Rough idle solutions? - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-27-2013, 09:19 PM   #11
Tjrommel
Tjrommel's Avatar
Fan#: 114674
What I Drive: 2013 Oxford white Sedan 5M
Points 1,588, Level 22
Points: 1,588, Level: 22 Points: 1,588, Level: 22 Points: 1,588, Level: 22
Level Up 88% Completed
Level up: 88% Level up: 88% Level up: 88%
FF Reputation: 1 Tjrommel Good Standing Member
Originally Posted by Juicedz View Post
Yea, the Cobb rmm is probably one of the stiffer ones on the market but also one of the nicest. Btw, you should have warned me about the Mt. Everest speed bump on the way out! Wowzers, I think it took three tries to get over that beast.
How you like the cfm rmm?
Tjrommel is offline
Old 06-28-2013, 01:21 AM   #12
Juicedz
Juicedz's Avatar
Fan#: 108814
What I Drive: 2013 Ford Focus Hatchback SE, 5sp
Points 2,372, Level 29
Points: 2,372, Level: 29 Points: 2,372, Level: 29 Points: 2,372, Level: 29
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
FF Reputation: 3 Juicedz Good Standing Member
Very affordable piece with very positive results. Minimal vibrations at idle while still reducing a large percentage of the flex. It's a happy medium between the Cobb and stock. It all depends on what your plans are. If you want all out performance/handling and are willing to sacrifice a little creature comforts with the stiffer Cobb mount go with that, it's definitely the better piece. I felt the cfm rmm would be enough for what my expectations were with the car.
'13 Oxford White Hatch 5-speed
injected 93 tune, steeda intake, e-focus rmm
Hatch Nation#24 172whp 157wtq
Juicedz is offline
Old 06-28-2013, 08:22 AM   #13
ShoOff
ShoOff's Avatar
Fan#: 109590
What I Drive: 2013 Performance Blue SE Hatchback
Points 1,858, Level 25
Points: 1,858, Level: 25 Points: 1,858, Level: 25 Points: 1,858, Level: 25
Level Up 58% Completed
FF Reputation: 16 ShoOff Great Standing Member
Very affordable piece with very positive results. Very minimal vibrations at idle while still reducing a large percentage of the flex. It's a happy medium between the Cobb and stock. It all depends on what your plans are. If you want all out performance/handling and are willing to sacrifice a little creature comforts with the stiffer Cobb mount go with that, it's definitely the better piece. I felt the cfm rmm would be enough for what my expectations were with the car.
Well said, I went with the Cobb because I plan on a highly moddded motor. (maybe turbo even? ) But if you simply want to improve on what you already have save your money and get the cfm
Steeda CAI, Steeda STS, Magnaflo Cat Back Exhaust, Injected Tuner, Cobb Rear Motor Mount, TTR Upper Motor Mount, Injected 180 T Stat
ShoOff is offline
Old 06-28-2013, 02:29 PM   #14
CriticalMass
Fan#: 63989
What I Drive: 2009 Focus Coupe SES, Silver
Points 372, Level 7
Points: 372, Level: 7 Points: 372, Level: 7 Points: 372, Level: 7
Level Up 44% Completed
FF Reputation: 2 CriticalMass Good Standing Member
My 2009 has this and has since they replaced the throttle body last year. in gear (automatic) on the brake (foot pedal). Idles around 600-650 and vibrates (smoothed out some going to copper plugs)
Second thing I noticed is that I started getting 37-38mpg instead of 30-33mpg.
and yeah, even just 30rpm higher and it goes away completely. Such as when you turn the A/C on, the vibration is just completely gone.
Before they replaced it the car idled around 700-800 depending and always did and there was no vibration, but the throttle body started acting up right before the warranty was up. The idle fluctuation became 400-600 RPMS instead of the usuall 100-200 and it was almost dying when it would bounce down low and then wanting to take off on you when it would bounce high. TSB for it. so they replaced it right before the warranty was up.
My guess is the mpg and the low /rough idle might somehow be related.
2009 Ford Focus Coupe SES -- What I don't know about modern cars would fill up a good sized country, but what I don't know about 50's and 60's Ford engines, would fill up a 4 oz glass.
CriticalMass is offline
Old 07-01-2013, 03:52 PM   #15
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Points 1,277, Level 19
Level Up 77% Completed
The CFM mount is the electric Focus mount. There are plenty of positive comments about it. It's cheaper to buy the mount from Ford than from CFM.
Hatch Nation #90
TboneZX3 is offline
Old 07-05-2013, 08:45 PM   #16
Tjrommel
Tjrommel's Avatar
Fan#: 114674
Are you sure?
Tjrommel is offline
Old 07-06-2013, 07:42 AM   #17
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
The mount at the link below is the electric Focus mount. I am certain.
http://focus.c-f-m.com/cfm-performan...-focus-st.aspx
Hatch Nation #90
TboneZX3 is offline
