Help advice needed -Head Gasket gone again - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-01-2013, 12:46 PM   #1
handrews
Fan#: 116311
What I Drive: 2010 ford focus black
FF Reputation: 1 handrews Good Standing Member
Hello
Help needed
I purchased my ford focus in feb 2010 new then after 20,000 miles and 18 months later the head gasket went - the dealer garage repaired it for free-now 20 months and 40,000 miles the head gasket has gone again, i have always had the car serviced with the dealer
Is this normal ??? or is there a problem with the car ???
handrews is offline
Old 07-01-2013, 01:03 PM   #2
bringler26
FUBARCUS
bringler26's Avatar
Fan#: 59705
What I Drive: 03 ZX3 & 07 Impreza 2.5i
Points 9,434, Level 65
Points: 9,434, Level: 65 Points: 9,434, Level: 65 Points: 9,434, Level: 65
Level Up 28% Completed
Forum Activity 7%
I moved you to our general technical chat area. You should get some more responses. Please post more details about your engine. This site is US based but has lots of people who are knowledgeable that can still help. It definitely isn't right that you have gone through two head gaskets.
2007 Subaru Impreza 2.5i - current DD
I always moderate naked!
bringler26 is offline
Old 07-01-2013, 01:08 PM   #3
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Points 2,078, Level 27
Points: 2,078, Level: 27 Points: 2,078, Level: 27 Points: 2,078, Level: 27
Level Up 52% Completed
Depends on the extent of the repairs made by the mechanic - gasket failures can warp heads and most warped heads need planing - and what caused the gasket failure in the first place (engine overheating?) As stated, not normal.
BC_ZX3 is offline
Old 07-01-2013, 01:24 PM   #4
handrews
Fan#: 116311
Really sorry dont know what caused the original problem, i never asked they never said i was just too concerned about the bill to ask but they said this time that they skimmed it last time ..does that sound right ?
Now they want me to pay 1300 to get it repaired
handrews is offline
Old 07-01-2013, 01:24 PM   #5
150mphzetec
Fan#: 77175
What I Drive: 00 yellow zetec
Points 389, Level 7
Points: 389, Level: 7 Points: 389, Level: 7 Points: 389, Level: 7
Level Up 78% Completed
FF Reputation: 2 150mphzetec Good Standing Member
definitely need more information as to why the gasket needed replacement the first time. Sometimes the gasket can break due to overheating of the cooling system. This is the worst type of head gasket break because it can warp the parts separated by the gasket. Another way the gasket can break is between the cylinders causing compression leakage. This sometimes happens but is not as common as the breakage due to overheat. If you have the paperwork for the first repair, it may tell what was found and why it was replaced. If it was due to overheating the head surface may not have been prepared correctly when put back into service.
Another reason this head gasket may need replacing so soon is that it was not done correctly. I had this happen with a car I purchased, some of the head bolts were finger loose because the PO did not know that they went on in stages when he replaced it
150mphzetec is offline
Old 07-01-2013, 01:30 PM   #6
handrews
Fan#: 116311
thank you for the advice i will ring the garage tomorrow and ask for the info
Great help thanks
i will get back tomorrow to you
handrews is offline
Old 07-01-2013, 01:35 PM   #7
nilskje
Fan#: 11478
What I Drive: Focus -04 5door 1,6 Ghia
Points 460, Level 9
Points: 460, Level: 9 Points: 460, Level: 9 Points: 460, Level: 9
Level Up 20% Completed
FF Reputation: 17 nilskje Great Standing Member
Not normal, what engine do you have in your Focus?
nilskje is offline
Old 07-01-2013, 01:40 PM   #8
handrews
Fan#: 116311
1.6d titan
handrews is offline
Old 07-01-2013, 07:36 PM   #9
amc49
Fan#: 96610
Points 3,360, Level 36
Points: 3,360, Level: 36 Points: 3,360, Level: 36 Points: 3,360, Level: 36
Level Up 7% Completed
Forum Activity 40%
Activity: 40% Activity: 40% Activity: 40%
One time use head bolts most likely, ask if they CHANGED them for new. If you didn't pay first time around they may have used them over to save shop cost. That could do it.
amc49 is offline
Old 07-01-2013, 09:17 PM   #10
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,868, Level 87
Points: 18,868, Level: 87 Points: 18,868, Level: 87 Points: 18,868, Level: 87
Level Up 4% Completed
Forum Activity 13%
Buy-Sell-Trade Rating: (4)
Gas engine, blowing HG's is abnormal.
Diesel, I can't say for certain, but sounds odd.
The thing that does (maybe) concern me is that the head was skimmed. Diesel is dependent on compression. If you raise compression you must change injection timing. But this will depend on how much compression has actually changed and how much was taken off the head. This is why they make shims.
But lets say the job was done correct (which I don't doubt) what would cause 2 failures in 40,000 KM (or is it miles?)?
The only thing I can think of isn't overheating, it's compression. Too much pressure too early will lift a head and/or burn through a HG. So back to injector timing. Abnormally high EGT's would reflect this.
But I'm curious why they say it's the HG that's bad. Find that out for me and I might be able to help more.
iminhell is online now
