Holset hx35 smoking - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-26-2013, 01:37 PM   #1
koke'sfocus
koke'sfocus's Avatar
Fan#: 69779
What I Drive: 05 silver st
Points 4,267, Level 41
Points: 4,267, Level: 41 Points: 4,267, Level: 41 Points: 4,267, Level: 41
Level Up 59% Completed
FF Reputation: 1 koke'sfocus Good Standing Member
Buy-Sell-Trade Rating: (6)
Holset hx35 smoking
Ok I had some problems with my drain line my car use to smoke alittle after sitting down in the traffic and what not, my drain line it was 10an now I change the drain line to 12an cause it got worst but it only smokes some times not at all the time, I took out the turbo it was a pita lol and I found out that the bolts that connects the exhaust housing weren't that tight could that be te problem?or should I rebuild the turbo ? No shaft play was found and no oil in the charge pipe thanks for all your opinions
cossie im, cfm 67mm tb, 3" dp, 3" exhaust and custom turbo kit, holset hx35 turbo on 13psi, exedy stage 2 clutch and flywheel
Stock long block 353whp 280lbtq, 13psi
team duratec #94
D23 crew #9.
koke'sfocus is offline
Old 06-26-2013, 11:25 PM   #2
koke'sfocus
Fan#: 69779
No one? Lol never mind guy I just rebuild the turbo but I broke the banjo of the feed line :( have to get another one :(
team duratec #94
D23 crew #9.
Old 06-27-2013, 08:58 AM   #3
700whpfocus
Fan#: 40899
What I Drive: 2000 zx3 twillight blue focus
Points 5,460, Level 47
Points: 5,460, Level: 47 Points: 5,460, Level: 47 Points: 5,460, Level: 47
Level Up 55% Completed
FF Reputation: 2 700whpfocus Good Standing Member
Buy-Sell-Trade Rating: (11)
how is that turbo on your car? when does boost come in?
700whpfocus is offline
Old 06-27-2013, 09:00 AM   #4
JSV578
Fan#: 93418
What I Drive: 2008, Black, B23T
Points 69, Level 1
Points: 69, Level: 1 Points: 69, Level: 1 Points: 69, Level: 1
Level Up 38% Completed
FF Reputation: 3 JSV578 Good Standing Member
The only times I had problem with my HX35 was:
-1 when I was still using stock 5/20 oil!
-2 bad size feed restriction
-3 feed problem lol
those turbos are tank
they use more oil than ball bearing, so more oil grade sensitive but still bullet proof.
And they are so easy to rebuilt (except the hot side seal ring that can be a pita)
JSV578 is offline
Old 06-27-2013, 09:02 AM   #5
JSV578
Fan#: 93418
Points 69, Level 1
mine boost at 3500 and this was plan that way
JSV578 is offline
Old 06-27-2013, 08:50 PM   #6
koke'sfocus
Fan#: 69779
What is the ideal oil grade to use?my problem was the drain line now I have a 12an lol it was really easy to rebuild, the only thing that was a pita was the clip that holds the inlet turbine :/
And mine it fully spools like @ 4k ish is not fully tune
-3 feed problem lol
team duratec #94
D23 crew #9.
Old 06-27-2013, 09:36 PM   #7
ZXthrizzle05
TURBO ZX3
ZXthrizzle05's Avatar
Fan#: 24434
What I Drive: 2007 mazda 3 I sport, TURBO ZX3
Points 50,882, Level 100
Points: 50,882, Level: 100 Points: 50,882, Level: 100 Points: 50,882, Level: 100
Level Up 0% Completed
Forum Activity 4%
FF Reputation: 6 ZXthrizzle05 Good Standing Member
my car smokes when running for a while, cant trace it thou, seems to be from the radiator and blowing out my fenders when fan kicks on lol
FF MODERATOR
RISE AGAIN EGGYOLK302 WHP 274 WTQ ZETEC CREW #271
RIFF CREW
ZXthrizzle05 is online now
Old 06-27-2013, 10:09 PM   #8
JSV578
Fan#: 93418
Points 69, Level 1
I'm using 5/40 synthetic oil
JSV578 is offline
Old 06-28-2013, 02:27 PM   #9
koke'sfocus
Fan#: 69779
I just fix the feed line issue and no smoke @all :) what's the break in period on turbos? 1k miles? 1.5k?
team duratec #94
D23 crew #9.
Old 06-28-2013, 03:09 PM   #10
Roushturboedzx3
I Fab Too Much
Roushturboedzx3's Avatar
Fan#: 42814
What I Drive: 2002 Liquid Gray ZX3
Points 14,483, Level 78
Points: 14,483, Level: 78 Points: 14,483, Level: 78 Points: 14,483, Level: 78
Level Up 9% Completed
FF Reputation: 20 Roushturboedzx3 Great Standing Member
Buy-Sell-Trade Rating: (18)
No break in, just run it around for 20-30 miles and go over all the bolts again and check for leaks then let her eat.
New: 2012 Mustang GT premium
SOLD:RACE GAS 602whp 501tq Pump Gas SAE 454whp
Garrett GT3582r, Topmount, built motor, Ported head,Tuned by Fernando@RacingPartsSolution
I may not be the baddest, but the baddest dont Fu** with me
Roushturboedzx3 is offline
