OK questions that I hope can be answered - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-29-2013, 03:05 PM   #1
bdeditch
Fan#: 57294
What I Drive: 2008 Ice blue SE
Points 217, Level 4
Points: 217, Level: 4 Points: 217, Level: 4 Points: 217, Level: 4
Level Up 34% Completed
FF Reputation: 1 bdeditch Good Standing Member
I have a 2008 Ford Focus 2.0L SFI DOHC 4cyl, 230,000 miles. Lately its been running a little strange, I know I can't expect like it did 200,000 miles ago. I did an ohm test on the fuel injectors and each one is showing about 12.8, I have no idea what it should be showing. I have been using Shell gas for as long as I can remember. I have never had the check engine light come yet. I am going to change the fuel filter this week and see if that helps first.
Questions
(1) What should the ohm output show for the injectors
(2) How can you check wires going to injectors?
(3) I have had this going on for a while. When I am driving in the city where the speed limit is about 40 to 50, my car seems to lose power from the 40 to 45 MPH range. When I give it a little more gas it seems to go away at about the 46 MPH mark. What would cause this? It seems it does it more with the A/C on.
bdeditch is offline
Old 06-29-2013, 11:13 PM   #2
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 13,055, Level 74
Points: 13,055, Level: 74 Points: 13,055, Level: 74 Points: 13,055, Level: 74
Level Up 52% Completed
Forum Activity 99%
Questions
I'd check the fuel pressure. Your replacing the filter which is in the tank, I'd replace the fuel pump too. Have you had your injectors flushed at a pro shop? Lots of miles, thats great to hear that your motor is still doing. For the ohm output, you'll have to hit up a shop manual or maybe google it.
felixthecat is offline
Old 06-29-2013, 11:49 PM   #3
bdeditch
Fan#: 57294
Points 217, Level 4
Actually the fuel filter is out side the tank on the frame.
bdeditch is offline
Old 06-30-2013, 02:47 AM   #4
LensDriven
LensDriven's Avatar
Fan#: 111184
What I Drive: 2006 Blk ZX4 SES, 2009 Blu Coupe SE
FF Reputation: 1 LensDriven Good Standing Member
Really? I thought after 07 they started putting em in the tank as 'lifetime'.
LensDriven is offline
Old 06-30-2013, 03:36 AM   #5
bdeditch
Fan#: 57294
Points 217, Level 4
No it is the type with 3 ports and the those clips are hard to get at.
bdeditch is offline
Old 06-30-2013, 03:48 AM   #6
LensDriven
LensDriven's Avatar
Fan#: 111184
Huh. I had no idea- my 09 is in the tank... I guess they changed it 09, not 08... I guess a lot of people figured it changed with the restyle. :)
Old 07-01-2013, 01:38 AM   #7
DJFreshlySnipes
DJFreshlySnipes's Avatar
Fan#: 99868
What I Drive: 09' Focus Coupe (Blue)
Points 1,336, Level 20
Points: 1,336, Level: 20 Points: 1,336, Level: 20 Points: 1,336, Level: 20
Level Up 36% Completed
Forum Activity 3%
FF Reputation: 1 DJFreshlySnipes Good Standing Member
Questions
Question
1). How did you put 230k miles on your car in 4 years? ? Do you commute from New York to LA for work every day or something lol?
- Kind of sounds like an air flow issue or an issue with the mass air flow sensor. When was the last time you checked your air intake filter and intake manifold? I cleaned my intake manifold recently and noticed a huge difference
- Go to an auto parts store and pick up Sea-Foam. Just put it in your gas tank and It cleans out the junk in your whole system. I use it every few months and can tell the difference immediately.
SEA-HAWKS
DJFreshlySnipes is offline
Old 07-01-2013, 10:41 AM   #8
bdeditch
Fan#: 57294
Points 217, Level 4
Originally Posted by DJFreshlySnipes View Post
Question
I commute about 160 miles a day to work and back, I know it a long distance.
As for air flow I took out the OEM Air filter and installed a K&N Cold air induction set up. I was surprised that California would even allow it, but it does have the carb sticker that is required here. I will try cleaning the intake manifold, I have not done that in a while.
bdeditch is offline
Old 07-01-2013, 12:04 PM   #9
felixthecat
w/ my magic bag
Fan#: 80663
Forum Activity 99%
bdeditch, your spelling for Your location in California= the a & i are backwords. What part are you at?
Old 07-01-2013, 12:55 PM   #10
bdeditch
Fan#: 57294
Points 217, Level 4
Well no one edited it for me and here is my exact quote, I I have the spell checker on, but it shows that you spelled backwards wrong, its not backwords
I am beside Sacramento
"I commute about 160 miles a day to work and back, I know it a long distance.
As for air flow I took out the OEM Air filter and installed a K&N Cold air induction set up. I was surprised that California would even allow it, but it does have the carb sticker that is required here. I will try cleaning the intake manifold, I have not done that in a while."
bdeditch is offline
