Speedometer works but jumps to speed - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-01-2013, 12:02 PM   #1
jlaws1990
Fan#: 109971
What I Drive: 2001 Red LX
FF Reputation: 1 jlaws1990 Good Standing Member
Question Speedometer works but jumps to speed
The speedometer on my 2001 Focus 5spd jumps up and down in speed rather than rising or declining. It jumps to the correct speed but freezes there until I go five iver or five under what its reading then it will jump down or up 5mph to the corresponding speed. I was thinking speed sensor. But I do not know for sure, maybe the cable?
Also if im parked with my car running it shakes really bad and sometimes boggs down and idles so low it almost dies. Any ideas? Maybe timing is off
jlaws1990 is offline
Old 07-01-2013, 12:58 PM   #2
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Points 2,074, Level 27
Points: 2,074, Level: 27 Points: 2,074, Level: 27 Points: 2,074, Level: 27
Level Up 50% Completed
Forum Activity 5%
What cable? Cable driven speedometers haven't been used on cars in years.
Common idle problem causes on the Focus are vacuum leaks, malfunctioning IAC valves and lack of regular maintenance ( plugs, plug wires, fuel and air filter and PCV changes, etc). A faulty engine mount can cause excessive shaking.
If you have a high mileage SPI engined Focus, a compression check on a car that consistently runs poorly would be in order.
Timing seldom goes "off"; the timing belt either breaks or sheds its teeth. It usualy disables the car.
BC_ZX3 is offline
Old 07-03-2013, 08:38 PM   #3
jlaws1990
Fan#: 109971
Just talked to the mechanic he said I need new seals and gaskets on my motor=$2100
He also said buying a 70, 000 mile engine and installing it would be $2000
$100 cheaper than him fixing it. :'(
Old 07-03-2013, 09:37 PM   #4
mikeeshaq
Fan#: 72526
What I Drive: 2010 Transit Connect
Points 626, Level 12
Points: 626, Level: 12 Points: 626, Level: 12 Points: 626, Level: 12
Level Up 52% Completed
FF Reputation: 15 mikeeshaq Great Standing Member
"""Also if im parked with my car running it shakes really bad and sometimes boggs down and idles so low it almost dies."""
I had a 2004 Zetec automatic and it did just that--it was the motor mounts
If you have a SPI engine sticking in a 70,000 mile SPI engine is a bad bet- valve seat drop issue
mikeeshaq is offline
Old 07-04-2013, 06:21 AM   #5
amc49
Fan#: 96610
Points 3,270, Level 35
Points: 3,270, Level: 35 Points: 3,270, Level: 35 Points: 3,270, Level: 35
Level Up 47% Completed
Forum Activity 9%
All 3 of mine 'need new seals and gaskets', like 5 years ago. Man you need to dump that mechanic, nobody does 'seals and gaskets only' on an engine, or, incompetent.
Motor mounts make motor shake but cannot make it idle low, if truly doing so. Now if misconstrued, yes, or the usual excellent use of the english language around here.
Speedo issue could be the gauge itself.
amc49 is offline
