
Points 163, Level 3
Points: 163, Level: 3 Points: 163, Level: 3 Points: 163, Level: 3
Level Up 26% Completed
FF Reputation: 3 MEJY1988 Good Standing Member
You are correct, there is a pressure switch in the line that will not let the clutch energize if there is not enough pressure in the system. IIRC there is a How-To on this. Also DO NOT MIX REFRIGERANT TYPES; ie: R-12 AND R-134, THEY ARE NOT COMPATIBLE WITH EACH OTHER. Good Luck.
I was a Shade Tree Mechanic, but had to cut down the Shade Tree to make room for the garage. Does this make me a Mechanic now?
MEJY1988 is offline
Old 07-01-2013, 07:07 PM   #4
CotyM
CotyM's Avatar
Fan#: 85558
Forum Activity 2%
^ You can't put R-12 in any US focus, iirc, 1992 was the last year R-12 was legal to be put on cars. If OP somehow manages to get a hold of R-12 it will cost him allot of money and he will quickly find that the can will not hook up to the focus.
Hatch Nation #32
CotyM is offline
