Paint taking forever to dry! Suggestions? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus First Generation > MK1 Interior Mods & Upgrades
Old 06-27-2013, 06:03 PM   #1
LensDriven
LensDriven's Avatar
Fan#: 111184
What I Drive: 2006 Blk ZX4 SES, 2009 Blu Coupe SE
FF Reputation: 1 LensDriven Good Standing Member
So I painted my dash pieces. This was originally intended to be hammered finish over plastidip (for texture and removability). I just couldn't get the hammered finish to work. Like one pass would look awesome, then the next pass below would slightly overlap the first, as per the instructions, and that would cover the hammer effect- so it ended up looking hammered in stripes. So I let it dry a bit then went for something else- a scrap metal look.
It came out kinda neat, road warrior looking, but here it is 36 hours later and the paint is still a bit soft. Really need to get my car back together- I know the paint obviously went on way thicker than I intended- but still never had leaving finger prints this long after. I did my grille with black plastidip and about a can if clear over and it was fine in 24hrs...
Any ideas what would make this hurry up and dry? I know it's humid here in florida, but I brought the parts in and out em in a room with the fan and ac on after painting...
Here's the finished weirdness:
LensDriven is offline
Old 06-27-2013, 06:44 PM   #2
FLYLOW
FLYLOW's Avatar
Fan#: 34077
What I Drive: Gen Coupe Rspec
FF Reputation: 4 FLYLOW Good Standing Member
Buy-Sell-Trade Rating: (7)
Hair dryer? And patience
FLYLOW is offline
Old 06-27-2013, 07:08 PM   #3
Deftmetal
Moderator
Deftmetal's Avatar
Fan#: 105884
What I Drive: 2014 Mazda 3
Points 6,071, Level 50
Points: 6,071, Level: 50 Points: 6,071, Level: 50 Points: 6,071, Level: 50
Level Up 61% Completed
Level up: 61% Level up: 61% Level up: 61%
FF Reputation: 9 Deftmetal Good Standing Member
I've had this happen when using different kinds of paints. You need less humidity and heat to speed things along.
Rally Revolution #14
Josh
Originally Posted by dyn085 View Post
Don't hate on an amputee chick that's still playing with lego's.
Deftmetal is online now
Old 06-27-2013, 07:19 PM   #4
LensDriven
LensDriven's Avatar
Fan#: 111184
So more heat? I tried a hair dryer on warm/hot and it seemed to make the paint softer...? Someone here suggested the oven on 100... Kinda scared though. Bah! So frustrating!
Old 06-27-2013, 07:25 PM   #5
Paladin
VEKTOR PLATE
Paladin's Avatar
Fan#: 64465
What I Drive: blue sub #6
Points 5,736, Level 48
Points: 5,736, Level: 48 Points: 5,736, Level: 48 Points: 5,736, Level: 48
Level Up 93% Completed
Level up: 93% Level up: 93% Level up: 93%
Forum Activity 3%
FF Reputation: 10 Paladin Great Standing Member
my guess is the plastidip is making it a problem for the paint to grab on properly.
dunno buts its just a guess.
MR. freaking negative
i'm not an enthusiast...... the internets told me.
Paladin is offline
Old 06-27-2013, 07:47 PM   #6
CotyM
CotyM's Avatar
Fan#: 85558
What I Drive: blue, y2k, 5spd ZX3, zetec inside
Points 956, Level 16
Points: 956, Level: 16 Points: 956, Level: 16 Points: 956, Level: 16
Level Up 56% Completed
FF Reputation: 3 CotyM Good Standing Member
Did you use some form of primer? Paint is meant to bond to primer... I recommend a primer meant to bond onto plastics and rubbers... If plastidip is "paintible" like bed liner is then you don't need primer... then you need to achieve the right temp and humidity for the paint...
Most paint like around 75f... dunno about humidity but it is a factor...
2000 Ford Focus US Spec Zetec 5 speed "Blue Dragon"
2000 Renault Clio 1.4 DOHC 5speed "Snap Dragon"
Hatch Nation #32
CotyM is offline
Old 06-27-2013, 10:41 PM   #7
LensDriven
LensDriven's Avatar
Fan#: 111184
I used rustoleum universal hammered, the advanced formula primer & paint in one. It said no primer was needed and said it was safe for plastics- which is why if figured it would work over plastidip- the can also said flexible when dried, which I though was a plus too. I know these trim pieces are painted originally.
I've used other paint over plastidip with no issues, but not this kind. Everyone was raving about it- but I had a lot of trouble getting it to do what it suppose to... Don't know.
Haha, I know it takes my hair about 4 hours to air dry here in humid florida, maybe it just needs more time then... Just yeah, got worried I'd caused some chemical reaction that prevented it curing right, or there might be some trick I've never heard of.
Old 06-28-2013, 12:27 AM   #8
elsolo
elsolo's Avatar
Fan#: 96835
Points 2,621, Level 31
Points: 2,621, Level: 31 Points: 2,621, Level: 31 Points: 2,621, Level: 31
Level Up 14% Completed
The hammered paints have silicone(s) in them which make them almost fisheye to get the desired appearance. That makes them not adhere quite as well. I did a rollaway toolbox with hammered paint about 10 years ago, primed and prepped it like painting a car. It is the most fragile, poorly adhering paint I have ever used.
Did the paint dry properly on the masking tape?
If it is dry there, the plastidip base coat on the plastic may be the problem.
I say add heat via lamps or whatever, you need temp to drive the solvents out of the paint.
elsolo is offline
Old 06-28-2013, 12:34 AM   #9
mix1983
Life Is Good
mix1983's Avatar
Fan#: 61101
What I Drive: 2000 Honda Civic EX 5spd
Points 9,181, Level 64
Points: 9,181, Level: 64 Points: 9,181, Level: 64 Points: 9,181, Level: 64
Level Up 44% Completed
Forum Activity 6%
FF Reputation: 5 mix1983 Good Standing Member
If it wasn't plastic I'd say bake it. Are the parts outside where air can get to them? Something you could try is if you have a space heater, seal up a room in your house (towel under the door, windows closed) and crank the heat in the room with the parts in there. Don't aim the heater right at them, just let the room become a big oven basically.
I've done this to dry clothes when all the dryers in my apartment complex are full.
I'm all about sharing the road with other drivers - as long as they use the part that's behind me.
mix1983 is online now
Old 06-28-2013, 12:52 AM   #10
LensDriven
LensDriven's Avatar
Fan#: 111184
There parts... Like the edges where I didn't get as much paint, that seem to have dried ok- so it seems it IS possible for this stuff to dry over plastidip. I mean- I did test it on something plastic. Plastidip, then this stuff- seemed ok.. But now I'm working on a larger area...
Right now I'm trying sitting IN FRONT of a hot oven, not in. But that's a really good idea with the heater in a room- might have a working one somewhere in the attic- not something that sees much use here.
