Fsw Stage 2 help!! - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Tech Discussions > General Forced Induction
Old 06-29-2013, 02:26 PM   #1
King Hoonigan
King Hoonigan's Avatar
Fan#: 100769
What I Drive: 2011 Sterling Grey SES
FF Reputation: 1 King Hoonigan Good Standing Member
Fsw Stage 2 help!!
Whats up guys, im mostly through with my install but cant for the life of me figure out how to mount the intercooler. Anyone know how this thing is supposed to mount? Bolts and nuts are supplied, but how are you supposed to get a nut onto the bolts in that enclosed space inside the bumper? Also, for the water lines, do they connect to the old rubber lines or where they came off of? any help is greatly appreciated. thanks in advance.
-Fswerks Race exhaust-Eibach Pro's-Eagle Eye Projectors-Fswerks stage 2 turbo-H&R 20mm Spacers(rear)-3D Carbon Rear Diffuser-17" Sparco Tarmac's-EBC Drilled Slotted Rotors-
King Hoonigan is offline
Old 06-29-2013, 05:04 PM   #2
koke'sfocus
koke'sfocus's Avatar
Fan#: 69779
What I Drive: 05 silver st
Points 4,267, Level 41
Points: 4,267, Level: 41 Points: 4,267, Level: 41 Points: 4,267, Level: 41
Level Up 59% Completed
FF Reputation: 1 koke'sfocus Good Standing Member
Buy-Sell-Trade Rating: (6)
Well the intercooler u have to make the holes and u can put a wrench with the nut an put the screw on is simple or u can cut a piece of the crash bumper
cossie im, cfm 67mm tb, 3" dp, 3" exhaust and custom turbo kit, holset hx35 turbo on 13psi, exedy stage 2 clutch and flywheel
Stock long block 353whp 280lbtq, 13psi
team duratec #94
D23 crew #9.
koke'sfocus is offline
Old 06-30-2013, 01:12 PM   #3
King Hoonigan
Fan#: 100769
ok so im good on the intercooler, only thing im stuck on now are where the turbo water lines go.
Old 06-30-2013, 08:30 PM   #4
King Hoonigan
Fan#: 100769
Alright so ive got everything together except the water lines. really rough idle on startup with white smoke,not a lot, but definitely noticeable with a strong fuel smell. any ideas?
Old 06-30-2013, 08:53 PM   #5
ZXthrizzle05
TURBO ZX3
ZXthrizzle05's Avatar
Fan#: 24434
What I Drive: 2007 mazda 3 I sport, TURBO ZX3
Points 50,433, Level 100
Points: 50,433, Level: 100 Points: 50,433, Level: 100 Points: 50,433, Level: 100
Level Up 0% Completed
Forum Activity 4%
FF Reputation: 6 ZXthrizzle05 Good Standing Member
Buy-Sell-Trade Rating: (11)
Fuel cell culd be tune related. Or a loose hose to fuel rail
FF MODERATOR
RISE AGAIN EGGYOLK302 WHP 274 WTQ ZETEC CREW #271
RIFF CREW
ZXthrizzle05 is offline
Old 07-01-2013, 03:03 AM   #6
King Hoonigan
Fan#: 100769
thats what i was thinking, just finished the install and havent started tuning yet. might also have something to do with the empty space on the inlet. Anyone know what actually goes there? im pretty sure that would fix the wierd idle problem. Gotta resolve this quick seeing how this car is my only dd
Old 07-01-2013, 07:41 AM   #7
Jgrove998
i <3 my ST
Jgrove998's Avatar
Fan#: 45311
What I Drive: '12 Fusion SE V6
FF Reputation: 24 Jgrove998 Great Standing Member
Buy-Sell-Trade Rating: (13)
Did you buy the kit from FSwerks? Their instructions are pretty detailed IIRC.
Did you have a base tune before you started the car? The weird idle would be fixed when the ECU is tuned for the new injectors (and other things). Empty space on the inlet? Not sure what your talking about there.
2012 Fusion SE 3.0L V6
'86 XR4Ti ; 2.3L Turbo, 15psi
1988 F150 Custom
'07 ST ; formally bewst'd - R.I.P
D23 Crew: #07
Jgrove998 is offline
Old 07-01-2013, 10:41 AM   #8
King Hoonigan
Fan#: 100769
No I don't have the base tune yet, I'm hoping that's what it is. I bought it brand new from fswerks. The 2.5 inlet branches out up near the turbine and looks like maybe a hose or some sort of fitting goes there I just don't know what
Old 07-02-2013, 11:51 AM   #9
Jgrove998
i <3 my ST
Jgrove998's Avatar
Fan#: 45311
If you bought the kit from FSwerks than you have the full support of the shop. I would not start the car until Randy tells you too or until you at least have a base tune loaded; you've changed the injectors, MAF location and added the turbo....there no way the car will run correctly with the stock tune from Ford. His remote tuning process if pretty particular and you should follow the instructions provided carefully.
The inlet you describe sounds like it could be for the bypass valve. The FSwerks system is recirculated due to metering the incoming air before the turbo. That means when you let off the throttle and the bypass valve opens, the air is returned to the charge piping AFTER the MAF (because it's already been metered by the ECU) and NOT vented to the atmosphere. You need to have to bypass valve hooked up correctly; if you don't its like have a giant vacuum leak.
1988 F150 Custom
D23 Crew: #07
Old 07-02-2013, 05:43 PM   #10
King Hoonigan
Fan#: 100769
Yep it was definitely the bypass. The bottom hose slipped off, and now I fel stupid lol. Idles smoothly, now to start tuning. Thanks for the help guys
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Cadillac ATS-V, Ford Fusion and Acura TLX. You can find all Ford Focus and Focus ST related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
