What does heat soak feel like? - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-30-2013, 02:32 PM   #11
#1fordfan
Fan#: 83143
What I Drive: 2005 white se zx4
Points 2,653, Level 31
Points: 2,653, Level: 31 Points: 2,653, Level: 31 Points: 2,653, Level: 31
Level Up 36% Completed
FF Reputation: 4 #1fordfan Good Standing Member
does the car run better in the cool of the morning?
#1fordfan is offline
Old 06-30-2013, 03:37 PM   #12
mikebontoft
Aurelius Pardus
mikebontoft's Avatar
Fan#: 58647
Points 23,637, Level 94
Points: 23,637, Level: 94 Points: 23,637, Level: 94 Points: 23,637, Level: 94
Level Up 29% Completed
Level up: 29% Level up: 29% Level up: 29%
Forum Activity 16%
Activity: 16% Activity: 16% Activity: 16%
long story short, OP has another problem.
mikebontoft is online now
Old 07-01-2013, 04:34 AM   #13
GBPackFan
GBPackFan's Avatar
Fan#: 84314
What I Drive: 2004 Sonic Blue SVT
Points 1,772, Level 24
Points: 1,772, Level: 24 Points: 1,772, Level: 24 Points: 1,772, Level: 24
Level Up 72% Completed
FF Reputation: 3 GBPackFan Good Standing Member
Buy-Sell-Trade Rating: (8)
What's my other problem?
Current love affair: 2004 SVTF #953 (Josephina - pronounced hoe-se-fin-a)
RIP: 2002 SVTF #2358, Sent to graveyard on June 11, 2013. I will always remember the good times we had!!
This car made my hair go gray, and did not care.
GBPackFan is offline
Old 07-01-2013, 08:34 AM   #14
amc49
Fan#: 96610
Points 3,260, Level 35
Points: 3,260, Level: 35 Points: 3,260, Level: 35 Points: 3,260, Level: 35
Level Up 40% Completed
Forum Activity 3%
My point about aluminum was to illustrate that if you use it on intake tube, it is going to absorb the temp of the 230 degree plus air under the hood. Yes, aluminum gives off heat as fast as it takes it on, it will give the outside heat to your intake air which is cooler if CAI. The idea works well on intercoolers also because either ambient air or liquid cooled. The turbo mix can be hotter than that by a good chunk. You flat need insulation or shielding if you want true CAI, it's stupid to pull air from a cold location and then plumb it through a hot area only to reheat it with a metal tube. The idea may work during cool days or winter but in summer, the intake length heating undoes all your cooling efforts.
The main reason major parts are now showing up in aluminum is because they CAN now. Manufacturers have long known that aluminum makes for much less tooling costs, the cutting tools to make parts last much longer. However, the casting techniques all through the '60s and 70s had problems with porosity and density control, the biggest problem with repeat part reliability. Now they seem to have the problem in check. They would've gone to aluminum long ago if they thought it cost effective, heat soak was low on the list of reasons why. Until PCM and O2 sensors showed up they used iron on heads specifically to keep the heat in, as well as exhaust manifolds, it holds emissions way down.
Calling something a 'short ram' is pretty silly too, there's no ramming of anything going on in there. Many of the so-called high perf parts sold now do very little at all for power.
amc49 is offline
Old 07-01-2013, 08:45 AM   #15
TerryB
TerryB's Avatar
Fan#: 34559
What I Drive: Red '01 ZX3
Points 5,215, Level 46
Points: 5,215, Level: 46 Points: 5,215, Level: 46 Points: 5,215, Level: 46
Level Up 33% Completed
FF Reputation: 68 TerryB Excellent Standing Member
^^^ True. My K&N typhoon is almost too hot to touch after turning the engine off. Kind of a contradiction.
TerryB is offline
Old 07-01-2013, 09:20 AM   #16
Milton
Fan#: 89715
What I Drive: 2007 Black Focus SES 2.0 L4 4 Door
Points 324, Level 6
Points: 324, Level: 6 Points: 324, Level: 6 Points: 324, Level: 6
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
Forum Activity 10%
FF Reputation: 8 Milton Good Standing Member
Originally Posted by amc49 View Post
...You flat need insulation or shielding if you want true CAI, it's stupid to pull air from a cold location and then plumb it through a hot area only to reheat it. ...
True on both points.
Also if you have a hot air filter located in the engine compartment it will be even more efficient at reheating the air, which is why we end up with a "lifetime" air filter in the fender.
So for an after market CAI I would want the filter located in the fender and the plumbing to be insulated.
Hmmm, filter in the fender? A pain to change! Hmmm, maybe some sort of filter good for 100k miles?
But how to tell if the filter is clogged? Maybe some sort of remote mounted recording vacuum gauge?
Hmm, bet this will be expense! Yes but often performance requires more money.
I wonder if anyone makes such a system?
To be serious when you think about it you end up with a design similar to Ford's. Did Ford do a good job executing that design? I guess that's a matter of opinion. Would the stock CAI benefit from insulating the plumbing? Would such insulation screw up stock MAF settings?
Just some random thoughts.
Milton is offline
Old 07-01-2013, 09:41 AM   #17
amc49
Fan#: 96610
Forum Activity 3%
Troublemaker..........LOL.
amc49 is offline
Old 07-01-2013, 11:18 PM   #18
GBPackFan
GBPackFan's Avatar
Fan#: 84314
When I drive the car after the sun goes down, or when it is cooler it seems to drive fine, with no issue. However today while I was driving, the temperate is averaging around 95-100* in certain areas with some micro-climates being slightly less, it was definitely having issues. There is not a lot of wind to push the hot air around so it just sits there and gets hotter. The humidity was moderate today, probably around 30-40%.
The car certainly did not like driving in this heat, but once I got into the micro-climate near my house and the temps were in the high 70's to low 80's with a nice cool river breeze the car felt much better.
It's difficult to say where the heat is going to be around here, there are so many micro-climates in the area I live in. Where I live at, it is always warmer than it is on the road that connects my mountain to the river road to the highway. The river road tends to be the coolest portion of my drives. The closest town, Longview, is always hotter than where I live; and the next big city to me, Vancouver, is always hotter than my place and Longview. The highway takes me through several micro-climates on my way to Vancouver. I live in WA State, BTW.
Old 07-02-2013, 02:10 PM   #19
mrdeath2000
Fan#: 91996
What I Drive: 2014 White SE 5spd
Points 1,331, Level 20
Points: 1,331, Level: 20 Points: 1,331, Level: 20 Points: 1,331, Level: 20
Level Up 31% Completed
Level up: 31% Level up: 31% Level up: 31%
FF Reputation: 3 mrdeath2000 Good Standing Member
Next tank of gas, put in 91(93) instead of the normal 87 and see if its different during the heat of the day.
Basically its a test to see if maybe you're getting pre-detonation, knock, whatever you want to call it.
The higher octane is more resistant to knocking/detonation and maybe the lagging is from the ECU pulling timing cause its hot as a mofo.
(AZ was 117 this weekend ;) )
2014 Focus SE Manual -
2006 Focus ZX4 SE Auto -commuter 110k /traded
mrdeath2000 is offline
Old 07-03-2013, 04:33 PM   #20
GBPackFan
GBPackFan's Avatar
Fan#: 84314
I put a half tank of Cheveron Supreme w/ Techron 92 octane, I believe. The car ran marginally better but still had some stumbling.
