Sport pedals - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Third Generation > MK3 Interior Mods & Upgrades
MK3 Interior Mods & Upgrades The place to chat about performance gauges, shifter knobs, custom interior paint, car seats or any interior upgrades for the 2012 Focus.
Old 06-30-2013, 10:15 PM   #1
jims shadetree
jims shadetree's Avatar
Fan#: 116036
What I Drive: 2013 tuxedo black 5 spd hatch se
FF Reputation: 1 jims shadetree Good Standing Member
Sport pedals
I didn't realize till I bought first set how much difference there was in tbem nor the way they mounted.not to mention the plastic clutch pedal n brake pedal that arm sits all the way to edge of pad area not to mention major curve of gas pedal..anyway I went back today n picked up a dimensionally smallest set I could find that had holes thru the middle (or room to drill) n headed to shop.I clamped in vise a a pair of wheel spacers that ha e same curve
Sent from my SAMSUNG-SGH-I747 using FF Mobile
Hatch nation #66
Gettin my kicks on route 66!
jims shadetree is offline
Old 06-30-2013, 10:31 PM   #2
jims shadetree
Fan#: 116036
Sorry damn phones.anyway had same curve as gas pedal n worked pedal cover to happy harmony n marked the holes so would clear the arm stucture.I used cut off deck screws n speed nuts on the back side(make sure move it up enough so when wot wont hit floor) then on to the brake pedal I attached the cover all the way to the left side to give plenty of room for my big paw to mash the gas.same deck screw speed nut hardware.the clutch pedal centered the cover on pad area slightly to the left for arm clearance. Not to bad .next I'll shadetree up a dead pedal n anodize m all black n red
Name:	uploadfromFF Mobile1372645803446.jpg
Name:	uploadfromFF Mobile1372645871113.jpg
Hatch nation #66
Old 06-30-2013, 11:01 PM   #3
jims shadetree
Fan#: 116036
Here's few more pics may helpClick image for larger version
Name:	uploadfromFF Mobile1372647535671.jpg
I did use some felt inbetween
Also removed rubber pedal coversClick image for larger version
Name:	uploadfromFF Mobile1372647643965.jpg
Name:	uploadfromFF Mobile1372647674188.jpg
Hatch nation #66
Old 08-24-2013, 04:32 AM   #4
Marine
Marine's Avatar
Fan#: 105885
What I Drive: 2012 Ford Focus SEL Hatchback
Points 1,697, Level 23
Points: 1,697, Level: 23 Points: 1,697, Level: 23 Points: 1,697, Level: 23
Level Up 97% Completed
Level up: 97% Level up: 97% Level up: 97%
Forum Activity 19%
FF Reputation: 2 Marine Good Standing Member
Jim I just picked up same ones. Can you explain a little better how you did it again especially the gas pedal. How they holding up? What size screws and speed nuts?
Marine is offline
Old 08-24-2013, 05:12 PM   #5
jims shadetree
Fan#: 116036
I had to recurve the sport pedal for the gas pedal so it had same curve .got to make sure u have it slid up towards pedal arm so the bottom edge doesn't hit the floor.also have to make sure where u drill thru stock pedal on the bottom ur at an open spot of bridge work of arm...ill tryin get more pics....I just used normal sheetrock screws n think they were #6 speed nuts n cut extra of on of screws...the brake pedal n clutch I removed the rubber pads.the sport cover for the brake I did attach is as far to the left as I could so had plenty of room to stomp on gas pedal.hardest part was gettin my large body in to do the job..I did remove throttle assy n did it on the bench (cheat!) As far as holding up been perfect.almost for get there not factory. Very grippy even with my greasy work shoes n being wet.I haven't found a dead pedal to match yet but been lookin.
Hatch nation #66
Old 08-24-2013, 06:20 PM   #6
jims shadetree
Fan#: 116036
Here's some more hope they helpgas pedal
brake pedal
clutch pedal
Hope this shows what I did.the felt (sticky on one side for lamp bases, vases, ect)I used probly isn't necessary but I had it n it sounded good.basically dove in both feet n keeped at it till it worked...damn shadetree!
Hatch nation #66
Old 08-24-2013, 07:18 PM   #7
Marine
Marine's Avatar
Fan#: 105885
Forum Activity 19%
Thanks it helps!
Marine is offline
Old 08-25-2013, 10:26 AM   #8
Marine
Marine's Avatar
Fan#: 105885
Forum Activity 19%
Mine. I used 3M exterior super strength tape with included clips. I clamped it for 24 hours and rock solid no wiggle and play. No drilling.
Marine is offline
Old 08-25-2013, 11:49 AM   #9
jims shadetree
Fan#: 116036
Goes with ur interior mods well..good job n good idea..but damn u was robbed! U might have piano blk grill but ur missing the most important pedal!....I got a can of paint to fix my grill but how u gonna fix ur missing pedal?
Hatch nation #66
Old 08-25-2013, 01:20 PM   #10
Marine
Marine's Avatar
Fan#: 105885
Forum Activity 19%
Cut a hole in the floorboard and play the FLINTSTONES as it seems the only way to fix the DCT LOL
Marine is offline
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Audi S3, Mazda MX-5 Miata and Acura TLX. You can find all Ford Focus, Focus ST and Focus RS related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
