NEW PRODUCT: Turbo Tech Racing Upper Engine Mount!!! - Page 13 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-25-2013, 07:00 PM   #121
Seminoles
Seminoles's Avatar
Fan#: 98405
What I Drive: 2012 SGM SE Sedan
Points 969, Level 16
Level Up 69% Completed
Forum Activity 2%
FF Reputation: 1 Seminoles Good Standing Member
Thank you sir my thoughts too.
Seminoles is offline
Old 07-25-2013, 07:13 PM   #122
Bliky
Bliky's Avatar
Fan#: 95135
What I Drive: 2012 Sterling Gray Focus Titanium
Points 3,308, Level 35
Points: 3,308, Level: 35 Points: 3,308, Level: 35 Points: 3,308, Level: 35
Level Up 72% Completed
FF Reputation: 4 Bliky Good Standing Member
I saw you guys offer UPS Ground shipping on the website. I'm away until the 4th and I want to order one but I don't want it to come before I get home... How long does shipping usually take. My zip code is 07932 if you need it.
'12 Sterling Grey Titanium Hatch - Moonroof / Winter Package / DCT / 17' Alloy Wheels
MK3 Manual Transmission Swap: http://bit.ly/1ondtuV
Bliky is offline
Old 07-25-2013, 10:43 PM   #123
TurboTechRacing
FF Affiliate
Fan#: 100913
What I Drive: Focus ST
Points 1,340, Level 20
Points: 1,340, Level: 20 Points: 1,340, Level: 20 Points: 1,340, Level: 20
Level Up 40% Completed
Forum Activity 2%
FF Reputation: 1 TurboTechRacing Good Standing Member
Ground takes 3 business days, so delivery ON the 4th you would want to order next Wednesday the 31st.
-Aaron
Turbo Tech Racing
www.TurboTechRacing.com
TurboTechRacing is offline
Old 07-26-2013, 03:24 AM   #124
MG_MK3
MG_MK3's Avatar
Fan#: 114522
What I Drive: 2013 Blue Candy Focus Hatchback SE
Points 493, Level 9
Points: 493, Level: 9 Points: 493, Level: 9 Points: 493, Level: 9
Level Up 86% Completed
Forum Activity 2%
FF Reputation: 0 MG_MK3 Newbie
2013 "Blue Candy" Focus Hatchback SE/DCT
AEM CAI | Steeda RMM | ST wing | TTR UMM
2.5 inch straight pipe | 3SDM 0.05 18"x8.5J | KSport Kontrol Pro's
Instagram @miKeyGilmore #MK3SLöCUS
MG_MK3 is offline
Old 07-27-2013, 05:03 PM   #125
I_go_for_Gs
Fan#: 113640
What I Drive: 2013 White SE 5MT
FF Reputation: 1 I_go_for_Gs Good Standing Member
Been on vacation, so a little late on this review
The initial drive, wow, the vibes were crazy on start up. The whole dash was shaking and the steering wheel felt like it was attached to the engine. So I put on 50kms hoping that it would get better. Noticed that anything above idle to 1800rpm was the worst, windows up or down. Getting it past 2000rpm to 3000rpm the shakes were tolerable. But trying to see anything behind me with the rear view mirror, let's just say forget it. Now the engine note is pure awesome from 3000-redline
I now have just over 400kms with the engine mount and the vibes have calmed down from 1800-3000rpm. That is my normal cruising rpm. Anything above that I like the vibes and sound. The initial start up is still the same, feels like I have aluminum motor mounts installed. The vibes from just over idle to 1750rpm still shakes the dash and steering wheel. I am hoping that at around 1000kms, the vibes will only be on initial start up and it only rough vibes through the steering wheel below 1700rpm.
I read up that the older duratec motors, the torque ratings were 59lbs for the bolts on the engine side and 39lbs for the frame side. I set my torque wrench to 55lbs and tried to loosen the 18mm bolts. Torque wrench clicked but did not loosen the bolt. I dialed it up to 60lbs and as the torque wrench clicked the bolt loosened So I tightened the 18mm bolts to 60lft/lbs. Did the same procedure to the frame side, starting at 35lbs and ending up at 40lbs to break the 15mm loose. So I tightened the 15mm to 40ft/lbs.
p.s. I have pics on my hard drive, how do I attach to this post? it keeps asking me for a url? Can't I just add my images to this post?
I_go_for_Gs is offline
Old 07-27-2013, 08:04 PM   #126
XlarXlar
XlarXlar's Avatar
Fan#: 111735
What I Drive: 2013 PB Ford Focus
Points 246, Level 4
Points: 246, Level: 4 Points: 246, Level: 4 Points: 246, Level: 4
Level Up 92% Completed
Level up: 92% Level up: 92% Level up: 92%
FF Reputation: 2 XlarXlar Good Standing Member
p.s. I have picks on my hard drive, how do I attach to this post? it keeps asking me for a url? Can't I just add my images to this post?
You have to upload it to another site and then post a link to it. A popular one seems to be photobucket. Here are the official instructions: http://www.focusfanatics.com/forum/s...ad.php?t=38843
XlarXlar is offline
Old 07-27-2013, 10:19 PM   #127
I_go_for_Gs
Fan#: 113640
O K, let's see if this works
http://www.flickr.com/photos/9946549...n/photostream/
Matt Black with red poly. I found a nice place to put the sticker.
http://www.flickr.com/photos/99465497@N07/9382102756/
Factory mount with just 6000kms.
http://www.flickr.com/photos/99465497@N07/9379318735/
New mount installed, took all of 35 minutes, and that included a Motorcraft oil filter and Mobil 1 0w-20.
Forgot to mention: Did a full throttle launch to redline, grabbed 2nd to redline and banged 3rd gear floored it to 6000rpm. The tires chirped hard on the 1-2 shift, but it just grabbed 3rd and pulled hard(I did it twice to see if I could get 3rd to chirp). Before, it felt like the engine and tranny rocked back and forth on the 1-2 shift and then the car moved forward. On a hard 2-3 shift the same rocking back and forth was there but it felt a split second longer. So definately impressed with the Turbo Tech mount. There is no more rocking/hesitation between shifts. The car just goes forward.
Old 07-28-2013, 11:48 AM   #128
TurboTechRacing
FF Affiliate
Fan#: 100913
Forum Activity 2%
Awesome!
-Aaron
Turbo Tech Racing
Old 07-28-2013, 04:56 PM   #129
Executable
Fan#: 116921
What I Drive: 2013 Gray Metallic Focus SE
Points 810, Level 15
Points: 810, Level: 15 Points: 810, Level: 15 Points: 810, Level: 15
Level Up 10% Completed
FF Reputation: 1 Executable Good Standing Member
Oh, man. I was wondering the same thing about my 2013 Ford Focus SE engine. It seems to be shaking all the time - the car only has 500 miles on it. I was getting worried. I had no idea that the mount was crappy as hell. I had a friend revving the engine while parking in neutral and I couldn't believe how much the motor was moving.
Thank God for this thread.
TurboTechRacing - please let us know if and when this part will be discounted for sale. I will definitely buy it.
Executable is offline
Old 07-28-2013, 05:28 PM   #130
TurboTechRacing
FF Affiliate
Fan#: 100913
Forum Activity 2%
Best price is on our site, shipping many each day.
-Aaron
Turbo Tech Racing
