Timing tool knurled end left in, any cause for issue? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-01-2013, 01:48 AM   #1
Deus Machina
Fan#: 100167
What I Drive: 2000 black ZX3
FF Reputation: 1 Deus Machina Good Standing Member
Jeez, life has sucked lately. Finally starting to get this thing back to running.
Okay, I had a saga changing the timing belt, where the timing tool--which locks the crankshaft--bent and got stuck. I managed to cut out the business end, so now I don't have to worry about the crankshaft.
But the grip end is still stuck in the hole that would normally have a plug torqued into it. Basically it would act as a slightly loose plug.
Is this going to affect oil pressure or anything? Any cause for concern aside from maybe a small leak? Or do I really need to buckle down and drill it out?
Deus Machina is offline
Old 07-01-2013, 05:46 AM   #2
150mphzetec
Fan#: 77175
What I Drive: 00 yellow zetec
Points 389, Level 7
Points: 389, Level: 7 Points: 389, Level: 7 Points: 389, Level: 7
Level Up 78% Completed
FF Reputation: 2 150mphzetec Good Standing Member
you can leave it in there if you don't mind a leak from there. That hole is really only there to lock the crank but there are other ways to determine TDC. To keep it from leaking, you may be able to turn it out a little, squeeze high-temp rtv in there, let it set slightly, then tighten the bolt/broken lock peg. This may help act as the rubber o-ring which is part of the bolt normally in that spot
150mphzetec is offline
Old 07-01-2013, 08:21 AM   #3
amc49
Fan#: 96610
Points 3,368, Level 36
Points: 3,368, Level: 36 Points: 3,368, Level: 36 Points: 3,368, Level: 36
Level Up 12% Completed
Forum Activity 49%
Leave it alone. Clean around it real good and build up a wad of silicone to cover it. Ugly but last forever done right.
amc49 is offline
Old 07-01-2013, 03:00 PM   #4
Deus Machina
Fan#: 100167
Alright, kind of what I figured. I just wasn't absolutely certain that the motor doesn't want an enclosed system.
Silicone it is!
Old 07-01-2013, 07:23 PM   #5
amc49
Fan#: 96610
Forum Activity 49%
Not enclosed, the valve cover hose is a big leak.
amc49 is offline
Old 07-01-2013, 10:02 PM   #6
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,868, Level 87
Points: 18,868, Level: 87 Points: 18,868, Level: 87 Points: 18,868, Level: 87
Level Up 4% Completed
Forum Activity 13%
Buy-Sell-Trade Rating: (4)
and that pin isn't subject to oil pressure, only oil spray thrown off the crank. I wouldn't doubt if W/O anything it'd not leak at all ... water would be my concern though.
iminhell is offline
